RTEMS 6.1-rc4
fsl-mpc551x.h
1/*
2 * Modifications of the original file provided by Freescale are:
3 *
4 * Copyright (c) 2011 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
16 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
17 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
18 * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
19 * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
20 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
21 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
22 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
23 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
24 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
25 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
26 */
27
28/**************************************************************************/
29/* FILE NAME: mpc5510.h COPYRIGHT (c) Freescale 2008 */
30/* REVISION: 2.2 All Rights Reserved */
31/* */
32/* DESCRIPTION: */
33/* This file contain all of the register and bit field definitions for */
34/* MPC5510. */
35/**************************************************************************/
36/*>>>>NOTE! this file is auto-generated please do not edit it!<<<<*/
37
38/*************************************************/
39/* Example register & bit field write: */
40/* */
41/* <MODULE>.<REGISTER>.B.<BIT> = 1; */
42/* <MODULE>.<REGISTER>.R = 0x10000000; */
43/* */
44/*************************************************/
45
46#ifndef _MPC5510_H_
47#define _MPC5510_H_
48
49#ifndef ASM
50
51#include <stdint.h>
52
53#include <mpc55xx/regs-edma.h>
54
55#ifdef __cplusplus
56extern "C" {
57#endif
58
59#ifdef __MWERKS__
60#pragma push
61#pragma ANSI_strict off
62#endif
63
64/****************************************************************************/
65/* MODULE : CRP */
66/****************************************************************************/
67 struct CRP_tag {
68
69 union {
70 uint32_t R;
71 struct {
72 uint32_t:12;
73 uint32_t IRC32KEN:1;
74 uint32_t XOSCEN:1;
75 uint32_t:1;
76 uint32_t OSC32KEN:1;
77 uint32_t TRIM32IRC:8;
78 uint32_t TRIMIRC:8;
79 } B;
80 } CLKSRC; /* Clock Source Register */
81
82 uint32_t crp_reserved1[3];
83
84 union {
85 uint32_t R;
86 struct {
87 uint32_t CNTEN:1;
88 uint32_t RTCIE:1;
89 uint32_t RTCF:1;
90 uint32_t ROVRF:1;
91 uint32_t RTCVAL:12;
92 uint32_t APIEN:1;
93 uint32_t APIIE:1;
94 uint32_t APIF:1;
95 uint32_t CLKSEL:2;
96 uint32_t ROVREN:1;
97 uint32_t APIVAL:10;
98 } B;
99 } RTCSC; /* RTC Status and Control Register */
100
101 union {
102 uint32_t R;
103 struct {
104 uint32_t RTCCNT:32;
105 } B;
106 } RTCCNT; /* RTC Counter Register */
107
108 uint32_t crp_reserved2[10];
109
110 union {
111 uint32_t R;
112 struct {
113 uint32_t:1;
114 uint32_t WKPSEL7:3;
115 uint32_t:1;
116 uint32_t WKPSEL6:3;
117 uint32_t:1;
118 uint32_t WKPSEL5:3;
119 uint32_t:1;
120 uint32_t WKPSEL4:3;
121 uint32_t:1;
122 uint32_t WKPSEL3:3;
123 uint32_t:1;
124 uint32_t WKPSEL2:3;
125 uint32_t:1;
126 uint32_t WKPSEL1:3;
127 uint32_t:1;
128 uint32_t WKPSEL0:3;
129 } B;
130 } WKPINSEL; /* Wakeup Pin Source Select Register */
131
132 union {
133 uint32_t R;
134 struct {
135 uint32_t WKPDET7:2;
136 uint32_t WKPDET6:2;
137 uint32_t WKPDET5:2;
138 uint32_t WKPDET4:2;
139 uint32_t WKPDET3:2;
140 uint32_t WKPDET2:2;
141 uint32_t WKPDET1:2;
142 uint32_t WKPDET0:2;
143 uint32_t:5;
144 uint32_t RTCOVREN:1;
145 uint32_t RTCWKEN:1;
146 uint32_t APIWKEN:1;
147 uint32_t:7;
148 uint32_t WKCLKSEL:1;
149 } B;
150 } WKSE; /* Wakeup Source Enable Register */
151
152 uint32_t crp_reserved3[2];
153
154 union {
155 uint32_t R;
156 struct {
157 uint32_t Z1VEC:30;
158 uint32_t Z1RST:1;
159 uint32_t VLE:1;
160 } B;
161 } Z1VEC; /* Z1 Reset Vector Register */
162
163 union {
164 uint32_t R;
165 struct {
166 uint32_t Z0VEC:30;
167 uint32_t Z0RST:1;
168 uint32_t:1;
169 } B;
170 } Z0VEC; /* Z0 Reset Vector Register */
171
172 union {
173 uint32_t R;
174 struct {
175 uint32_t RECPTR:30;
176 uint32_t FASTREC:1;
177 uint32_t:1;
178 } B;
179 } RECPTR; /* Reset Recovery Pointer Register */
180
181 uint32_t crp_reserved4;
182
183 union {
184 uint32_t R;
185 struct {
186 uint32_t SLEEPF:1;
187 uint32_t STOPF:1;
188 uint32_t:3;
189 uint32_t WKRLLOVRF:1;
190 uint32_t WKAPIF:1;
191 uint32_t WKRTCF:1;
192 uint32_t PWKSCRF:8;
193 uint32_t SLEEP:1;
194 uint32_t STOP:1;
195 uint32_t:1;
196 uint32_t PKREL:1;
197 uint32_t SLP12EN:1;
198 uint32_t RAMSEL:3;
199 uint32_t PWKSRIE:8;
200 } B;
201 } PSCR; /* Power Status and Control Register */
202
203 uint32_t crp_reserved5[3];
204
205 union {
206 uint32_t R;
207 struct {
208 uint32_t LVI5IE:1;
209 uint32_t LVI5HIE:1;
210 uint32_t LVI5F:1;
211 uint32_t LVI5HF:1;
212 uint32_t LVI5LOCK:1;
213 uint32_t LVI5RE:1;
214 uint32_t:9;
215 uint32_t BYPDIS:1;
216 uint32_t:16;
217 } B;
218 } SOCSC; /* LVI Status and Control Register */
219
220 };
221/****************************************************************************/
222/* MODULE : DMAMUX */
223/****************************************************************************/
224 struct DMAMUX_tag {
225 union {
226 uint8_t R;
227 struct {
228 uint8_t ENBL:1;
229 uint8_t TRIG:1;
230 uint8_t SOURCE:6;
231 } B;
232 } CHCONFIG[16]; /* DMA Channel Configuration Register */
233
234 };
235/****************************************************************************/
236/* MODULE : DSPI */
237/****************************************************************************/
238 struct DSPI_tag {
240 uint32_t R;
241 struct {
242 uint32_t MSTR:1;
243 uint32_t CONT_SCKE:1;
244 uint32_t DCONF:2;
245 uint32_t FRZ:1;
246 uint32_t MTFE:1;
247 uint32_t PCSSE:1;
248 uint32_t ROOE:1;
249 uint32_t:2;
250 uint32_t PCSIS5:1;
251 uint32_t PCSIS4:1;
252 uint32_t PCSIS3:1;
253 uint32_t PCSIS2:1;
254 uint32_t PCSIS1:1;
255 uint32_t PCSIS0:1;
256 uint32_t:1;
257 uint32_t MDIS:1;
258 uint32_t DIS_TXF:1;
259 uint32_t DIS_RXF:1;
260 uint32_t CLR_TXF:1;
261 uint32_t CLR_RXF:1;
262 uint32_t SMPL_PT:2;
263 uint32_t:7;
264 uint32_t HALT:1;
265 } B;
266 } MCR; /* Module Configuration Register */
267
268 uint32_t dspi_reserved1;
269
270 union {
271 uint32_t R;
272 struct {
273 uint32_t SPI_TCNT:16;
274 uint32_t:16;
275 } B;
276 } TCR;
277
279 uint32_t R;
280 struct {
281 uint32_t DBR:1;
282 uint32_t FMSZ:4;
283 uint32_t CPOL:1;
284 uint32_t CPHA:1;
285 uint32_t LSBFE:1;
286 uint32_t PCSSCK:2;
287 uint32_t PASC:2;
288 uint32_t PDT:2;
289 uint32_t PBR:2;
290 uint32_t CSSCK:4;
291 uint32_t ASC:4;
292 uint32_t DT:4;
293 uint32_t BR:4;
294 } B;
295 } CTAR[8]; /* Clock and Transfer Attributes Registers */
296
298 uint32_t R;
299 struct {
300 uint32_t TCF:1;
301 uint32_t TXRXS:1;
302 uint32_t:1;
303 uint32_t EOQF:1;
304 uint32_t TFUF:1;
305 uint32_t:1;
306 uint32_t TFFF:1;
307 uint32_t:5;
308 uint32_t RFOF:1;
309 uint32_t:1;
310 uint32_t RFDF:1;
311 uint32_t:1;
312 uint32_t TXCTR:4;
313 uint32_t TXNXTPTR:4;
314 uint32_t RXCTR:4;
315 uint32_t POPNXTPTR:4;
316 } B;
317 } SR; /* Status Register */
318
320 uint32_t R;
321 struct {
322 uint32_t TCF_RE:1;
323 uint32_t:2;
324 uint32_t EOQFRE:1;
325 uint32_t TFUFRE:1;
326 uint32_t:1;
327 uint32_t TFFFRE:1;
328 uint32_t TFFFDIRS:1;
329 uint32_t:4;
330 uint32_t RFOFRE:1;
331 uint32_t:1;
332 uint32_t RFDFRE:1;
333 uint32_t RFDFDIRS:1;
334 uint32_t:16;
335 } B;
336 } RSER; /* DMA/Interrupt Request Select and Enable Register */
337
339 uint32_t R;
340 struct {
341 uint32_t CONT:1;
342 uint32_t CTAS:3;
343 uint32_t EOQ:1;
344 uint32_t CTCNT:1;
345 uint32_t:4;
346 uint32_t PCS5:1;
347 uint32_t PCS4:1;
348 uint32_t PCS3:1;
349 uint32_t PCS2:1;
350 uint32_t PCS1:1;
351 uint32_t PCS0:1;
352 uint32_t TXDATA:16;
353 } B;
354 } PUSHR; /* PUSH TX FIFO Register */
355
357 uint32_t R;
358 struct {
359 uint32_t:16;
360 uint32_t RXDATA:16;
361 } B;
362 } POPR; /* POP RX FIFO Register */
363
364 union {
365 uint32_t R;
366 struct {
367 uint32_t TXCMD:16;
368 uint32_t TXDATA:16;
369 } B;
370 } TXFR[4]; /* Transmit FIFO Registers */
371
372 uint32_t DSPI_reserved_txf[12];
373
374 union {
375 uint32_t R;
376 struct {
377 uint32_t:16;
378 uint32_t RXDATA:16;
379 } B;
380 } RXFR[4]; /* Transmit FIFO Registers */
381
382 uint32_t DSPI_reserved_rxf[12];
383
384 union {
385 uint32_t R;
386 struct {
387 uint32_t:12;
388 uint32_t TXSS:1;
389 uint32_t:2;
390 uint32_t CID:1;
391 uint32_t DCONT:1;
392 uint32_t DSICTAS:3;
393 uint32_t:6;
394 uint32_t DPCS5:1;
395 uint32_t DPCS4:1;
396 uint32_t DPCS3:1;
397 uint32_t DPCS2:1;
398 uint32_t DPCS1:1;
399 uint32_t DPCS0:1;
400 } B;
401 } DSICR; /* DSI Configuration Register */
402
403 union {
404 uint32_t R;
405 struct {
406 uint32_t:16;
407 uint32_t SER_DATA:16;
408 } B;
409 } SDR; /* DSI Serialization Data Register */
410
411 union {
412 uint32_t R;
413 struct {
414 uint32_t:16;
415 uint32_t ASER_DATA:16;
416 } B;
417 } ASDR; /* DSI Alternate Serialization Data Register */
418
419 union {
420 uint32_t R;
421 struct {
422 uint32_t:16;
423 uint32_t COMP_DATA:16;
424 } B;
425 } COMPR; /* DSI Transmit Comparison Register */
426
427 union {
428 uint32_t R;
429 struct {
430 uint32_t:16;
431 uint32_t DESER_DATA:16;
432 } B;
433 } DDR; /* DSI deserialization Data Register */
434
435 };
436/****************************************************************************/
437/* MODULE : External Bus Interface (EBI) */
438/****************************************************************************/
439
440/* CS_tag instantiated within EBI_tag */
441 struct EBI_CS_tag {
442 union { /* Base Register Bank */
443 uint32_t R;
444 struct {
445 uint32_t BA:17;
446 uint32_t:3;
447 uint32_t PS:1;
448 uint32_t:3;
449 uint32_t AD_MUX:1;
450 uint32_t BL:1;
451 uint32_t WEBS:1;
452 uint32_t TBDIP:1;
453 uint32_t:1;
454 uint32_t SETA:1;
455 uint32_t BI:1;
456 uint32_t V:1;
457 } B;
458 } BR;
459
460 union { /* Option Register Bank */
461 uint32_t R;
462 struct {
463 uint32_t AM:17;
464 uint32_t:7;
465 uint32_t SCY:4;
466 uint32_t:1;
467 uint32_t BSCY:2;
468 uint32_t:1;
469 } B;
470 } OR;
471 };
472
474 uint32_t ebi_cal_cs_reserved [2];
475 };
476
477 struct EBI_tag {
478 union EBI_MCR_tag { /* Module Configuration Register */
479 uint32_t R;
480 struct {
481 uint32_t:16;
482 uint32_t ACGE:1;
483 uint32_t EXTM:1;
484 uint32_t EARB:1;
485 uint32_t:6;
486 uint32_t MDIS:1;
487 uint32_t:3;
488 uint32_t D16_31:1;
489 uint32_t AD_MUX:1;
490 uint32_t DBM:1;
491 } B;
492 } MCR;
493
494 uint32_t EBI_reserved1;
495
496 union { /* Transfer Error Status Register */
497 uint32_t R;
498 struct {
499 uint32_t:30;
500 uint32_t TEAF:1;
501 uint32_t BMTF:1;
502 } B;
503 } TESR;
504
505 union { /* Bus Monitor Control Register */
506 uint32_t R;
507 struct {
508 uint32_t:16;
509 uint32_t BMT:8;
510 uint32_t BME:1;
511 uint32_t:7;
512 } B;
513 } BMCR;
514
515 /* Roll in 3x CS registers */
516 struct EBI_CS_tag CS[4];
517
518 uint32_t EBI_reserved2[4];
519
520 struct EBI_CAL_CS_tag CAL_CS[4];
521 };
522/****************************************************************************/
523/* MODULE : EMIOS */
524/****************************************************************************/
525 struct EMIOS_tag {
527 uint32_t R;
528 struct {
529 uint32_t:1;
530 uint32_t MDIS:1;
531 uint32_t FRZ:1;
532 uint32_t GTBE:1;
533 uint32_t:1;
534 uint32_t GPREN:1;
535 uint32_t:10;
536 uint32_t GPRE:8;
537 uint32_t:8;
538 } B;
539 } MCR; /* Module Configuration Register */
540
541 union {
542 uint32_t R;
543 struct {
544 uint32_t:8;
545 uint32_t F23:1;
546 uint32_t F22:1;
547 uint32_t F21:1;
548 uint32_t F20:1;
549 uint32_t F19:1;
550 uint32_t F18:1;
551 uint32_t F17:1;
552 uint32_t F16:1;
553 uint32_t F15:1;
554 uint32_t F14:1;
555 uint32_t F13:1;
556 uint32_t F12:1;
557 uint32_t F11:1;
558 uint32_t F10:1;
559 uint32_t F9:1;
560 uint32_t F8:1;
561 uint32_t F7:1;
562 uint32_t F6:1;
563 uint32_t F5:1;
564 uint32_t F4:1;
565 uint32_t F3:1;
566 uint32_t F2:1;
567 uint32_t F1:1;
568 uint32_t F0:1;
569 } B;
570 } GFG; /* Global FLAG Register */
571
572 union {
573 uint32_t R;
574 struct {
575 uint32_t:8;
576 uint32_t OU23:1;
577 uint32_t OU22:1;
578 uint32_t OU21:1;
579 uint32_t OU20:1;
580 uint32_t OU19:1;
581 uint32_t OU18:1;
582 uint32_t OU17:1;
583 uint32_t OU16:1;
584 uint32_t OU15:1;
585 uint32_t OU14:1;
586 uint32_t OU13:1;
587 uint32_t OU12:1;
588 uint32_t OU11:1;
589 uint32_t OU10:1;
590 uint32_t OU9:1;
591 uint32_t OU8:1;
592 uint32_t OU7:1;
593 uint32_t OU6:1;
594 uint32_t OU5:1;
595 uint32_t OU4:1;
596 uint32_t OU3:1;
597 uint32_t OU2:1;
598 uint32_t OU1:1;
599 uint32_t OU0:1;
600 } B;
601 } OUDR; /* Output Update Disable Register */
602
603 union {
604 uint32_t R;
605 struct {
606 uint32_t:8;
607 uint32_t UC23:1;
608 uint32_t UC22:1;
609 uint32_t UC21:1;
610 uint32_t UC20:1;
611 uint32_t UC19:1;
612 uint32_t UC18:1;
613 uint32_t UC17:1;
614 uint32_t UC16:1;
615 uint32_t UC15:1;
616 uint32_t UC14:1;
617 uint32_t UC13:1;
618 uint32_t UC12:1;
619 uint32_t UC11:1;
620 uint32_t UC10:1;
621 uint32_t UC9:1;
622 uint32_t UC8:1;
623 uint32_t UC7:1;
624 uint32_t UC6:1;
625 uint32_t UC5:1;
626 uint32_t UC4:1;
627 uint32_t UC3:1;
628 uint32_t UC2:1;
629 uint32_t UC1:1;
630 uint32_t UC0:1;
631 } B;
632 } UCDIS; /* Disable Channel Register */
633
634 uint32_t emios_reserved1[4];
635
637 union {
638 uint32_t R;
639 struct {
640 uint32_t:16;
641 uint32_t A:16; /* Channel A Data Register */
642 } B;
643 } CADR;
644
645 union {
646 uint32_t R;
647 struct {
648 uint32_t:16;
649 uint32_t B:16; /* Channel B Data Register */
650 } B;
651 } CBDR;
652
653 union {
654 uint32_t R; /* Channel Counter Register */
655 struct {
656 uint32_t:16;
657 uint32_t C:16; /* Channel C Data Register */
658 } B;
659 } CCNTR;
660
662 uint32_t R;
663 struct {
664 uint32_t FREN:1;
665 uint32_t ODIS:1;
666 uint32_t ODISSL:2;
667 uint32_t UCPRE:2;
668 uint32_t UCPREN:1;
669 uint32_t DMA:1;
670 uint32_t:1;
671 uint32_t IF:4;
672 uint32_t FCK:1;
673 uint32_t FEN:1;
674 uint32_t:3;
675 uint32_t FORCMA:1;
676 uint32_t FORCMB:1;
677 uint32_t:1;
678 uint32_t BSL:2;
679 uint32_t EDSEL:1;
680 uint32_t EDPOL:1;
681 uint32_t MODE:7;
682 } B;
683 } CCR; /* Channel Control Register */
684
686 uint32_t R;
687 struct {
688 uint32_t OVR:1;
689 uint32_t:15;
690 uint32_t OVFL:1;
691 uint32_t:12;
692 uint32_t UCIN:1;
693 uint32_t UCOUT:1;
694 uint32_t FLAG:1;
695 } B;
696 } CSR; /* Channel Status Register */
697
698 union {
699 uint32_t R; /* Alternate Channel A Data Register */
700 } ALTA;
701
702 uint32_t emios_channel_reserved[2];
703
704 } CH[24];
705
706 };
707/****************************************************************************/
708/* MODULE : EQADC */
709/****************************************************************************/
710 struct EQADC_tag {
711 union {
712 uint32_t R;
713 struct {
714 uint32_t:30;
715 uint32_t DBG:2;
716 } B;
717 } MCR; /* Module Configuration Register */
718
719 uint32_t eqadc_reserved0;
720
721 union {
722 uint32_t R;
723 struct {
724 uint32_t:6;
725 uint32_t NMF:26;
726 } B;
727 } NMSFR; /* Null Message Send Format Register */
728
729 union {
730 uint32_t R;
731 struct {
732 uint32_t:28;
733 uint32_t DFL:4;
734 } B;
735 } ETDFR; /* External Trigger Digital Filter Register */
736
737 union {
738 uint32_t R;
739 struct {
740 uint32_t CF_PUSH:32;
741 } B;
742 } CFPR[6]; /* CFIFO Push Registers */
743
744 uint32_t eqadc_reserved1;
745
746 uint32_t eqadc_reserved2;
747
748 union {
749 uint32_t R;
750 struct {
751 uint32_t:16;
752 uint32_t RF_POP:16;
753 } B;
754 } RFPR[6]; /* Result FIFO Pop Registers */
755
756 uint32_t eqadc_reserved3;
757
758 uint32_t eqadc_reserved4;
759
760 union {
761 uint16_t R;
762 struct {
763 uint16_t:5;
764 uint16_t SSE:1;
765 uint16_t CFINV:1;
766 uint16_t:1;
767 uint16_t MODE:4;
768 uint16_t:4;
769 } B;
770 } CFCR[6]; /* CFIFO Control Registers */
771
772 uint32_t eqadc_reserved5;
773
774 union {
775 uint16_t R;
776 struct {
777 uint16_t NCIE:1;
778 uint16_t TORIE:1;
779 uint16_t PIE:1;
780 uint16_t EOQIE:1;
781 uint16_t CFUIE:1;
782 uint16_t:1;
783 uint16_t CFFE:1;
784 uint16_t CFFS:1;
785 uint16_t:4;
786 uint16_t RFOIE:1;
787 uint16_t:1;
788 uint16_t RFDE:1;
789 uint16_t RFDS:1;
790 } B;
791 } IDCR[6]; /* Interrupt and DMA Control Registers */
792
793 uint32_t eqadc_reserved6;
794
795 union {
796 uint32_t R;
797 struct {
798 uint32_t NCF:1;
799 uint32_t TORF:1;
800 uint32_t PF:1;
801 uint32_t EOQF:1;
802 uint32_t CFUF:1;
803 uint32_t SSS:1;
804 uint32_t CFFF:1;
805 uint32_t:5;
806 uint32_t RFOF:1;
807 uint32_t:1;
808 uint32_t RFDF:1;
809 uint32_t:1;
810 uint32_t CFCTR:4;
811 uint32_t TNXTPTR:4;
812 uint32_t RFCTR:4;
813 uint32_t POPNXTPTR:4;
814 } B;
815 } FISR[6]; /* FIFO and Interrupt Status Registers */
816
817 uint32_t eqadc_reserved7;
818
819 uint32_t eqadc_reserved8;
820
821 union {
822 uint16_t R;
823 struct {
824 uint16_t:5;
825 uint16_t TC_CF:11;
826 } B;
827 } CFTCR[6]; /* CFIFO Transfer Counter Registers */
828
829 uint32_t eqadc_reserved9;
830
831 union {
832 uint32_t R;
833 struct {
834 uint32_t CFS0_T0:2;
835 uint32_t CFS1_T0:2;
836 uint32_t CFS2_T0:2;
837 uint32_t CFS3_T0:2;
838 uint32_t CFS4_T0:2;
839 uint32_t CFS5_T0:2;
840 uint32_t:5;
841 uint32_t LCFT0:4;
842 uint32_t TC_LCFT0:11;
843 } B;
844 } CFSSR0; /* CFIFO Status Register 0 */
845
846 uint32_t eqadc_reserved10[2];
847
848 union {
849 uint32_t R;
850 struct {
851 uint32_t CFS0:2;
852 uint32_t CFS1:2;
853 uint32_t CFS2:2;
854 uint32_t CFS3:2;
855 uint32_t CFS4:2;
856 uint32_t CFS5:2;
857 uint32_t:20;
858 } B;
859 } CFSR;
860
861 uint32_t eqadc_reserved11[20];
862
863 struct {
864 union {
865 uint32_t R;
866 struct {
867 uint32_t:32;
868 } B;
869 } R[4];
870
871 uint32_t eqadc_reserved12[12];
872
873 } CF[6];
874
875 uint32_t eqadc_reserved13[32];
876
877 struct {
878 union {
879 uint32_t R;
880 struct {
881 uint32_t:32;
882 } B;
883 } R[4];
884
885 uint32_t eqadc_reserved14[12];
886
887 } RF[6];
888
889 };
890/****************************************************************************/
891/* MODULE : eSCI */
892/****************************************************************************/
893 struct ESCI_tag {
895 uint32_t R;
896 struct {
897 uint32_t:3;
898 uint32_t SBR:13;
899 uint32_t LOOPS:1;
900 uint32_t:1;
901 uint32_t RSRC:1;
902 uint32_t M:1;
903 uint32_t WAKE:1;
904 uint32_t ILT:1;
905 uint32_t PE:1;
906 uint32_t PT:1;
907 uint32_t TIE:1;
908 uint32_t TCIE:1;
909 uint32_t RIE:1;
910 uint32_t ILIE:1;
911 uint32_t TE:1;
912 uint32_t RE:1;
913 uint32_t RWU:1;
914 uint32_t SBK:1;
915 } B;
916 } CR1; /* Control Register 1 */
917
919 uint16_t R;
920 struct {
921 uint16_t MDIS:1;
922 uint16_t FBR:1;
923 uint16_t BSTP:1;
924 uint16_t IEBERR:1;
925 uint16_t RXDMA:1;
926 uint16_t TXDMA:1;
927 uint16_t BRK13:1;
928 uint16_t TXDIR:1;
929 uint16_t BESM13:1;
930 uint16_t SBSTP:1;
931 uint16_t:1;
932 uint16_t PMSK:1;
933 uint16_t ORIE:1;
934 uint16_t NFIE:1;
935 uint16_t FEIE:1;
936 uint16_t PFIE:1;
937 } B;
938 } CR2; /* Control Register 2 */
939
941 uint16_t R;
942 struct {
943 uint16_t R8:1;
944 uint16_t T8:1;
945 uint16_t:6;
946 uint8_t D;
947 } B;
948 } DR; /* Data Register */
949
951 uint32_t R;
952 struct {
953 uint32_t TDRE:1;
954 uint32_t TC:1;
955 uint32_t RDRF:1;
956 uint32_t IDLE:1;
957 uint32_t OR:1;
958 uint32_t NF:1;
959 uint32_t FE:1;
960 uint32_t PF:1;
961 uint32_t:3;
962 uint32_t BERR:1;
963 uint32_t:3;
964 uint32_t RAF:1;
965 uint32_t RXRDY:1;
966 uint32_t TXRDY:1;
967 uint32_t LWAKE:1;
968 uint32_t STO:1;
969 uint32_t PBERR:1;
970 uint32_t CERR:1;
971 uint32_t CKERR:1;
972 uint32_t FRC:1;
973 uint32_t:6;
974 uint32_t UREQ:1;
975 uint32_t OVFL:1;
976 } B;
977 } SR; /* Status Register */
978
979 union {
980 uint32_t R;
981 struct {
982 uint32_t LRES:1;
983 uint32_t WU:1;
984 uint32_t WUD0:1;
985 uint32_t WUD1:1;
986 uint32_t LDBG:1;
987 uint32_t DSF:1;
988 uint32_t PRTY:1;
989 uint32_t LIN:1;
990 uint32_t RXIE:1;
991 uint32_t TXIE:1;
992 uint32_t WUIE:1;
993 uint32_t STIE:1;
994 uint32_t PBIE:1;
995 uint32_t CIE:1;
996 uint32_t CKIE:1;
997 uint32_t FCIE:1;
998 uint32_t:6;
999 uint32_t UQIE:1;
1000 uint32_t OFIE:1;
1001 uint32_t:8;
1002 } B;
1003 } LCR; /* LIN Control Register */
1004
1005 union {
1006 uint32_t R;
1007 } LTR; /* LIN Transmit Register */
1008
1009 union {
1010 uint32_t R;
1011 } LRR; /* LIN Recieve Register */
1012
1013 union {
1014 uint32_t R;
1015 } LPR; /* LIN CRC Polynom Register */
1016
1017 };
1018/****************************************************************************/
1019/* MODULE : FLASH */
1020/****************************************************************************/
1021 struct FLASH_tag {
1022 union { /* Module Configuration Register */
1023 uint32_t R;
1024 struct {
1025 uint32_t:3;
1026 uint32_t SFS:1;
1027 uint32_t SIZE:4;
1028 uint32_t:1;
1029 uint32_t LAS:3;
1030 uint32_t:3;
1031 uint32_t MAS:1;
1032 uint32_t EER:1;
1033 uint32_t RWE:1;
1034 uint32_t BBEPE:1;
1035 uint32_t EPE:1;
1036 uint32_t PEAS:1;
1037 uint32_t DONE:1;
1038 uint32_t PEG:1;
1039 uint32_t:1;
1040 uint32_t PRD:1;
1041 uint32_t STOP:1;
1042 uint32_t:1;
1043 uint32_t PGM:1;
1044 uint32_t PSUS:1;
1045 uint32_t ERS:1;
1046 uint32_t ESUS:1;
1047 uint32_t EHV:1;
1048 } B;
1049 } MCR;
1050
1051 union LMLR_tag { /* Low/Mid Address Space Block Locking Register */
1052 uint32_t R;
1053 struct {
1054 uint32_t LME:1;
1055 uint32_t:10;
1056 uint32_t SLOCK:1;
1057 uint32_t:2;
1058 uint32_t MLOCK:2;
1059 uint32_t:6;
1060 uint32_t LLOCK:10;
1061 } B;
1062 } LMLR; /* Legacy naming - refer to LML in Reference Manual */
1063
1064 union HLR_tag { /* High Address Space Block Locking Register */
1065 uint32_t R;
1066 struct {
1067 uint32_t HBE:1;
1068 uint32_t:23;
1069 uint32_t HBLOCK:8;
1070 } B;
1071 } HLR; /* Legacy naming - refer to HBL in Reference Manual */
1072
1073 union SLMLR_tag { /* Secondary Low/Mid Block Locking Register */
1074 uint32_t R;
1075 struct {
1076 uint32_t SLE:1;
1077 uint32_t:10;
1078 uint32_t SSLOCK:1;
1079 uint32_t:2;
1080 uint32_t SMLOCK:2;
1081 uint32_t:6;
1082 uint32_t SLLOCK:10;
1083 } B;
1084 } SLMLR; /* Legacy naming - refer to SLL in Reference Manual */
1085
1086 union { /* Low/Mid Address Space Block Select Register */
1087 uint32_t R;
1088 struct {
1089 uint32_t:14;
1090 uint32_t MSEL:2;
1091 uint32_t:6;
1092 uint32_t LSEL:10;
1093 } B;
1094 } LMSR; /* Legacy naming - refer to LMS in Reference Manual */
1095
1096 union { /* High Address Space Block Select Register */
1097 uint32_t R;
1098 struct {
1099 uint32_t:28;
1100 uint32_t HBSEL:4;
1101 } B;
1102 } HSR; /* Legacy naming - refer to HBS in Reference Manual */
1103
1104 union { /* Address Register */
1105 uint32_t R;
1106 struct {
1107 uint32_t:10;
1108 uint32_t ADDR:19;
1109 uint32_t:3;
1110 } B;
1111 } AR; /* Legacy naming - refer to ADR in Reference Manual */
1112
1113 union { /* Platform Flash Configuration Register for Port 0 */
1114 uint32_t R;
1115 struct {
1116 uint32_t LBCFG:4;
1117 uint32_t ARB:1;
1118 uint32_t PRI:1;
1119 uint32_t:5;
1120 uint32_t M4PFE:1;
1121 uint32_t M3PFE:1;
1122 uint32_t M2PFE:1;
1123 uint32_t M1PFE:1;
1124 uint32_t M0PFE:1;
1125 uint32_t APC:3;
1126 uint32_t WWSC:2;
1127 uint32_t RWSC:3;
1128 uint32_t:1;
1129 uint32_t DPFEN:1;
1130 uint32_t:1;
1131 uint32_t IPFEN:1;
1132 uint32_t:1;
1133 uint32_t PFLIM:2;
1134 uint32_t BFEN:1;
1135 } B;
1136 } PFCRP0;
1137
1138 union { /* Platform Flash Configuration Register for Port 1 */
1139 uint32_t R;
1140 struct {
1141 uint32_t LBCFG:4;
1142 uint32_t:7;
1143 uint32_t M4PFE:1;
1144 uint32_t M3PFE:1;
1145 uint32_t M2PFE:1;
1146 uint32_t M1PFE:1;
1147 uint32_t M0PFE:1;
1148 uint32_t APC:3;
1149 uint32_t WWSC:2;
1150 uint32_t RWSC:3;
1151 uint32_t:1;
1152 uint32_t DPFEN:1;
1153 uint32_t:1;
1154 uint32_t IPFEN:1;
1155 uint32_t:1;
1156 uint32_t PFLIM:2;
1157 uint32_t BFEN:1;
1158 } B;
1159 } PFCRP1;
1160
1161 };
1162/****************************************************************************/
1163/* MODULE : FlexCAN */
1164/****************************************************************************/
1166 union {
1167 uint32_t R;
1168 struct {
1169 uint32_t MDIS:1;
1170 uint32_t FRZ:1;
1171 uint32_t FEN:1;
1172 uint32_t HALT:1;
1173 uint32_t NOTRDY:1;
1174 uint32_t WAKMSK:1;
1175 uint32_t SOFTRST:1;
1176 uint32_t FRZACK:1;
1177 uint32_t SUPV:1;
1178 uint32_t SLFWAK:1;
1179 uint32_t WRNEN:1;
1180 uint32_t LPMACK:1;
1181 uint32_t WAKSRC:1;
1182 uint32_t DOZE:1;
1183 uint32_t SRXDIS:1;
1184 uint32_t BCC:1;
1185 uint32_t:2;
1186 uint32_t LPRIO_EN:1;
1187 uint32_t AEN:1;
1188 uint32_t:2;
1189 uint32_t IDAM:2;
1190 uint32_t:2;
1191 uint32_t MAXMB:6;
1192 } B;
1193 } MCR; /* Module Configuration Register */
1194
1195 union {
1196 uint32_t R;
1197 struct {
1198 uint32_t PRESDIV:8;
1199 uint32_t RJW:2;
1200 uint32_t PSEG1:3;
1201 uint32_t PSEG2:3;
1202 uint32_t BOFFMSK:1;
1203 uint32_t ERRMSK:1;
1204 uint32_t CLKSRC:1;
1205 uint32_t LPB:1;
1206 uint32_t TWRNMSK:1;
1207 uint32_t RWRNMSK:1;
1208 uint32_t:2;
1209 uint32_t SMP:1;
1210 uint32_t BOFFREC:1;
1211 uint32_t TSYN:1;
1212 uint32_t LBUF:1;
1213 uint32_t LOM:1;
1214 uint32_t PROPSEG:3;
1215 } B;
1216 } CTRL; /* Control Register */
1217
1218 union {
1219 uint32_t R;
1220 } TIMER; /* Free Running Timer */
1221
1222 uint32_t FLEXCAN_reserved1;
1223
1224 union {
1225 uint32_t R;
1226 struct {
1227 uint32_t MI:32;
1228 } B;
1229 } RXGMASK; /* RX Global Mask */
1230
1231 union {
1232 uint32_t R;
1233 struct {
1234 uint32_t MI:32;
1235 } B;
1236 } RX14MASK; /* RX 14 Mask */
1237
1238 union {
1239 uint32_t R;
1240 struct {
1241 uint32_t MI:32;
1242 } B;
1243 } RX15MASK; /* RX 15 Mask */
1244
1245 union {
1246 uint32_t R;
1247 struct {
1248 uint32_t:16;
1249 uint32_t RXECNT:8;
1250 uint32_t TXECNT:8;
1251 } B;
1252 } ECR; /* Error Counter Register */
1253
1254 union {
1255 uint32_t R;
1256 struct {
1257 uint32_t:14;
1258 uint32_t TWRNINT:1;
1259 uint32_t RWRNINT:1;
1260 uint32_t BIT1ERR:1;
1261 uint32_t BIT0ERR:1;
1262 uint32_t ACKERR:1;
1263 uint32_t CRCERR:1;
1264 uint32_t FRMERR:1;
1265 uint32_t STFERR:1;
1266 uint32_t TXWRN:1;
1267 uint32_t RXWRN:1;
1268 uint32_t IDLE:1;
1269 uint32_t TXRX:1;
1270 uint32_t FLTCONF:2;
1271 uint32_t:1;
1272 uint32_t BOFFINT:1;
1273 uint32_t ERRINT:1;
1274 uint32_t WAKINT:1;
1275 } B;
1276 } ESR; /* Error and Status Register */
1277
1278 union {
1279 uint32_t R;
1280 struct {
1281 uint32_t BUF63M:1;
1282 uint32_t BUF62M:1;
1283 uint32_t BUF61M:1;
1284 uint32_t BUF60M:1;
1285 uint32_t BUF59M:1;
1286 uint32_t BUF58M:1;
1287 uint32_t BUF57M:1;
1288 uint32_t BUF56M:1;
1289 uint32_t BUF55M:1;
1290 uint32_t BUF54M:1;
1291 uint32_t BUF53M:1;
1292 uint32_t BUF52M:1;
1293 uint32_t BUF51M:1;
1294 uint32_t BUF50M:1;
1295 uint32_t BUF49M:1;
1296 uint32_t BUF48M:1;
1297 uint32_t BUF47M:1;
1298 uint32_t BUF46M:1;
1299 uint32_t BUF45M:1;
1300 uint32_t BUF44M:1;
1301 uint32_t BUF43M:1;
1302 uint32_t BUF42M:1;
1303 uint32_t BUF41M:1;
1304 uint32_t BUF40M:1;
1305 uint32_t BUF39M:1;
1306 uint32_t BUF38M:1;
1307 uint32_t BUF37M:1;
1308 uint32_t BUF36M:1;
1309 uint32_t BUF35M:1;
1310 uint32_t BUF34M:1;
1311 uint32_t BUF33M:1;
1312 uint32_t BUF32M:1;
1313 } B;
1314 } IMASK2; /* Interruput Masks Register */
1315
1316 union {
1317 uint32_t R;
1318 struct {
1319 uint32_t BUF31M:1;
1320 uint32_t BUF30M:1;
1321 uint32_t BUF29M:1;
1322 uint32_t BUF28M:1;
1323 uint32_t BUF27M:1;
1324 uint32_t BUF26M:1;
1325 uint32_t BUF25M:1;
1326 uint32_t BUF24M:1;
1327 uint32_t BUF23M:1;
1328 uint32_t BUF22M:1;
1329 uint32_t BUF21M:1;
1330 uint32_t BUF20M:1;
1331 uint32_t BUF19M:1;
1332 uint32_t BUF18M:1;
1333 uint32_t BUF17M:1;
1334 uint32_t BUF16M:1;
1335 uint32_t BUF15M:1;
1336 uint32_t BUF14M:1;
1337 uint32_t BUF13M:1;
1338 uint32_t BUF12M:1;
1339 uint32_t BUF11M:1;
1340 uint32_t BUF10M:1;
1341 uint32_t BUF09M:1;
1342 uint32_t BUF08M:1;
1343 uint32_t BUF07M:1;
1344 uint32_t BUF06M:1;
1345 uint32_t BUF05M:1;
1346 uint32_t BUF04M:1;
1347 uint32_t BUF03M:1;
1348 uint32_t BUF02M:1;
1349 uint32_t BUF01M:1;
1350 uint32_t BUF00M:1;
1351 } B;
1352 } IMASK1; /* Interruput Masks Register */
1353
1354 union {
1355 uint32_t R;
1356 struct {
1357 uint32_t BUF63I:1;
1358 uint32_t BUF62I:1;
1359 uint32_t BUF61I:1;
1360 uint32_t BUF60I:1;
1361 uint32_t BUF59I:1;
1362 uint32_t BUF58I:1;
1363 uint32_t BUF57I:1;
1364 uint32_t BUF56I:1;
1365 uint32_t BUF55I:1;
1366 uint32_t BUF54I:1;
1367 uint32_t BUF53I:1;
1368 uint32_t BUF52I:1;
1369 uint32_t BUF51I:1;
1370 uint32_t BUF50I:1;
1371 uint32_t BUF49I:1;
1372 uint32_t BUF48I:1;
1373 uint32_t BUF47I:1;
1374 uint32_t BUF46I:1;
1375 uint32_t BUF45I:1;
1376 uint32_t BUF44I:1;
1377 uint32_t BUF43I:1;
1378 uint32_t BUF42I:1;
1379 uint32_t BUF41I:1;
1380 uint32_t BUF40I:1;
1381 uint32_t BUF39I:1;
1382 uint32_t BUF38I:1;
1383 uint32_t BUF37I:1;
1384 uint32_t BUF36I:1;
1385 uint32_t BUF35I:1;
1386 uint32_t BUF34I:1;
1387 uint32_t BUF33I:1;
1388 uint32_t BUF32I:1;
1389 } B;
1390 } IFLAG2; /* Interruput Flag Register */
1391
1392 union {
1393 uint32_t R;
1394 struct {
1395 uint32_t BUF31I:1;
1396 uint32_t BUF30I:1;
1397 uint32_t BUF29I:1;
1398 uint32_t BUF28I:1;
1399 uint32_t BUF27I:1;
1400 uint32_t BUF26I:1;
1401 uint32_t BUF25I:1;
1402 uint32_t BUF24I:1;
1403 uint32_t BUF23I:1;
1404 uint32_t BUF22I:1;
1405 uint32_t BUF21I:1;
1406 uint32_t BUF20I:1;
1407 uint32_t BUF19I:1;
1408 uint32_t BUF18I:1;
1409 uint32_t BUF17I:1;
1410 uint32_t BUF16I:1;
1411 uint32_t BUF15I:1;
1412 uint32_t BUF14I:1;
1413 uint32_t BUF13I:1;
1414 uint32_t BUF12I:1;
1415 uint32_t BUF11I:1;
1416 uint32_t BUF10I:1;
1417 uint32_t BUF09I:1;
1418 uint32_t BUF08I:1;
1419 uint32_t BUF07I:1;
1420 uint32_t BUF06I:1;
1421 uint32_t BUF05I:1;
1422 uint32_t BUF04I:1;
1423 uint32_t BUF03I:1;
1424 uint32_t BUF02I:1;
1425 uint32_t BUF01I:1;
1426 uint32_t BUF00I:1;
1427 } B;
1428 } IFLAG1; /* Interruput Flag Register */
1429
1430 uint32_t FLEXCAN_reserved2[19];
1431
1432 struct canbuf_t {
1433 union {
1434 uint32_t R;
1435 struct {
1436 uint32_t:4;
1437 uint32_t CODE:4;
1438 uint32_t:1;
1439 uint32_t SRR:1;
1440 uint32_t IDE:1;
1441 uint32_t RTR:1;
1442 uint32_t LENGTH:4;
1443 uint32_t TIMESTAMP:16;
1444 } B;
1445 } CS;
1446
1447 union {
1448 uint32_t R;
1449 struct {
1450 uint32_t PRIO:3;
1451 uint32_t STD_ID:11;
1452 uint32_t EXT_ID:18;
1453 } B;
1454 } ID;
1455
1456 union {
1457 uint8_t B[8]; /* Data buffer in Bytes (8 bits) */
1458 uint16_t H[4]; /* Data buffer in Half-words (16 bits) */
1459 uint32_t W[2]; /* Data buffer in words (32 bits) */
1460 uint32_t R[2]; /* Data buffer in words (32 bits) */
1461 } DATA;
1462
1463 } BUF[64];
1464
1465 uint32_t FLEXCAN_reserved3[256];
1466
1467 union {
1468 uint32_t R;
1469 struct {
1470 uint32_t MI:32;
1471 } B;
1472 } RXIMR[64]; /* RX Individual Mask Registers */
1473
1474 };
1475/****************************************************************************/
1476/* MODULE : FMPLL */
1477/****************************************************************************/
1478 struct FMPLL_tag {
1479
1480 uint32_t FMPLL_reserved0;
1481
1482 union FMPLL_SYNSR_tag { /* Synthesiser Status Register */
1483 uint32_t R;
1484 struct {
1485 uint32_t:22;
1486 uint32_t LOLF:1;
1487 uint32_t LOC:1;
1488 uint32_t MODE:1;
1489 uint32_t PLLSEL:1;
1490 uint32_t PLLREF:1;
1491 uint32_t LOCKS:1;
1492 uint32_t LOCK:1;
1493 uint32_t LOCF:1;
1494 uint32_t CALDONE:1;
1495 uint32_t CALPASS:1;
1496 } B;
1497 } SYNSR;
1498
1500 uint32_t R;
1501 struct {
1502 uint32_t:1;
1503 uint32_t CLKCFG:3;
1504 uint32_t:8;
1505 uint32_t EPREDIV:4;
1506 uint32_t:8;
1507 uint32_t EMFD:8;
1508 } B;
1509 } ESYNCR1;
1510
1512 uint32_t R;
1513 struct {
1514 uint32_t:8;
1515 uint32_t LOCEN:1;
1516 uint32_t LOLRE:1;
1517 uint32_t LOCRE:1;
1518 uint32_t LOLIRQ:1;
1519 uint32_t LOCIRQ:1;
1520 uint32_t:1;
1521 uint32_t ERATE:2;
1522 uint32_t:5;
1523 uint32_t EDEPTH:3;
1524 uint32_t:2;
1525 uint32_t ERFD:6;
1526 } B;
1527 } ESYNCR2;
1528
1529 };
1530/****************************************************************************/
1531/* MODULE : i2c */
1532/****************************************************************************/
1533 struct I2C_tag {
1534 union {
1535 uint8_t R;
1536 struct {
1537 uint8_t AD:7;
1538 uint8_t:1;
1539 } B;
1540 } IBAD; /* Module Bus Address Register */
1541
1542 union {
1543 uint8_t R;
1544 struct {
1545 uint8_t MULT:2;
1546 uint8_t ICR:6;
1547 } B;
1548 } IBFD; /* Module Bus Frequency Register */
1549
1550 union {
1551 uint8_t R;
1552 struct {
1553 uint8_t MDIS:1;
1554 uint8_t IBIE:1;
1555 uint8_t MS:1;
1556 uint8_t TX:1;
1557 uint8_t NOACK:1;
1558 uint8_t RSTA:1;
1559 uint8_t DMAEN:1;
1560 uint8_t:1;
1561 } B;
1562 } IBCR; /* Module Bus Control Register */
1563
1564 union {
1565 uint8_t R;
1566 struct {
1567 uint8_t TCF:1;
1568 uint8_t IAAS:1;
1569 uint8_t IBB:1;
1570 uint8_t IBAL:1;
1571 uint8_t:1;
1572 uint8_t SRW:1;
1573 uint8_t IBIF:1;
1574 uint8_t RXAK:1;
1575 } B;
1576 } IBSR; /* Module Status Register */
1577
1578 union {
1579 uint8_t R;
1580 struct {
1581 uint8_t DATA:8;
1582 } B;
1583 } IBDR; /* Module Data Register */
1584
1585 union {
1586 uint8_t R;
1587 struct {
1588 uint8_t BIIE:1;
1589 uint8_t:7;
1590 } B;
1591 } IBIC; /* Module Interrupt Configuration Register */
1592
1593 };
1594/****************************************************************************/
1595/* MODULE : INTC */
1596/****************************************************************************/
1597 struct INTC_tag {
1598 union {
1599 uint32_t R;
1600 struct {
1601 uint32_t:18;
1602 uint32_t VTES_PRC1:1;
1603 uint32_t:4;
1604 uint32_t HVEN_PRC1:1;
1605 uint32_t:2;
1606 uint32_t VTES:1;
1607 uint32_t:4;
1608 uint32_t HVEN:1;
1609 } B;
1610 } MCR; /* Module Configuration Register */
1611
1612 int32_t INTC_reserved1;
1613
1614 union {
1615 uint32_t R;
1616 struct {
1617 uint32_t:28;
1618 uint32_t PRI:4;
1619 } B;
1620 } CPR; /* Processor 0 Current Priority Register */
1621
1622 union {
1623 uint32_t R;
1624 struct {
1625 uint32_t:28;
1626 uint32_t PRI:4;
1627 } B;
1628 } CPR_PRC1; /* Processor 1 Current Priority Register */
1629
1630 union {
1631 uint32_t R;
1632 struct {
1633 uint32_t VTBA:21;
1634 uint32_t INTVEC:9;
1635 uint32_t:2;
1636 } B;
1637 } IACKR; /* Processor 0 Interrupt Acknowledge Register */
1638
1639 union {
1640 uint32_t R;
1641 struct {
1642 uint32_t VTBA_PRC1:21;
1643 uint32_t INTVEC_PRC1:9;
1644 uint32_t:2;
1645 } B;
1646 } IACKR_PRC1; /* Processor 1 Interrupt Acknowledge Register */
1647
1648 union {
1649 uint32_t R;
1650 struct {
1651 uint32_t:32;
1652 } B;
1653 } EOIR; /* Processor 0 End of Interrupt Register */
1654
1655 union {
1656 uint32_t R;
1657 struct {
1658 uint32_t:32;
1659 } B;
1660 } EOIR_PRC1; /* Processor 1 End of Interrupt Register */
1661
1662 union {
1663 uint8_t R;
1664 struct {
1665 uint8_t:6;
1666 uint8_t SET:1;
1667 uint8_t CLR:1;
1668 } B;
1669 } SSCIR[8]; /* Software Set/Clear Interruput Register */
1670
1671 uint32_t intc_reserved2[6];
1672
1673 union {
1674 uint8_t R;
1675 struct {
1676 uint8_t PRC_SEL:2;
1677 uint8_t:2;
1678 uint8_t PRI:4;
1679 } B;
1680 } PSR[294]; /* Software Set/Clear Interrupt Register */
1681
1682 };
1683/****************************************************************************/
1684/* MODULE : MCM */
1685/****************************************************************************/
1686 struct MCM_tag {
1687
1688 uint32_t mcm_reserved1[5];
1689
1690 uint16_t mcm_reserved2;
1691
1692 union {
1693 uint16_t R;
1694 struct {
1695 uint16_t RO:1;
1696 uint16_t:6;
1697 uint16_t SWRWH:1;
1698 uint16_t SWE:1;
1699 uint16_t SWRI:2;
1700 uint16_t SWT:5;
1701 } B;
1702 } SWTCR; /* Software Watchdog Timer Control */
1703
1704 uint8_t mcm_reserved3[3];
1705
1706 union {
1707 uint8_t R;
1708 } SWTSR; /* SWT Service Register */
1709
1710 uint8_t mcm_reserved4[3];
1711
1712 union {
1713 uint8_t R;
1714 struct {
1715 uint8_t:7;
1716 uint8_t SWTIC:1;
1717 } B;
1718 } SWTIR; /* SWT Interrupt Register */
1719
1720 uint32_t mcm_reserved5[1];
1721
1722 union {
1723 uint32_t R;
1724 struct {
1725 uint32_t PRI:1;
1726 uint32_t:31;
1727 } B;
1728 } MUDCR; /* Misc. User Defined Control Register */
1729
1730 uint32_t mcm_reserved6[6];
1731 uint8_t mcm_reserved7[3];
1732
1733 union {
1734 uint8_t R;
1735 struct {
1736 uint8_t:6;
1737 uint8_t ERNCR:1;
1738 uint8_t EFNCR:1;
1739 } B;
1740 } ECR; /* ECC Configuration Register */
1741
1742 uint8_t mcm_reserved8[3];
1743
1744 union {
1745 uint8_t R;
1746 struct {
1747 uint8_t:6;
1748 uint8_t RNCE:1;
1749 uint8_t FNCE:1;
1750 } B;
1751 } ESR; /* ECC Status Register */
1752
1753 uint16_t mcm_reserved9;
1754
1755 union {
1756 uint16_t R;
1757 struct {
1758 uint16_t:6;
1759 uint16_t FRCNCI:1;
1760 uint16_t FR1NCI:1;
1761 uint16_t:1;
1762 uint16_t ERRBIT:7;
1763 } B;
1764 } EEGR; /* ECC Error Generation Register */
1765
1766 uint32_t mcm_reserved10;
1767
1768 union {
1769 uint32_t R;
1770 } FEAR; /* Flash ECC Address Register */
1771
1772 uint16_t mcm_reserved11;
1773
1774 union {
1775 uint8_t R;
1776 struct {
1777 uint8_t:4;
1778 uint8_t FEMR:4;
1779 } B;
1780 } FEMR; /* Flash ECC Master Register */
1781
1782 union {
1783 uint8_t R;
1784 struct {
1785 uint8_t WRITE:1;
1786 uint8_t SIZE:3;
1787 uint8_t PROTECTION:4;
1788 } B;
1789 } FEAT; /* Flash ECC Attributes Register */
1790
1791 union {
1792 uint32_t R;
1793 } FEDRH; /* Flash ECC Data High Register */
1794
1795 union {
1796 uint32_t R;
1797 } FEDRL; /* Flash ECC Data Low Register */
1798
1799 union {
1800 uint32_t R;
1801 struct {
1802 uint32_t REAR:32;
1803 } B;
1804 } REAR; /* RAM ECC Address */
1805
1806 uint16_t mcm_reserved12;
1807
1808 union {
1809 uint8_t R;
1810 struct {
1811 uint8_t:4;
1812 uint8_t REMR:4;
1813 } B;
1814 } REMR; /* RAM ECC Master */
1815
1816 union {
1817 uint8_t R;
1818 struct {
1819 uint8_t WRITE:1;
1820 uint8_t SIZE:3;
1821 uint8_t PROTECTION:4;
1822 } B;
1823 } REAT; /* RAM ECC Attributes Register */
1824
1825 union {
1826 uint32_t R;
1827 } REDRH; /* RAM ECC Data High Register */
1828
1829 union {
1830 uint32_t R;
1831 } REDRL; /* RAMECC Data Low Register */
1832
1833 };
1834/****************************************************************************/
1835/* MODULE : MPU */
1836/****************************************************************************/
1837 struct MPU_tag {
1838 union {
1839 uint32_t R;
1840 struct {
1841 uint32_t SPERR:8;
1842 uint32_t:4;
1843 uint32_t HRL:4;
1844 uint32_t NSP:4;
1845 uint32_t NGRD:4;
1846 uint32_t:7;
1847 uint32_t VLD:1;
1848 } B;
1849 } CESR; /* Module Control/Error Status Register */
1850
1851 uint32_t mpu_reserved1[3];
1852
1853 union {
1854 uint32_t R;
1855 struct {
1856 uint32_t EADDR:32;
1857 } B;
1858 } EAR0;
1859
1860 union {
1861 uint32_t R;
1862 struct {
1863 uint32_t EACD:16;
1864 uint32_t EPID:8;
1865 uint32_t EMN:4;
1866 uint32_t EATTR:3;
1867 uint32_t ERW:1;
1868 } B;
1869 } EDR0;
1870
1871 union {
1872 uint32_t R;
1873 struct {
1874 uint32_t EADDR:32;
1875 } B;
1876 } EAR1;
1877
1878 union {
1879 uint32_t R;
1880 struct {
1881 uint32_t EACD:16;
1882 uint32_t EPID:8;
1883 uint32_t EMN:4;
1884 uint32_t EATTR:3;
1885 uint32_t ERW:1;
1886 } B;
1887 } EDR1;
1888
1889 union {
1890 uint32_t R;
1891 struct {
1892 uint32_t EADDR:32;
1893 } B;
1894 } EAR2;
1895
1896 union {
1897 uint32_t R;
1898 struct {
1899 uint32_t EACD:16;
1900 uint32_t EPID:8;
1901 uint32_t EMN:4;
1902 uint32_t EATTR:3;
1903 uint32_t ERW:1;
1904 } B;
1905 } EDR2;
1906
1907 uint32_t mpu_reserved2[246];
1908
1909 struct {
1910 union {
1911 uint32_t R;
1912 struct {
1913 uint32_t SRTADDR:27;
1914 uint32_t:5;
1915 } B;
1916 } WORD0; /* Region Descriptor n Word 0 */
1917
1918 union {
1919 uint32_t R;
1920 struct {
1921 uint32_t ENDADDR:27;
1922 uint32_t:5;
1923 } B;
1924 } WORD1; /* Region Descriptor n Word 1 */
1925
1926 union {
1927 uint32_t R;
1928 struct {
1929 uint32_t:6;
1930 uint32_t M4RE0:1;
1931 uint32_t M4WE:1;
1932 uint32_t M3PE:1;
1933 uint32_t M3SM:2;
1934 uint32_t M3UM:3;
1935 uint32_t M2PE:1;
1936 uint32_t M2SM:2;
1937 uint32_t M2UM:3;
1938 uint32_t M1PE:1;
1939 uint32_t M1SM:2;
1940 uint32_t M1UM:3;
1941 uint32_t M0PE:1;
1942 uint32_t M0SM:2;
1943 uint32_t M0UM:3;
1944 } B;
1945 } WORD2; /* Region Descriptor n Word 2 */
1946
1947 union {
1948 uint32_t R;
1949 struct {
1950 uint32_t PID:8;
1951 uint32_t PIDMASK:8;
1952 uint32_t:15;
1953 uint32_t VLD:1;
1954 } B;
1955 } WORD3; /* Region Descriptor n Word 3 */
1956
1957 } RGD[16];
1958
1959 uint32_t mpu_reserved3[192];
1960
1961 union {
1962 uint32_t R;
1963 struct {
1964 uint32_t:6;
1965 uint32_t M4RE:1;
1966 uint32_t M4WE:1;
1967 uint32_t M3PE:1;
1968 uint32_t M3SM:2;
1969 uint32_t M3UM:3;
1970 uint32_t M2PE:1;
1971 uint32_t M2SM:2;
1972 uint32_t M2UM:3;
1973 uint32_t M1PE:1;
1974 uint32_t M1SM:2;
1975 uint32_t M1UM:3;
1976 uint32_t M0PE:1;
1977 uint32_t M0SM:2;
1978 uint32_t M0UM:3;
1979 } B;
1980 } RGDAAC[16]; /* Region Descriptor Alternate Access Control n */
1981 };
1982/****************************************************************************/
1983/* MODULE : pit */
1984/****************************************************************************/
1985 struct PIT_tag {
1986 union {
1987 uint32_t R;
1988 struct {
1989 uint32_t TSV:32;
1990 } B;
1991 } TLVAL[9];
1992
1993 uint32_t pit_reserved1[23];
1994
1995 union {
1996 uint32_t R;
1997 struct {
1998 uint32_t TVL:32;
1999 } B;
2000 } TVAL[9];
2001
2002 uint32_t pit_reserved2[23];
2003
2004 union {
2005 uint32_t R;
2006 struct {
2007 uint32_t:23;
2008 uint32_t TIF8:1;
2009 uint32_t TIF7:1;
2010 uint32_t TIF6:1;
2011 uint32_t TIF5:1;
2012 uint32_t TIF4:1;
2013 uint32_t TIF3:1;
2014 uint32_t TIF2:1;
2015 uint32_t TIF1:1;
2016 uint32_t RTIF:1;
2017 } B;
2018 } PITFLG;
2019
2020 union {
2021 uint32_t R;
2022 struct {
2023 uint32_t:23;
2024 uint32_t TIE8:1;
2025 uint32_t TIE7:1;
2026 uint32_t TIE6:1;
2027 uint32_t TIE5:1;
2028 uint32_t TIE4:1;
2029 uint32_t TIE3:1;
2030 uint32_t TIE2:1;
2031 uint32_t TIE1:1;
2032 uint32_t RTIE:1;
2033 } B;
2034 } PITINTEN;
2035
2036 union {
2037 uint32_t R;
2038 struct {
2039 uint32_t:23;
2040 uint32_t ISEL8:1;
2041 uint32_t ISEL7:1;
2042 uint32_t ISEL6:1;
2043 uint32_t ISEL5:1;
2044 uint32_t ISEL4:1;
2045 uint32_t ISEL3:1;
2046 uint32_t ISEL2:1;
2047 uint32_t ISEL1:1;
2048 uint32_t:1;
2049 } B;
2050 } PITINTSEL;
2051
2052 union {
2053 uint32_t R;
2054 struct {
2055 uint32_t:23;
2056 uint32_t PEN8:1;
2057 uint32_t PEN7:1;
2058 uint32_t PEN6:1;
2059 uint32_t PEN5:1;
2060 uint32_t PEN4:1;
2061 uint32_t PEN3:1;
2062 uint32_t PEN2:1;
2063 uint32_t PEN1:1;
2064 uint32_t PEN0:1;
2065 } B;
2066 } PITEN;
2067
2068 union {
2069 uint32_t R;
2070 struct {
2071 uint32_t:7;
2072 uint32_t MDIS:1;
2073 uint32_t:24;
2074 } B;
2075 } PITCTRL;
2076
2077 };
2078/****************************************************************************/
2079/* MODULE : sem4 */
2080/****************************************************************************/
2081 struct SEMA4_tag {
2082 union {
2083 uint8_t R;
2084 struct {
2085 uint8_t:6;
2086 uint8_t GTFSM:2;
2087 } B;
2088 } GATE[16]; /* Gate n Register */
2089
2090 uint32_t sema4_reserved1[12]; /* {0x40-0x10}/4 = 0x0C */
2091
2092 union {
2093 uint16_t R;
2094 struct {
2095 uint16_t INE0:1;
2096 uint16_t INE1:1;
2097 uint16_t INE2:1;
2098 uint16_t INE3:1;
2099 uint16_t INE4:1;
2100 uint16_t INE5:1;
2101 uint16_t INE6:1;
2102 uint16_t INE7:1;
2103 uint16_t INE8:1;
2104 uint16_t INE9:1;
2105 uint16_t INE10:1;
2106 uint16_t INE11:1;
2107 uint16_t INE12:1;
2108 uint16_t INE13:1;
2109 uint16_t INE14:1;
2110 uint16_t INE15:1;
2111 } B;
2112 } CP0INE;
2113
2114 uint16_t sema4_reserved2[3]; /* {0x48-0x42}/2 = 0x03 */
2115
2116 union {
2117 uint16_t R;
2118 struct {
2119 uint16_t INE0:1;
2120 uint16_t INE1:1;
2121 uint16_t INE2:1;
2122 uint16_t INE3:1;
2123 uint16_t INE4:1;
2124 uint16_t INE5:1;
2125 uint16_t INE6:1;
2126 uint16_t INE7:1;
2127 uint16_t INE8:1;
2128 uint16_t INE9:1;
2129 uint16_t INE10:1;
2130 uint16_t INE11:1;
2131 uint16_t INE12:1;
2132 uint16_t INE13:1;
2133 uint16_t INE14:1;
2134 uint16_t INE15:1;
2135 } B;
2136 } CP1INE;
2137
2138 uint16_t sema4_reserved3[27]; /* {0x80-0x4A}/2 = 0x1B */
2139
2140 union {
2141 uint16_t R;
2142 struct {
2143 uint16_t GN0:1;
2144 uint16_t GN1:1;
2145 uint16_t GN2:1;
2146 uint16_t GN3:1;
2147 uint16_t GN4:1;
2148 uint16_t GN5:1;
2149 uint16_t GN6:1;
2150 uint16_t GN7:1;
2151 uint16_t GN8:1;
2152 uint16_t GN9:1;
2153 uint16_t GN10:1;
2154 uint16_t GN11:1;
2155 uint16_t GN12:1;
2156 uint16_t GN13:1;
2157 uint16_t GN14:1;
2158 uint16_t GN15:1;
2159 } B;
2160 } CP0NTF;
2161
2162 uint16_t sema4_reserved4[3]; /* {0x88-0x82}/2 = 0x03 */
2163
2164 union {
2165 uint16_t R;
2166 struct {
2167 uint16_t GN0:1;
2168 uint16_t GN1:1;
2169 uint16_t GN2:1;
2170 uint16_t GN3:1;
2171 uint16_t GN4:1;
2172 uint16_t GN5:1;
2173 uint16_t GN6:1;
2174 uint16_t GN7:1;
2175 uint16_t GN8:1;
2176 uint16_t GN9:1;
2177 uint16_t GN10:1;
2178 uint16_t GN11:1;
2179 uint16_t GN12:1;
2180 uint16_t GN13:1;
2181 uint16_t GN14:1;
2182 uint16_t GN15:1;
2183 } B;
2184 } CP1NTF;
2185
2186 uint16_t sema4_reserved5[59]; /* {0x100-0x8A}/2 = 0x3B */
2187
2188 union {
2189 uint16_t R;
2190 struct {
2191 uint16_t:2;
2192 uint16_t RSTGSM:2;
2193 uint16_t:1;
2194 uint16_t RSTGMS:3;
2195 uint16_t RSTGTN:8;
2196 } B;
2197 } RSTGT;
2198
2199 uint16_t sema4_reserved6;
2200
2201 union {
2202 uint16_t R;
2203 struct {
2204 uint16_t:2;
2205 uint16_t RSTNSM:2;
2206 uint16_t:1;
2207 uint16_t RSTNMS:3;
2208 uint16_t RSTNTN:8;
2209 } B;
2210 } RSTNTF;
2211 };
2212/****************************************************************************/
2213/* MODULE : SIU */
2214/****************************************************************************/
2215 struct SIU_tag {
2216
2217 int32_t SIU_reserved0;
2218
2219 union { /* MCU ID Register */
2220 uint32_t R;
2221 struct {
2222 uint32_t PARTNUM:16;
2223 uint32_t CSP:1;
2224 uint32_t PKG:5;
2225 uint32_t:2;
2226 uint32_t MASKNUM_MAJOR:4;
2227 uint32_t MASKNUM_MINOR:4;
2228 } B;
2229 } MIDR;
2230
2231 int32_t SIU_reserved1;
2232
2233 union { /* Reset Status Register */
2234 uint32_t R;
2235 struct {
2236 uint32_t PORS:1;
2237 uint32_t ERS:1;
2238 uint32_t LLRS:1;
2239 uint32_t LCRS:1;
2240 uint32_t WDRS:1;
2241 uint32_t CRS:1;
2242 uint32_t:8;
2243 uint32_t SSRS:1;
2244 uint32_t:15;
2245 uint32_t BOOTCFG:1;
2246 uint32_t:1;
2247 } B;
2248 } RSR;
2249
2250 union { /* System Reset Control Register */
2251 uint32_t R;
2252 struct {
2253 uint32_t SSR:1;
2254 uint32_t:15;
2255 uint32_t CRE0:1;
2256 uint32_t CRE1:1;
2257 uint32_t:6;
2258 uint32_t SSRL:1;
2259 uint32_t:7;
2260 } B;
2261 } SRCR;
2262
2263 union SIU_EISR_tag { /* External Interrupt Status Register */
2264 uint32_t R;
2265 struct {
2266 uint32_t NMI0:1;
2267 uint32_t NMI1:1;
2268 uint32_t:14;
2269 uint32_t EIF15:1;
2270 uint32_t EIF14:1;
2271 uint32_t EIF13:1;
2272 uint32_t EIF12:1;
2273 uint32_t EIF11:1;
2274 uint32_t EIF10:1;
2275 uint32_t EIF9:1;
2276 uint32_t EIF8:1;
2277 uint32_t EIF7:1;
2278 uint32_t EIF6:1;
2279 uint32_t EIF5:1;
2280 uint32_t EIF4:1;
2281 uint32_t EIF3:1;
2282 uint32_t EIF2:1;
2283 uint32_t EIF1:1;
2284 uint32_t EIF0:1;
2285 } B;
2286 } EISR;
2287
2288 union SIU_DIRER_tag { /* DMA/Interrupt Request Enable Register */
2289 uint32_t R;
2290 struct {
2291 uint32_t:16;
2292 uint32_t EIRE15:1;
2293 uint32_t EIRE14:1;
2294 uint32_t EIRE13:1;
2295 uint32_t EIRE12:1;
2296 uint32_t EIRE11:1;
2297 uint32_t EIRE10:1;
2298 uint32_t EIRE9:1;
2299 uint32_t EIRE8:1;
2300 uint32_t EIRE7:1;
2301 uint32_t EIRE6:1;
2302 uint32_t EIRE5:1;
2303 uint32_t EIRE4:1;
2304 uint32_t EIRE3:1;
2305 uint32_t EIRE2:1;
2306 uint32_t EIRE1:1;
2307 uint32_t EIRE0:1;
2308 } B;
2309 } DIRER;
2310
2311 union SIU_DIRSR_tag { /* DMA/Interrupt Select Register */
2312 uint32_t R;
2313 struct {
2314 uint32_t:27;
2315 uint32_t DIRS4:1;
2316 uint32_t DIRS3:1;
2317 uint32_t DIRS2:1;
2318 uint32_t DIRS1:1;
2319 uint32_t:1;
2320 } B;
2321 } DIRSR;
2322
2323 union { /* Overrun Status Register */
2324 uint32_t R;
2325 struct {
2326 uint32_t:16;
2327 uint32_t OVF15:1;
2328 uint32_t OVF14:1;
2329 uint32_t OVF13:1;
2330 uint32_t OVF12:1;
2331 uint32_t OVF11:1;
2332 uint32_t OVF10:1;
2333 uint32_t OVF9:1;
2334 uint32_t OVF8:1;
2335 uint32_t OVF7:1;
2336 uint32_t OVF6:1;
2337 uint32_t OVF5:1;
2338 uint32_t OVF4:1;
2339 uint32_t OVF3:1;
2340 uint32_t OVF2:1;
2341 uint32_t OVF1:1;
2342 uint32_t OVF0:1;
2343 } B;
2344 } OSR;
2345
2346 union SIU_ORER_tag { /* Overrun Request Enable Register */
2347 uint32_t R;
2348 struct {
2349 uint32_t:16;
2350 uint32_t ORE15:1;
2351 uint32_t ORE14:1;
2352 uint32_t ORE13:1;
2353 uint32_t ORE12:1;
2354 uint32_t ORE11:1;
2355 uint32_t ORE10:1;
2356 uint32_t ORE9:1;
2357 uint32_t ORE8:1;
2358 uint32_t ORE7:1;
2359 uint32_t ORE6:1;
2360 uint32_t ORE5:1;
2361 uint32_t ORE4:1;
2362 uint32_t ORE3:1;
2363 uint32_t ORE2:1;
2364 uint32_t ORE1:1;
2365 uint32_t ORE0:1;
2366 } B;
2367 } ORER;
2368
2369 union SIU_IREER_tag { /* External IRQ Rising-Edge Event Enable Register */
2370 uint32_t R;
2371 struct {
2372 uint32_t NREE0:1;
2373 uint32_t NREE1:1;
2374 uint32_t:14;
2375 uint32_t IREE15:1;
2376 uint32_t IREE14:1;
2377 uint32_t IREE13:1;
2378 uint32_t IREE12:1;
2379 uint32_t IREE11:1;
2380 uint32_t IREE10:1;
2381 uint32_t IREE9:1;
2382 uint32_t IREE8:1;
2383 uint32_t IREE7:1;
2384 uint32_t IREE6:1;
2385 uint32_t IREE5:1;
2386 uint32_t IREE4:1;
2387 uint32_t IREE3:1;
2388 uint32_t IREE2:1;
2389 uint32_t IREE1:1;
2390 uint32_t IREE0:1;
2391 } B;
2392 } IREER;
2393
2394 union SIU_IFEER_tag { /* External IRQ Falling-Edge Event Enable Register */
2395 uint32_t R;
2396 struct {
2397 uint32_t NFEE0:1;
2398 uint32_t NFEE1:1;
2399 uint32_t:14;
2400 uint32_t IFEE15:1;
2401 uint32_t IFEE14:1;
2402 uint32_t IFEE13:1;
2403 uint32_t IFEE12:1;
2404 uint32_t IFEE11:1;
2405 uint32_t IFEE10:1;
2406 uint32_t IFEE9:1;
2407 uint32_t IFEE8:1;
2408 uint32_t IFEE7:1;
2409 uint32_t IFEE6:1;
2410 uint32_t IFEE5:1;
2411 uint32_t IFEE4:1;
2412 uint32_t IFEE3:1;
2413 uint32_t IFEE2:1;
2414 uint32_t IFEE1:1;
2415 uint32_t IFEE0:1;
2416 } B;
2417 } IFEER;
2418
2419 union SIU_IDFR_tag { /* External IRQ Digital Filter Register */
2420 uint32_t R;
2421 struct {
2422 uint32_t:28;
2423 uint32_t DFL:4;
2424 } B;
2425 } IDFR;
2426
2427 union { /* External IRQ Filtered Input Register */
2428 uint32_t R;
2429 struct {
2430 uint32_t FNMI0:1;
2431 uint32_t FNMI1:1;
2432 uint32_t:14;
2433 uint32_t FI15:1;
2434 uint32_t FI14:1;
2435 uint32_t FI13:1;
2436 uint32_t FI12:1;
2437 uint32_t FI11:1;
2438 uint32_t FI10:1;
2439 uint32_t FI9:1;
2440 uint32_t FI8:1;
2441 uint32_t FI7:1;
2442 uint32_t FI6:1;
2443 uint32_t FI5:1;
2444 uint32_t FI4:1;
2445 uint32_t FI3:1;
2446 uint32_t FI2:1;
2447 uint32_t FI1:1;
2448 uint32_t FI0:1;
2449 } B;
2450 } IFIR;
2451
2452 int32_t SIU_reserved2[2];
2453
2454 union SIU_PCR_tag { /* Pad Configuration Registers */
2455 uint16_t R;
2456 struct {
2457 uint16_t:4;
2458 uint16_t PA:2;
2459 uint16_t OBE:1;
2460 uint16_t IBE:1;
2461 uint16_t:2;
2462 uint16_t ODE:1;
2463 uint16_t HYS:1;
2464 uint16_t SRC:2;
2465 uint16_t WPE:1;
2466 uint16_t WPS:1;
2467 } B;
2468 } PCR[146];
2469
2470 int32_t SIU_reserved3[295];
2471
2472 union { /* GPIO Pin Data Output Registers */
2473 uint8_t R;
2474 struct {
2475 uint8_t:7;
2476 uint8_t PDO:1;
2477 } B;
2478 } GPDO[146];
2479
2480 int32_t SIU_reserved4[91];
2481
2482 union { /* GPIO Pin Data Input Registers */
2483 uint8_t R;
2484 struct {
2485 uint8_t:7;
2486 uint8_t PDI:1;
2487 } B;
2488 } GPDI[146];
2489
2490 int32_t SIU_reserved5[27];
2491
2492 union { /* IMUX Register */
2493 uint32_t R;
2494 struct {
2495 uint32_t TSEL3:2;
2496 uint32_t TSEL2:2;
2497 uint32_t TSEL1:2;
2498 uint32_t TSEL0:2;
2499 uint32_t:24;
2500 } B;
2501 } ISEL0;
2502
2503 union { /* IMUX Register */
2504 uint32_t R;
2505 struct {
2506 uint32_t ESEL15:2;
2507 uint32_t ESEL14:2;
2508 uint32_t ESEL13:2;
2509 uint32_t ESEL12:2;
2510 uint32_t ESEL11:2;
2511 uint32_t ESEL10:2;
2512 uint32_t ESEL9:2;
2513 uint32_t ESEL8:2;
2514 uint32_t ESEL7:2;
2515 uint32_t ESEL6:2;
2516 uint32_t ESEL5:2;
2517 uint32_t ESEL4:2;
2518 uint32_t ESEL3:2;
2519 uint32_t ESEL2:2;
2520 uint32_t ESEL1:2;
2521 uint32_t ESEL0:2;
2522 } B;
2523 } ISEL1;
2524
2525 union { /* IMUX Register */
2526 uint32_t R;
2527 struct {
2528 uint32_t SELEMIOS15:2;
2529 uint32_t SELEMIOS14:2;
2530 uint32_t SELEMIOS13:2;
2531 uint32_t SELEMIOS12:2;
2532 uint32_t SELEMIOS11:2;
2533 uint32_t SELEMIOS10:2;
2534 uint32_t SELEMIOS9:2;
2535 uint32_t SELEMIOS8:2;
2536 uint32_t SELEMIOS7:2;
2537 uint32_t SELEMIOS6:2;
2538 uint32_t SELEMIOS5:2;
2539 uint32_t SELEMIOS4:2;
2540 uint32_t SELEMIOS3:2;
2541 uint32_t SELEMIOS2:2;
2542 uint32_t SELEMIOS1:2;
2543 uint32_t SELEMIOS0:2;
2544 } B;
2545 } ISEL2;
2546
2547 int32_t SIU_reserved6[29];
2548
2549 union { /* Chip Configuration Register Register */
2550 uint32_t R;
2551 struct {
2552 uint32_t:14;
2553 uint32_t MATCH:1;
2554 uint32_t DISNEX:1;
2555 uint32_t:16;
2556 } B;
2557 } CCR;
2558
2559 union { /* External Clock Configuration Register Register */
2560 uint32_t R;
2561 struct {
2562 uint32_t:30;
2563 uint32_t EBDF:2;
2564 } B;
2565 } ECCR;
2566
2567 union { /* Compare A High Register */
2568 uint32_t R;
2569 } CMPAH;
2570
2571 union { /* Compare A Low Register */
2572 uint32_t R;
2573 } CMPAL;
2574
2575 union { /* Compare B High Register */
2576 uint32_t R;
2577 } CMPBH;
2578
2579 union { /* Compare B Low Register */
2580 uint32_t R;
2581 } CMPBL;
2582
2583 int32_t SIU_reserved7[2];
2584
2585 union { /* System CLock Register */
2586 uint32_t R;
2587 struct {
2588 uint32_t SYSCLKSEL:2;
2589 uint32_t SYSCLKDIV:2;
2590 uint32_t SWTCLKSEL:1;
2591 uint32_t:11;
2592 uint32_t LPCLKDIV7:2;
2593 uint32_t LPCLKDIV6:2;
2594 uint32_t LPCLKDIV5:2;
2595 uint32_t LPCLKDIV4:2;
2596 uint32_t LPCLKDIV3:2;
2597 uint32_t LPCLKDIV2:2;
2598 uint32_t LPCLKDIV1:2;
2599 uint32_t LPCLKDIV0:2;
2600 } B;
2601 } SYSCLK;
2602
2603 union { /* Halt Register */
2604 uint32_t R;
2605 } HLT;
2606
2607 union { /* Halt Acknowledge Register */
2608 uint32_t R;
2609 } HLTACK;
2610
2611 int32_t SIU_reserved8[149];
2612
2613 union { /* Parallel GPIO Pin Data Output Register */
2614 uint32_t R;
2615 struct {
2616 uint32_t:16;
2617 uint32_t PB:16;
2618 } B;
2619 } PGPDO0;
2620
2621 union { /* Parallel GPIO Pin Data Output Register */
2622 uint32_t R;
2623 struct {
2624 uint32_t PC:16;
2625 uint32_t PD:16;
2626 } B;
2627 } PGPDO1;
2628
2629 union { /* Parallel GPIO Pin Data Output Register */
2630 uint32_t R;
2631 struct {
2632 uint32_t PE:16;
2633 uint32_t PF:16;
2634 } B;
2635 } PGPDO2;
2636
2637 union { /* Parallel GPIO Pin Data Output Register */
2638 uint32_t R;
2639 struct {
2640 uint32_t PG:16;
2641 uint32_t PH:16;
2642 } B;
2643 } PGPDO3;
2644
2645 union { /* Parallel GPIO Pin Data Output Register */
2646 uint32_t R;
2647 struct {
2648 uint32_t PJ:16;
2649 uint32_t:16;
2650 } B;
2651 } PGPDO4;
2652
2653 int32_t SIU_reserved9[11];
2654
2655 union { /* Parallel GPIO Pin Data Input Register */
2656 uint32_t R;
2657 struct {
2658 uint32_t PA:16;
2659 uint32_t PB:16;
2660 } B;
2661 } PGPDI0;
2662
2663 union { /* Parallel GPIO Pin Data Input Register */
2664 uint32_t R;
2665 struct {
2666 uint32_t PC:16;
2667 uint32_t PD:16;
2668 } B;
2669 } PGPDI1;
2670
2671 union { /* Parallel GPIO Pin Data Input Register */
2672 uint32_t R;
2673 struct {
2674 uint32_t PE:16;
2675 uint32_t PF:16;
2676 } B;
2677 } PGPDI2;
2678
2679 union { /* Parallel GPIO Pin Data Input Register */
2680 uint32_t R;
2681 struct {
2682 uint32_t PG:16;
2683 uint32_t PH:16;
2684 } B;
2685 } PGPDI3;
2686
2687 union { /* Parallel GPIO Pin Data Input Register */
2688 uint32_t R;
2689 struct {
2690 uint32_t PJ:16;
2691 uint32_t PK:2;
2692 uint32_t:14;
2693 } B;
2694 } PGPDI4;
2695
2696 int32_t SIU_reserved10[12];
2697
2698 union { /* Masked Parallel GPIO Pin Data Input Register */
2699 uint32_t R;
2700 struct {
2701 uint32_t PB_MASK:16;
2702 uint32_t PB:16;
2703 } B;
2704 } MPGPDO1;
2705
2706 union { /* Masked Parallel GPIO Pin Data Input Register */
2707 uint32_t R;
2708 struct {
2709 uint32_t PC_MASK:16;
2710 uint32_t PC:16;
2711 } B;
2712 } MPGPDO2;
2713
2714 union { /* Masked Parallel GPIO Pin Data Input Register */
2715 uint32_t R;
2716 struct {
2717 uint32_t PD_MASK:16;
2718 uint32_t PD:16;
2719 } B;
2720 } MPGPDO3;
2721
2722 union { /* Masked Parallel GPIO Pin Data Input Register */
2723 uint32_t R;
2724 struct {
2725 uint32_t PE_MASK:16;
2726 uint32_t PE:16;
2727 } B;
2728 } MPGPDO4;
2729
2730 union { /* Masked Parallel GPIO Pin Data Input Register */
2731 uint32_t R;
2732 struct {
2733 uint32_t PF_MASK:16;
2734 uint32_t PF:16;
2735 } B;
2736 } MPGPDO5;
2737
2738 union { /* Masked Parallel GPIO Pin Data Input Register */
2739 uint32_t R;
2740 struct {
2741 uint32_t PG_MASK:16;
2742 uint32_t PG:16;
2743 } B;
2744 } MPGPDO6;
2745
2746 union { /* Masked Parallel GPIO Pin Data Input Register */
2747 uint32_t R;
2748 struct {
2749 uint32_t PH_MASK:16;
2750 uint32_t PH:16;
2751 } B;
2752 } MPGPDO7;
2753
2754 union { /* Masked Parallel GPIO Pin Data Input Register */
2755 uint32_t R;
2756 struct {
2757 uint32_t PJ_MASK:16;
2758 uint32_t PJ:16;
2759 } B;
2760 } MPGPDO8;
2761
2762 };
2763/****************************************************************************/
2764/* MODULE : FlexRay */
2765/****************************************************************************/
2766
2767 typedef union uMVR {
2768 uint16_t R;
2769 struct {
2770 uint16_t CHIVER:8; /* CHI Version Number */
2771 uint16_t PEVER:8; /* PE Version Number */
2772 } B;
2773 } MVR_t;
2774
2775 typedef union uMCR {
2776 uint16_t R;
2777 struct {
2778 uint16_t MEN:1; /* module enable */
2779 uint16_t:1;
2780 uint16_t SCMD:1; /* single channel mode */
2781 uint16_t CHB:1; /* channel B enable */
2782 uint16_t CHA:1; /* channel A enable */
2783 uint16_t SFFE:1; /* synchronization frame filter enable */
2784 uint16_t:5;
2785 uint16_t CLKSEL:1; /* protocol engine clock source select */
2786 uint16_t PRESCALE:3; /* protocol engine clock prescaler */
2787 uint16_t:1;
2788 } B;
2789 } MCR_t;
2790 typedef union uSTBSCR {
2791 uint16_t R;
2792 struct {
2793 uint16_t WMD:1; /* write mode */
2794 uint16_t STBSSEL:7; /* strobe signal select */
2795 uint16_t:3;
2796 uint16_t ENB:1; /* strobe signal enable */
2797 uint16_t:2;
2798 uint16_t STBPSEL:2; /* strobe port select */
2799 } B;
2800 } STBSCR_t;
2801 typedef union uMBDSR {
2802 uint16_t R;
2803 struct {
2804 uint16_t:1;
2805 uint16_t MBSEG2DS:7; /* message buffer segment 2 data size */
2806 uint16_t:1;
2807 uint16_t MBSEG1DS:7; /* message buffer segment 1 data size */
2808 } B;
2809 } MBDSR_t;
2810
2811 typedef union uMBSSUTR {
2812 uint16_t R;
2813 struct {
2814
2815 uint16_t:2;
2816 uint16_t LAST_MB_SEG1:6; /* last message buffer control register for message buffer segment 1 */
2817 uint16_t:2;
2818 uint16_t LAST_MB_UTIL:6; /* last message buffer utilized */
2819 } B;
2820 } MBSSUTR_t;
2821
2822 typedef union uPOCR {
2823 uint16_t R;
2824 uint8_t byte[2];
2825 struct {
2826 uint16_t WME:1; /* write mode external correction command */
2827 uint16_t:3;
2828 uint16_t EOC_AP:2; /* external offset correction application */
2829 uint16_t ERC_AP:2; /* external rate correction application */
2830 uint16_t BSY:1; /* command write busy / write mode command */
2831 uint16_t:3;
2832 uint16_t POCCMD:4; /* protocol command */
2833 } B;
2834 } POCR_t;
2835/* protocol commands */
2836 typedef union uGIFER {
2837 uint16_t R;
2838 struct {
2839 uint16_t MIF:1; /* module interrupt flag */
2840 uint16_t PRIF:1; /* protocol interrupt flag */
2841 uint16_t CHIF:1; /* CHI interrupt flag */
2842 uint16_t WKUPIF:1; /* wakeup interrupt flag */
2843 uint16_t FNEBIF:1; /* receive FIFO channel B not empty interrupt flag */
2844 uint16_t FNEAIF:1; /* receive FIFO channel A not empty interrupt flag */
2845 uint16_t RBIF:1; /* receive message buffer interrupt flag */
2846 uint16_t TBIF:1; /* transmit buffer interrupt flag */
2847 uint16_t MIE:1; /* module interrupt enable */
2848 uint16_t PRIE:1; /* protocol interrupt enable */
2849 uint16_t CHIE:1; /* CHI interrupt enable */
2850 uint16_t WKUPIE:1; /* wakeup interrupt enable */
2851 uint16_t FNEBIE:1; /* receive FIFO channel B not empty interrupt enable */
2852 uint16_t FNEAIE:1; /* receive FIFO channel A not empty interrupt enable */
2853 uint16_t RBIE:1; /* receive message buffer interrupt enable */
2854 uint16_t TBIE:1; /* transmit buffer interrupt enable */
2855 } B;
2856 } GIFER_t;
2857 typedef union uPIFR0 {
2858 uint16_t R;
2859 struct {
2860 uint16_t FATLIF:1; /* fatal protocol error interrupt flag */
2861 uint16_t INTLIF:1; /* internal protocol error interrupt flag */
2862 uint16_t ILCFIF:1; /* illegal protocol configuration flag */
2863 uint16_t CSAIF:1; /* cold start abort interrupt flag */
2864 uint16_t MRCIF:1; /* missing rate correctio interrupt flag */
2865 uint16_t MOCIF:1; /* missing offset correctio interrupt flag */
2866 uint16_t CCLIF:1; /* clock correction limit reached interrupt flag */
2867 uint16_t MXSIF:1; /* max sync frames detected interrupt flag */
2868 uint16_t MTXIF:1; /* media access test symbol received flag */
2869 uint16_t LTXBIF:1; /* pdLatestTx violation on channel B interrupt flag */
2870 uint16_t LTXAIF:1; /* pdLatestTx violation on channel A interrupt flag */
2871 uint16_t TBVBIF:1; /* Transmission across boundary on channel B Interrupt Flag */
2872 uint16_t TBVAIF:1; /* Transmission across boundary on channel A Interrupt Flag */
2873 uint16_t TI2IF:1; /* timer 2 expired interrupt flag */
2874 uint16_t TI1IF:1; /* timer 1 expired interrupt flag */
2875 uint16_t CYSIF:1; /* cycle start interrupt flag */
2876 } B;
2877 } PIFR0_t;
2878 typedef union uPIFR1 {
2879 uint16_t R;
2880 struct {
2881 uint16_t EMCIF:1; /* error mode changed interrupt flag */
2882 uint16_t IPCIF:1; /* illegal protocol command interrupt flag */
2883 uint16_t PECFIF:1; /* protocol engine communication failure interrupt flag */
2884 uint16_t PSCIF:1; /* Protocol State Changed Interrupt Flag */
2885 uint16_t SSI3IF:1; /* slot status counter incremented interrupt flag */
2886 uint16_t SSI2IF:1; /* slot status counter incremented interrupt flag */
2887 uint16_t SSI1IF:1; /* slot status counter incremented interrupt flag */
2888 uint16_t SSI0IF:1; /* slot status counter incremented interrupt flag */
2889 uint16_t:2;
2890 uint16_t EVTIF:1; /* even cycle table written interrupt flag */
2891 uint16_t ODTIF:1; /* odd cycle table written interrupt flag */
2892 uint16_t:4;
2893 } B;
2894 } PIFR1_t;
2895 typedef union uPIER0 {
2896 uint16_t R;
2897 struct {
2898 uint16_t FATLIE:1; /* fatal protocol error interrupt enable */
2899 uint16_t INTLIE:1; /* internal protocol error interrupt interrupt enable */
2900 uint16_t ILCFIE:1; /* illegal protocol configuration interrupt enable */
2901 uint16_t CSAIE:1; /* cold start abort interrupt enable */
2902 uint16_t MRCIE:1; /* missing rate correctio interrupt enable */
2903 uint16_t MOCIE:1; /* missing offset correctio interrupt enable */
2904 uint16_t CCLIE:1; /* clock correction limit reached interrupt enable */
2905 uint16_t MXSIE:1; /* max sync frames detected interrupt enable */
2906 uint16_t MTXIE:1; /* media access test symbol received interrupt enable */
2907 uint16_t LTXBIE:1; /* pdLatestTx violation on channel B interrupt enable */
2908 uint16_t LTXAIE:1; /* pdLatestTx violation on channel A interrupt enable */
2909 uint16_t TBVBIE:1; /* Transmission across boundary on channel B Interrupt enable */
2910 uint16_t TBVAIE:1; /* Transmission across boundary on channel A Interrupt enable */
2911 uint16_t TI2IE:1; /* timer 2 expired interrupt enable */
2912 uint16_t TI1IE:1; /* timer 1 expired interrupt enable */
2913 uint16_t CYSIE:1; /* cycle start interrupt enable */
2914 } B;
2915 } PIER0_t;
2916 typedef union uPIER1 {
2917 uint16_t R;
2918 struct {
2919 uint16_t EMCIE:1; /* error mode changed interrupt enable */
2920 uint16_t IPCIE:1; /* illegal protocol command interrupt enable */
2921 uint16_t PECFIE:1; /* protocol engine communication failure interrupt enable */
2922 uint16_t PSCIE:1; /* Protocol State Changed Interrupt enable */
2923 uint16_t SSI3IE:1; /* slot status counter incremented interrupt enable */
2924 uint16_t SSI2IE:1; /* slot status counter incremented interrupt enable */
2925 uint16_t SSI1IE:1; /* slot status counter incremented interrupt enable */
2926 uint16_t SSI0IE:1; /* slot status counter incremented interrupt enable */
2927 uint16_t:2;
2928 uint16_t EVTIE:1; /* even cycle table written interrupt enable */
2929 uint16_t ODTIE:1; /* odd cycle table written interrupt enable */
2930 uint16_t:4;
2931 } B;
2932 } PIER1_t;
2933 typedef union uCHIERFR {
2934 uint16_t R;
2935 struct {
2936 uint16_t FRLBEF:1; /* flame lost channel B error flag */
2937 uint16_t FRLAEF:1; /* frame lost channel A error flag */
2938 uint16_t PCMIEF:1; /* command ignored error flag */
2939 uint16_t FOVBEF:1; /* receive FIFO overrun channel B error flag */
2940 uint16_t FOVAEF:1; /* receive FIFO overrun channel A error flag */
2941 uint16_t MSBEF:1; /* message buffer search error flag */
2942 uint16_t MBUEF:1; /* message buffer utilization error flag */
2943 uint16_t LCKEF:1; /* lock error flag */
2944 uint16_t DBLEF:1; /* double transmit message buffer lock error flag */
2945 uint16_t SBCFEF:1; /* system bus communication failure error flag */
2946 uint16_t FIDEF:1; /* frame ID error flag */
2947 uint16_t DPLEF:1; /* dynamic payload length error flag */
2948 uint16_t SPLEF:1; /* static payload length error flag */
2949 uint16_t NMLEF:1; /* network management length error flag */
2950 uint16_t NMFEF:1; /* network management frame error flag */
2951 uint16_t ILSAEF:1; /* illegal access error flag */
2952 } B;
2953 } CHIERFR_t;
2954 typedef union uMBIVEC {
2955 uint16_t R;
2956 struct {
2957
2958 uint16_t:2;
2959 uint16_t TBIVEC:6; /* transmit buffer interrupt vector */
2960 uint16_t:2;
2961 uint16_t RBIVEC:6; /* receive buffer interrupt vector */
2962 } B;
2963 } MBIVEC_t;
2964
2965 typedef union uPSR0 {
2966 uint16_t R;
2967 struct {
2968 uint16_t ERRMODE:2; /* error mode */
2969 uint16_t SLOTMODE:2; /* slot mode */
2970 uint16_t:1;
2971 uint16_t PROTSTATE:3; /* protocol state */
2972 uint16_t SUBSTATE:4; /* protocol sub state */
2973 uint16_t:1;
2974 uint16_t WAKEUPSTATUS:3; /* wakeup status */
2975 } B;
2976 } PSR0_t;
2977
2978/* protocol states */
2979/* protocol sub-states */
2980/* wakeup status */
2981 typedef union uPSR1 {
2982 uint16_t R;
2983 struct {
2984 uint16_t CSAA:1; /* cold start attempt abort flag */
2985 uint16_t SCP:1; /* cold start path */
2986 uint16_t:1;
2987 uint16_t REMCSAT:5; /* remanining coldstart attempts */
2988 uint16_t CPN:1; /* cold start noise path */
2989 uint16_t HHR:1; /* host halt request pending */
2990 uint16_t FRZ:1; /* freeze occured */
2991 uint16_t APTAC:5; /* allow passive to active counter */
2992 } B;
2993 } PSR1_t;
2994 typedef union uPSR2 {
2995 uint16_t R;
2996 struct {
2997 uint16_t NBVB:1; /* NIT boundary violation on channel B */
2998 uint16_t NSEB:1; /* NIT syntax error on channel B */
2999 uint16_t STCB:1; /* symbol window transmit conflict on channel B */
3000 uint16_t SBVB:1; /* symbol window boundary violation on channel B */
3001 uint16_t SSEB:1; /* symbol window syntax error on channel B */
3002 uint16_t MTB:1; /* media access test symbol MTS received on channel B */
3003 uint16_t NBVA:1; /* NIT boundary violation on channel A */
3004 uint16_t NSEA:1; /* NIT syntax error on channel A */
3005 uint16_t STCA:1; /* symbol window transmit conflict on channel A */
3006 uint16_t SBVA:1; /* symbol window boundary violation on channel A */
3007 uint16_t SSEA:1; /* symbol window syntax error on channel A */
3008 uint16_t MTA:1; /* media access test symbol MTS received on channel A */
3009 uint16_t CLKCORRFAILCNT:4; /* clock correction failed counter */
3010 } B;
3011 } PSR2_t;
3012 typedef union uPSR3 {
3013 uint16_t R;
3014 struct {
3015 uint16_t:2;
3016 uint16_t WUB:1; /* wakeup symbol received on channel B */
3017 uint16_t ABVB:1; /* aggregated boundary violation on channel B */
3018 uint16_t AACB:1; /* aggregated additional communication on channel B */
3019 uint16_t ACEB:1; /* aggregated content error on channel B */
3020 uint16_t ASEB:1; /* aggregated syntax error on channel B */
3021 uint16_t AVFB:1; /* aggregated valid frame on channel B */
3022 uint16_t:2;
3023 uint16_t WUA:1; /* wakeup symbol received on channel A */
3024 uint16_t ABVA:1; /* aggregated boundary violation on channel A */
3025 uint16_t AACA:1; /* aggregated additional communication on channel A */
3026 uint16_t ACEA:1; /* aggregated content error on channel A */
3027 uint16_t ASEA:1; /* aggregated syntax error on channel A */
3028 uint16_t AVFA:1; /* aggregated valid frame on channel A */
3029 } B;
3030 } PSR3_t;
3031 typedef union uCIFRR {
3032 uint16_t R;
3033 struct {
3034 uint16_t:8;
3035 uint16_t MIFR:1; /* module interrupt flag */
3036 uint16_t PRIFR:1; /* protocol interrupt flag */
3037 uint16_t CHIFR:1; /* CHI interrupt flag */
3038 uint16_t WUPIFR:1; /* wakeup interrupt flag */
3039 uint16_t FNEBIFR:1; /* receive fifo channel B no empty interrupt flag */
3040 uint16_t FNEAIFR:1; /* receive fifo channel A no empty interrupt flag */
3041 uint16_t RBIFR:1; /* receive message buffer interrupt flag */
3042 uint16_t TBIFR:1; /* transmit buffer interrupt flag */
3043 } B;
3044 } CIFRR_t;
3045 typedef union uSYMATOR {
3046 uint16_t R;
3047 struct {
3048 uint16_t:11;
3049 uint16_t TIMEOUT:5; /* system memory time out value */
3050 } B;
3051 } SYMATOR_t;
3052
3053 typedef union uSFCNTR {
3054 uint16_t R;
3055 struct {
3056 uint16_t SFEVB:4; /* sync frames channel B, even cycle */
3057 uint16_t SFEVA:4; /* sync frames channel A, even cycle */
3058 uint16_t SFODB:4; /* sync frames channel B, odd cycle */
3059 uint16_t SFODA:4; /* sync frames channel A, odd cycle */
3060 } B;
3061 } SFCNTR_t;
3062
3063 typedef union uSFTCCSR {
3064 uint16_t R;
3065 struct {
3066 uint16_t ELKT:1; /* even cycle tables lock and unlock trigger */
3067 uint16_t OLKT:1; /* odd cycle tables lock and unlock trigger */
3068 uint16_t CYCNUM:6; /* cycle number */
3069 uint16_t ELKS:1; /* even cycle tables lock status */
3070 uint16_t OLKS:1; /* odd cycle tables lock status */
3071 uint16_t EVAL:1; /* even cycle tables valid */
3072 uint16_t OVAL:1; /* odd cycle tables valid */
3073 uint16_t:1;
3074 uint16_t OPT:1; /*one pair trigger */
3075 uint16_t SDVEN:1; /* sync frame deviation table enable */
3076 uint16_t SIDEN:1; /* sync frame ID table enable */
3077 } B;
3078 } SFTCCSR_t;
3079 typedef union uSFIDRFR {
3080 uint16_t R;
3081 struct {
3082 uint16_t:6;
3083 uint16_t SYNFRID:10; /* sync frame rejection ID */
3084 } B;
3085 } SFIDRFR_t;
3086
3087 typedef union uTICCR {
3088 uint16_t R;
3089 struct {
3090 uint16_t:2;
3091 uint16_t T2CFG:1; /* timer 2 configuration */
3092 uint16_t T2REP:1; /* timer 2 repetitive mode */
3093 uint16_t:1;
3094 uint16_t T2SP:1; /* timer 2 stop */
3095 uint16_t T2TR:1; /* timer 2 trigger */
3096 uint16_t T2ST:1; /* timer 2 state */
3097 uint16_t:3;
3098 uint16_t T1REP:1; /* timer 1 repetitive mode */
3099 uint16_t:1;
3100 uint16_t T1SP:1; /* timer 1 stop */
3101 uint16_t T1TR:1; /* timer 1 trigger */
3102 uint16_t T1ST:1; /* timer 1 state */
3103
3104 } B;
3105 } TICCR_t;
3106 typedef union uTI1CYSR {
3107 uint16_t R;
3108 struct {
3109 uint16_t:2;
3110 uint16_t TI1CYCVAL:6; /* timer 1 cycle filter value */
3111 uint16_t:2;
3112 uint16_t TI1CYCMSK:6; /* timer 1 cycle filter mask */
3113
3114 } B;
3115 } TI1CYSR_t;
3116
3117 typedef union uSSSR {
3118 uint16_t R;
3119 struct {
3120 uint16_t WMD:1; /* write mode */
3121 uint16_t:1;
3122 uint16_t SEL:2; /* static slot number */
3123 uint16_t:1;
3124 uint16_t SLOTNUMBER:11; /* selector */
3125 } B;
3126 } SSSR_t;
3127
3128 typedef union uSSCCR {
3129 uint16_t R;
3130 struct {
3131 uint16_t WMD:1; /* write mode */
3132 uint16_t:1;
3133 uint16_t SEL:2; /* selector */
3134 uint16_t:1;
3135 uint16_t CNTCFG:2; /* counter configuration */
3136 uint16_t MCY:1; /* multi cycle selection */
3137 uint16_t VFR:1; /* valid frame selection */
3138 uint16_t SYF:1; /* sync frame selection */
3139 uint16_t NUF:1; /* null frame selection */
3140 uint16_t SUF:1; /* startup frame selection */
3141 uint16_t STATUSMASK:4; /* slot status mask */
3142 } B;
3143 } SSCCR_t;
3144 typedef union uSSR {
3145 uint16_t R;
3146 struct {
3147 uint16_t VFB:1; /* valid frame on channel B */
3148 uint16_t SYB:1; /* valid sync frame on channel B */
3149 uint16_t NFB:1; /* valid null frame on channel B */
3150 uint16_t SUB:1; /* valid startup frame on channel B */
3151 uint16_t SEB:1; /* syntax error on channel B */
3152 uint16_t CEB:1; /* content error on channel B */
3153 uint16_t BVB:1; /* boundary violation on channel B */
3154 uint16_t TCB:1; /* tx conflict on channel B */
3155 uint16_t VFA:1; /* valid frame on channel A */
3156 uint16_t SYA:1; /* valid sync frame on channel A */
3157 uint16_t NFA:1; /* valid null frame on channel A */
3158 uint16_t SUA:1; /* valid startup frame on channel A */
3159 uint16_t SEA:1; /* syntax error on channel A */
3160 uint16_t CEA:1; /* content error on channel A */
3161 uint16_t BVA:1; /* boundary violation on channel A */
3162 uint16_t TCA:1; /* tx conflict on channel A */
3163 } B;
3164 } SSR_t;
3165 typedef union uMTSCFR {
3166 uint16_t R;
3167 struct {
3168 uint16_t MTE:1; /* media access test symbol transmission enable */
3169 uint16_t:1;
3170 uint16_t CYCCNTMSK:6; /* cycle counter mask */
3171 uint16_t:2;
3172 uint16_t CYCCNTVAL:6; /* cycle counter value */
3173 } B;
3174 } MTSCFR_t;
3175
3176 typedef union uRSBIR {
3177 uint16_t R;
3178 struct {
3179 uint16_t WMD:1; /* write mode */
3180 uint16_t:1;
3181 uint16_t SEL:2; /* selector */
3182 uint16_t:5;
3183 uint16_t RSBIDX:7; /* receive shadow buffer index */
3184 } B;
3185 } RSBIR_t;
3186
3187 typedef union uRFDSR {
3188 uint16_t R;
3189 struct {
3190 uint16_t FIFODEPTH:8; /* fifo depth */
3191 uint16_t:1;
3192 uint16_t ENTRYSIZE:7; /* entry size */
3193 } B;
3194 } RFDSR_t;
3195
3196 typedef union uRFRFCFR {
3197 uint16_t R;
3198 struct {
3199 uint16_t WMD:1; /* write mode */
3200 uint16_t IBD:1; /* interval boundary */
3201 uint16_t SEL:2; /* filter number */
3202 uint16_t:1;
3203 uint16_t SID:11; /* slot ID */
3204 } B;
3205 } RFRFCFR_t;
3206
3207 typedef union uRFRFCTR {
3208 uint16_t R;
3209 struct {
3210 uint16_t:4;
3211 uint16_t F3MD:1; /* filter mode */
3212 uint16_t F2MD:1; /* filter mode */
3213 uint16_t F1MD:1; /* filter mode */
3214 uint16_t F0MD:1; /* filter mode */
3215 uint16_t:4;
3216 uint16_t F3EN:1; /* filter enable */
3217 uint16_t F2EN:1; /* filter enable */
3218 uint16_t F1EN:1; /* filter enable */
3219 uint16_t F0EN:1; /* filter enable */
3220 } B;
3221 } RFRFCTR_t;
3222 typedef union uPCR0 {
3223 uint16_t R;
3224 struct {
3225 uint16_t ACTION_POINT_OFFSET:6;
3226 uint16_t STATIC_SLOT_LENGTH:10;
3227 } B;
3228 } PCR0_t;
3229
3230 typedef union uPCR1 {
3231 uint16_t R;
3232 struct {
3233 uint16_t:2;
3234 uint16_t MACRO_AFTER_FIRST_STATIC_SLOT:14;
3235 } B;
3236 } PCR1_t;
3237
3238 typedef union uPCR2 {
3239 uint16_t R;
3240 struct {
3241 uint16_t MINISLOT_AFTER_ACTION_POINT:6;
3242 uint16_t NUMBER_OF_STATIC_SLOTS:10;
3243 } B;
3244 } PCR2_t;
3245
3246 typedef union uPCR3 {
3247 uint16_t R;
3248 struct {
3249 uint16_t WAKEUP_SYMBOL_RX_LOW:6;
3250 uint16_t MINISLOT_ACTION_POINT_OFFSET:5;
3251 uint16_t COLDSTART_ATTEMPTS:5;
3252 } B;
3253 } PCR3_t;
3254
3255 typedef union uPCR4 {
3256 uint16_t R;
3257 struct {
3258 uint16_t CAS_RX_LOW_MAX:7;
3259 uint16_t WAKEUP_SYMBOL_RX_WINDOW:9;
3260 } B;
3261 } PCR4_t;
3262
3263 typedef union uPCR5 {
3264 uint16_t R;
3265 struct {
3266 uint16_t TSS_TRANSMITTER:4;
3267 uint16_t WAKEUP_SYMBOL_TX_LOW:6;
3268 uint16_t WAKEUP_SYMBOL_RX_IDLE:6;
3269 } B;
3270 } PCR5_t;
3271
3272 typedef union uPCR6 {
3273 uint16_t R;
3274 struct {
3275 uint16_t:1;
3276 uint16_t SYMBOL_WINDOW_AFTER_ACTION_POINT:8;
3277 uint16_t MACRO_INITIAL_OFFSET_A:7;
3278 } B;
3279 } PCR6_t;
3280
3281 typedef union uPCR7 {
3282 uint16_t R;
3283 struct {
3284 uint16_t DECODING_CORRECTION_B:9;
3285 uint16_t MICRO_PER_MACRO_NOM_HALF:7;
3286 } B;
3287 } PCR7_t;
3288
3289 typedef union uPCR8 {
3290 uint16_t R;
3291 struct {
3292 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_FATAL:4;
3293 uint16_t MAX_WITHOUT_CLOCK_CORRECTION_PASSIVE:4;
3294 uint16_t WAKEUP_SYMBOL_TX_IDLE:8;
3295 } B;
3296 } PCR8_t;
3297
3298 typedef union uPCR9 {
3299 uint16_t R;
3300 struct {
3301 uint16_t MINISLOT_EXISTS:1;
3302 uint16_t SYMBOL_WINDOW_EXISTS:1;
3303 uint16_t OFFSET_CORRECTION_OUT:14;
3304 } B;
3305 } PCR9_t;
3306
3307 typedef union uPCR10 {
3308 uint16_t R;
3309 struct {
3310 uint16_t SINGLE_SLOT_ENABLED:1;
3311 uint16_t WAKEUP_CHANNEL:1;
3312 uint16_t MACRO_PER_CYCLE:14;
3313 } B;
3314 } PCR10_t;
3315
3316 typedef union uPCR11 {
3317 uint16_t R;
3318 struct {
3319 uint16_t KEY_SLOT_USED_FOR_STARTUP:1;
3320 uint16_t KEY_SLOT_USED_FOR_SYNC:1;
3321 uint16_t OFFSET_CORRECTION_START:14;
3322 } B;
3323 } PCR11_t;
3324
3325 typedef union uPCR12 {
3326 uint16_t R;
3327 struct {
3328 uint16_t ALLOW_PASSIVE_TO_ACTIVE:5;
3329 uint16_t KEY_SLOT_HEADER_CRC:11;
3330 } B;
3331 } PCR12_t;
3332
3333 typedef union uPCR13 {
3334 uint16_t R;
3335 struct {
3336 uint16_t FIRST_MINISLOT_ACTION_POINT_OFFSET:6;
3337 uint16_t STATIC_SLOT_AFTER_ACTION_POINT:10;
3338 } B;
3339 } PCR13_t;
3340
3341 typedef union uPCR14 {
3342 uint16_t R;
3343 struct {
3344 uint16_t RATE_CORRECTION_OUT:11;
3345 uint16_t LISTEN_TIMEOUT_H:5;
3346 } B;
3347 } PCR14_t;
3348
3349 typedef union uPCR15 {
3350 uint16_t R;
3351 struct {
3352 uint16_t LISTEN_TIMEOUT_L:16;
3353 } B;
3354 } PCR15_t;
3355
3356 typedef union uPCR16 {
3357 uint16_t R;
3358 struct {
3359 uint16_t MACRO_INITIAL_OFFSET_B:7;
3360 uint16_t NOISE_LISTEN_TIMEOUT_H:9;
3361 } B;
3362 } PCR16_t;
3363
3364 typedef union uPCR17 {
3365 uint16_t R;
3366 struct {
3367 uint16_t NOISE_LISTEN_TIMEOUT_L:16;
3368 } B;
3369 } PCR17_t;
3370
3371 typedef union uPCR18 {
3372 uint16_t R;
3373 struct {
3374 uint16_t WAKEUP_PATTERN:6;
3375 uint16_t KEY_SLOT_ID:10;
3376 } B;
3377 } PCR18_t;
3378
3379 typedef union uPCR19 {
3380 uint16_t R;
3381 struct {
3382 uint16_t DECODING_CORRECTION_A:9;
3383 uint16_t PAYLOAD_LENGTH_STATIC:7;
3384 } B;
3385 } PCR19_t;
3386
3387 typedef union uPCR20 {
3388 uint16_t R;
3389 struct {
3390 uint16_t MICRO_INITIAL_OFFSET_B:8;
3391 uint16_t MICRO_INITIAL_OFFSET_A:8;
3392 } B;
3393 } PCR20_t;
3394
3395 typedef union uPCR21 {
3396 uint16_t R;
3397 struct {
3398 uint16_t EXTERN_RATE_CORRECTION:3;
3399 uint16_t LATEST_TX:13;
3400 } B;
3401 } PCR21_t;
3402
3403 typedef union uPCR22 {
3404 uint16_t R;
3405 struct {
3406 uint16_t:1;
3407 uint16_t COMP_ACCEPTED_STARTUP_RANGE_A:11;
3408 uint16_t MICRO_PER_CYCLE_H:4;
3409 } B;
3410 } PCR22_t;
3411
3412 typedef union uPCR23 {
3413 uint16_t R;
3414 struct {
3415 uint16_t micro_per_cycle_l:16;
3416 } B;
3417 } PCR23_t;
3418
3419 typedef union uPCR24 {
3420 uint16_t R;
3421 struct {
3422 uint16_t CLUSTER_DRIFT_DAMPING:5;
3423 uint16_t MAX_PAYLOAD_LENGTH_DYNAMIC:7;
3424 uint16_t MICRO_PER_CYCLE_MIN_H:4;
3425 } B;
3426 } PCR24_t;
3427
3428 typedef union uPCR25 {
3429 uint16_t R;
3430 struct {
3431 uint16_t MICRO_PER_CYCLE_MIN_L:16;
3432 } B;
3433 } PCR25_t;
3434
3435 typedef union uPCR26 {
3436 uint16_t R;
3437 struct {
3438 uint16_t ALLOW_HALT_DUE_TO_CLOCK:1;
3439 uint16_t COMP_ACCEPTED_STARTUP_RANGE_B:11;
3440 uint16_t MICRO_PER_CYCLE_MAX_H:4;
3441 } B;
3442 } PCR26_t;
3443
3444 typedef union uPCR27 {
3445 uint16_t R;
3446 struct {
3447 uint16_t MICRO_PER_CYCLE_MAX_L:16;
3448 } B;
3449 } PCR27_t;
3450
3451 typedef union uPCR28 {
3452 uint16_t R;
3453 struct {
3454 uint16_t DYNAMIC_SLOT_IDLE_PHASE:2;
3455 uint16_t MACRO_AFTER_OFFSET_CORRECTION:14;
3456 } B;
3457 } PCR28_t;
3458
3459 typedef union uPCR29 {
3460 uint16_t R;
3461 struct {
3462 uint16_t EXTERN_OFFSET_CORRECTION:3;
3463 uint16_t MINISLOTS_MAX:13;
3464 } B;
3465 } PCR29_t;
3466
3467 typedef union uPCR30 {
3468 uint16_t R;
3469 struct {
3470 uint16_t:12;
3471 uint16_t SYNC_NODE_MAX:4;
3472 } B;
3473 } PCR30_t;
3474
3475 typedef struct uMSG_BUFF_CCS {
3476 union {
3477 uint16_t R;
3478 struct {
3479 uint16_t:1;
3480 uint16_t MCM:1; /* message buffer commit mode */
3481 uint16_t MBT:1; /* message buffer type */
3482 uint16_t MTD:1; /* message buffer direction */
3483 uint16_t CMT:1; /* commit for transmission */
3484 uint16_t EDT:1; /* enable / disable trigger */
3485 uint16_t LCKT:1; /* lock request trigger */
3486 uint16_t MBIE:1; /* message buffer interrupt enable */
3487 uint16_t:3;
3488 uint16_t DUP:1; /* data updated */
3489 uint16_t DVAL:1; /* data valid */
3490 uint16_t EDS:1; /* lock status */
3491 uint16_t LCKS:1; /* enable / disable status */
3492 uint16_t MBIF:1; /* message buffer interrupt flag */
3493 } B;
3494 } MBCCSR;
3495 union {
3496 uint16_t R;
3497 struct {
3498 uint16_t MTM:1; /* message buffer transmission mode */
3499 uint16_t CHNLA:1; /* channel assignement */
3500 uint16_t CHNLB:1; /* channel assignement */
3501 uint16_t CCFE:1; /* cycle counter filter enable */
3502 uint16_t CCFMSK:6; /* cycle counter filter mask */
3503 uint16_t CCFVAL:6; /* cycle counter filter value */
3504 } B;
3505 } MBCCFR;
3506 union {
3507 uint16_t R;
3508 struct {
3509 uint16_t:5;
3510 uint16_t FID:11; /* frame ID */
3511 } B;
3512 } MBFIDR;
3513
3514 union {
3515 uint16_t R;
3516 struct {
3517 uint16_t:9;
3518 uint16_t MBIDX:7; /* message buffer index */
3519 } B;
3520 } MBIDXR;
3522 typedef union uSYSBADHR {
3523 uint16_t R;
3524 } SYSBADHR_t;
3525 typedef union uSYSBADLR {
3526 uint16_t R;
3527 } SYSBADLR_t;
3528 typedef union uPADR {
3529 uint16_t R;
3530 } PADR_t;
3531 typedef union uPDAR {
3532 uint16_t R;
3533 } PDAR_t;
3534 typedef union uCASERCR {
3535 uint16_t R;
3536 } CASERCR_t;
3537 typedef union uCBSERCR {
3538 uint16_t R;
3539 } CBSERCR_t;
3540 typedef union uCYCTR {
3541 uint16_t R;
3542 } CYCTR_t;
3543 typedef union uMTCTR {
3544 uint16_t R;
3545 } MTCTR_t;
3546 typedef union uSLTCTAR {
3547 uint16_t R;
3548 } SLTCTAR_t;
3549 typedef union uSLTCTBR {
3550 uint16_t R;
3551 } SLTCTBR_t;
3552 typedef union uRTCORVR {
3553 uint16_t R;
3554 } RTCORVR_t;
3555 typedef union uOFCORVR {
3556 uint16_t R;
3557 } OFCORVR_t;
3558 typedef union uSFTOR {
3559 uint16_t R;
3560 } SFTOR_t;
3561 typedef union uSFIDAFVR {
3562 uint16_t R;
3563 } SFIDAFVR_t;
3564 typedef union uSFIDAFMR {
3565 uint16_t R;
3566 } SFIDAFMR_t;
3567 typedef union uNMVR {
3568 uint16_t R;
3569 } NMVR_t;
3570 typedef union uNMVLR {
3571 uint16_t R;
3572 } NMVLR_t;
3573 typedef union uT1MTOR {
3574 uint16_t R;
3575 } T1MTOR_t;
3576 typedef union uTI2CR0 {
3577 uint16_t R;
3578 } TI2CR0_t;
3579 typedef union uTI2CR1 {
3580 uint16_t R;
3581 } TI2CR1_t;
3582 typedef union uSSCR {
3583 uint16_t R;
3584 } SSCR_t;
3585 typedef union uRFSR {
3586 uint16_t R;
3587 } RFSR_t;
3588 typedef union uRFSIR {
3589 uint16_t R;
3590 } RFSIR_t;
3591 typedef union uRFARIR {
3592 uint16_t R;
3593 } RFARIR_t;
3594 typedef union uRFBRIR {
3595 uint16_t R;
3596 } RFBRIR_t;
3597 typedef union uRFMIDAFVR {
3598 uint16_t R;
3599 } RFMIDAFVR_t;
3600 typedef union uRFMIAFMR {
3601 uint16_t R;
3602 } RFMIAFMR_t;
3603 typedef union uRFFIDRFVR {
3604 uint16_t R;
3605 } RFFIDRFVR_t;
3606 typedef union uRFFIDRFMR {
3607 uint16_t R;
3608 } RFFIDRFMR_t;
3609 typedef union uLDTXSLAR {
3610 uint16_t R;
3611 } LDTXSLAR_t;
3612 typedef union uLDTXSLBR {
3613 uint16_t R;
3614 } LDTXSLBR_t;
3615
3616 typedef struct FR_tag {
3617 volatile MVR_t MVR; /*module version register *//*0 */
3618 volatile MCR_t MCR; /*module configuration register *//*2 */
3619 volatile SYSBADHR_t SYSBADHR; /*system memory base address high register *//*4 */
3620 volatile SYSBADLR_t SYSBADLR; /*system memory base address low register *//*6 */
3621 volatile STBSCR_t STBSCR; /*strobe signal control register *//*8 */
3622 uint16_t reserved0[1]; /*A */
3623 volatile MBDSR_t MBDSR; /*message buffer data size register *//*C */
3624 volatile MBSSUTR_t MBSSUTR; /*message buffer segment size and utilization register *//*E */
3625 uint16_t reserved1[1]; /*10 */
3626 uint16_t reserved2[1]; /*12 */
3627 volatile POCR_t POCR; /*Protocol operation control register *//*14 */
3628 volatile GIFER_t GIFER; /*global interrupt flag and enable register *//*16 */
3629 volatile PIFR0_t PIFR0; /*protocol interrupt flag register 0 *//*18 */
3630 volatile PIFR1_t PIFR1; /*protocol interrupt flag register 1 *//*1A */
3631 volatile PIER0_t PIER0; /*protocol interrupt enable register 0 *//*1C */
3632 volatile PIER1_t PIER1; /*protocol interrupt enable register 1 *//*1E */
3633 volatile CHIERFR_t CHIERFR; /*CHI error flag register *//*20 */
3634 volatile MBIVEC_t MBIVEC; /*message buffer interrupt vector register *//*22 */
3635 volatile CASERCR_t CASERCR; /*channel A status error counter register *//*24 */
3636 volatile CBSERCR_t CBSERCR; /*channel B status error counter register *//*26 */
3637 volatile PSR0_t PSR0; /*protocol status register 0 *//*28 */
3638 volatile PSR1_t PSR1; /*protocol status register 1 *//*2A */
3639 volatile PSR2_t PSR2; /*protocol status register 2 *//*2C */
3640 volatile PSR3_t PSR3; /*protocol status register 3 *//*2E */
3641 volatile MTCTR_t MTCTR; /*macrotick counter register *//*30 */
3642 volatile CYCTR_t CYCTR; /*cycle counter register *//*32 */
3643 volatile SLTCTAR_t SLTCTAR; /*slot counter channel A register *//*34 */
3644 volatile SLTCTBR_t SLTCTBR; /*slot counter channel B register *//*36 */
3645 volatile RTCORVR_t RTCORVR; /*rate correction value register *//*38 */
3646 volatile OFCORVR_t OFCORVR; /*offset correction value register *//*3A */
3647 volatile CIFRR_t CIFRR; /*combined interrupt flag register *//*3C */
3648 volatile SYMATOR_t SYMATOR; /*system memory acess time-out register *//*3E */
3649 volatile SFCNTR_t SFCNTR; /*sync frame counter register *//*40 */
3650 volatile SFTOR_t SFTOR; /*sync frame table offset register *//*42 */
3651 volatile SFTCCSR_t SFTCCSR; /*sync frame table configuration, control, status register *//*44 */
3652 volatile SFIDRFR_t SFIDRFR; /*sync frame ID rejection filter register *//*46 */
3653 volatile SFIDAFVR_t SFIDAFVR; /*sync frame ID acceptance filter value regiater *//*48 */
3654 volatile SFIDAFMR_t SFIDAFMR; /*sync frame ID acceptance filter mask register *//*4A */
3655 volatile NMVR_t NMVR[6]; /*network management vector registers (12 bytes) *//*4C */
3656 volatile NMVLR_t NMVLR; /*network management vector length register *//*58 */
3657 volatile TICCR_t TICCR; /*timer configuration and control register *//*5A */
3658 volatile TI1CYSR_t TI1CYSR; /*timer 1 cycle set register *//*5C */
3659 volatile T1MTOR_t T1MTOR; /*timer 1 macrotick offset register *//*5E */
3660 volatile TI2CR0_t TI2CR0; /*timer 2 configuration register 0 *//*60 */
3661 volatile TI2CR1_t TI2CR1; /*timer 2 configuration register 1 *//*62 */
3662 volatile SSSR_t SSSR; /*slot status selection register *//*64 */
3663 volatile SSCCR_t SSCCR; /*slot status counter condition register *//*66 */
3664 volatile SSR_t SSR[8]; /*slot status registers 0-7 *//*68 */
3665 volatile SSCR_t SSCR[4]; /*slot status counter registers 0-3 *//*78 */
3666 volatile MTSCFR_t MTSACFR; /*mts a config register *//*80 */
3667 volatile MTSCFR_t MTSBCFR; /*mts b config register *//*82 */
3668 volatile RSBIR_t RSBIR; /*receive shadow buffer index register *//*84 */
3669 volatile RFSR_t RFSR; /*receive fifo selection register *//*86 */
3670 volatile RFSIR_t RFSIR; /*receive fifo start index register *//*88 */
3671 volatile RFDSR_t RFDSR; /*receive fifo depth and size register *//*8A */
3672 volatile RFARIR_t RFARIR; /*receive fifo a read index register *//*8C */
3673 volatile RFBRIR_t RFBRIR; /*receive fifo b read index register *//*8E */
3674 volatile RFMIDAFVR_t RFMIDAFVR; /*receive fifo message ID acceptance filter value register *//*90 */
3675 volatile RFMIAFMR_t RFMIAFMR; /*receive fifo message ID acceptance filter mask register *//*92 */
3676 volatile RFFIDRFVR_t RFFIDRFVR; /*receive fifo frame ID rejection filter value register *//*94 */
3677 volatile RFFIDRFMR_t RFFIDRFMR; /*receive fifo frame ID rejection filter mask register *//*96 */
3678 volatile RFRFCFR_t RFRFCFR; /*receive fifo range filter configuration register *//*98 */
3679 volatile RFRFCTR_t RFRFCTR; /*receive fifo range filter control register *//*9A */
3680 volatile LDTXSLAR_t LDTXSLAR; /*last dynamic transmit slot channel A register *//*9C */
3681 volatile LDTXSLBR_t LDTXSLBR; /*last dynamic transmit slot channel B register *//*9E */
3682 volatile PCR0_t PCR0; /*protocol configuration register 0 *//*A0 */
3683 volatile PCR1_t PCR1; /*protocol configuration register 1 *//*A2 */
3684 volatile PCR2_t PCR2; /*protocol configuration register 2 *//*A4 */
3685 volatile PCR3_t PCR3; /*protocol configuration register 3 *//*A6 */
3686 volatile PCR4_t PCR4; /*protocol configuration register 4 *//*A8 */
3687 volatile PCR5_t PCR5; /*protocol configuration register 5 *//*AA */
3688 volatile PCR6_t PCR6; /*protocol configuration register 6 *//*AC */
3689 volatile PCR7_t PCR7; /*protocol configuration register 7 *//*AE */
3690 volatile PCR8_t PCR8; /*protocol configuration register 8 *//*B0 */
3691 volatile PCR9_t PCR9; /*protocol configuration register 9 *//*B2 */
3692 volatile PCR10_t PCR10; /*protocol configuration register 10 *//*B4 */
3693 volatile PCR11_t PCR11; /*protocol configuration register 11 *//*B6 */
3694 volatile PCR12_t PCR12; /*protocol configuration register 12 *//*B8 */
3695 volatile PCR13_t PCR13; /*protocol configuration register 13 *//*BA */
3696 volatile PCR14_t PCR14; /*protocol configuration register 14 *//*BC */
3697 volatile PCR15_t PCR15; /*protocol configuration register 15 *//*BE */
3698 volatile PCR16_t PCR16; /*protocol configuration register 16 *//*C0 */
3699 volatile PCR17_t PCR17; /*protocol configuration register 17 *//*C2 */
3700 volatile PCR18_t PCR18; /*protocol configuration register 18 *//*C4 */
3701 volatile PCR19_t PCR19; /*protocol configuration register 19 *//*C6 */
3702 volatile PCR20_t PCR20; /*protocol configuration register 20 *//*C8 */
3703 volatile PCR21_t PCR21; /*protocol configuration register 21 *//*CA */
3704 volatile PCR22_t PCR22; /*protocol configuration register 22 *//*CC */
3705 volatile PCR23_t PCR23; /*protocol configuration register 23 *//*CE */
3706 volatile PCR24_t PCR24; /*protocol configuration register 24 *//*D0 */
3707 volatile PCR25_t PCR25; /*protocol configuration register 25 *//*D2 */
3708 volatile PCR26_t PCR26; /*protocol configuration register 26 *//*D4 */
3709 volatile PCR27_t PCR27; /*protocol configuration register 27 *//*D6 */
3710 volatile PCR28_t PCR28; /*protocol configuration register 28 *//*D8 */
3711 volatile PCR29_t PCR29; /*protocol configuration register 29 *//*DA */
3712 volatile PCR30_t PCR30; /*protocol configuration register 30 *//*DC */
3713 uint16_t reserved3[17];
3714 volatile MSG_BUFF_CCS_t MBCCS[128]; /* message buffer configuration, control & status registers 0-31 *//*100 */
3715 } FR_tag_t;
3716
3717 typedef union uF_HEADER /* frame header */
3718 {
3719 struct {
3720 uint16_t:5;
3721 uint16_t HDCRC:11; /* Header CRC */
3722 uint16_t:2;
3723 uint16_t CYCCNT:6; /* Cycle Count */
3724 uint16_t:1;
3725 uint16_t PLDLEN:7; /* Payload Length */
3726 uint16_t:1;
3727 uint16_t PPI:1; /* Payload Preamble Indicator */
3728 uint16_t NUF:1; /* Null Frame Indicator */
3729 uint16_t SYF:1; /* Sync Frame Indicator */
3730 uint16_t SUF:1; /* Startup Frame Indicator */
3731 uint16_t FID:11; /* Frame ID */
3732 } B;
3733 uint16_t WORDS[3];
3734 } F_HEADER_t;
3735 typedef union uS_STSTUS /* slot status */
3736 {
3737 struct {
3738 uint16_t VFB:1; /* Valid Frame on channel B */
3739 uint16_t SYB:1; /* Sync Frame Indicator channel B */
3740 uint16_t NFB:1; /* Null Frame Indicator channel B */
3741 uint16_t SUB:1; /* Startup Frame Indicator channel B */
3742 uint16_t SEB:1; /* Syntax Error on channel B */
3743 uint16_t CEB:1; /* Content Error on channel B */
3744 uint16_t BVB:1; /* Boundary Violation on channel B */
3745 uint16_t CH:1; /* Channel */
3746 uint16_t VFA:1; /* Valid Frame on channel A */
3747 uint16_t SYA:1; /* Sync Frame Indicator channel A */
3748 uint16_t NFA:1; /* Null Frame Indicator channel A */
3749 uint16_t SUA:1; /* Startup Frame Indicator channel A */
3750 uint16_t SEA:1; /* Syntax Error on channel A */
3751 uint16_t CEA:1; /* Content Error on channel A */
3752 uint16_t BVA:1; /* Boundary Violation on channel A */
3753 uint16_t:1;
3754 } RX;
3755 struct {
3756 uint16_t VFB:1; /* Valid Frame on channel B */
3757 uint16_t SYB:1; /* Sync Frame Indicator channel B */
3758 uint16_t NFB:1; /* Null Frame Indicator channel B */
3759 uint16_t SUB:1; /* Startup Frame Indicator channel B */
3760 uint16_t SEB:1; /* Syntax Error on channel B */
3761 uint16_t CEB:1; /* Content Error on channel B */
3762 uint16_t BVB:1; /* Boundary Violation on channel B */
3763 uint16_t TCB:1; /* Tx Conflict on channel B */
3764 uint16_t VFA:1; /* Valid Frame on channel A */
3765 uint16_t SYA:1; /* Sync Frame Indicator channel A */
3766 uint16_t NFA:1; /* Null Frame Indicator channel A */
3767 uint16_t SUA:1; /* Startup Frame Indicator channel A */
3768 uint16_t SEA:1; /* Syntax Error on channel A */
3769 uint16_t CEA:1; /* Content Error on channel A */
3770 uint16_t BVA:1; /* Boundary Violation on channel A */
3771 uint16_t TCA:1; /* Tx Conflict on channel A */
3772 } TX;
3773 uint16_t R;
3774 } S_STATUS_t;
3775
3776 typedef struct uMB_HEADER /* message buffer header */
3777 {
3778 F_HEADER_t FRAME_HEADER;
3779 uint16_t DATA_OFFSET;
3780 S_STATUS_t SLOT_STATUS;
3781 } MB_HEADER_t;
3782/****************************************************************************/
3783/* MODULE : MLB */
3784/****************************************************************************/
3785 struct MLB_tag {
3786
3787 union { /* MLB Module Configuration Register */
3788 uint32_t R;
3789 struct {
3790 uint32_t MDIS:1;
3791 uint32_t:15;
3792 uint32_t MDATOBSE:1;
3793 uint32_t MSIGOBS:1;
3794 uint32_t MSLOTE:1;
3795 uint32_t:2;
3796 uint32_t MSVRQIE:1;
3797 uint32_t MDATRQE:1;
3798 uint32_t:2;
3799 uint32_t MSVRQDL:3;
3800 uint32_t MSVRQCIE:1;
3801 uint32_t MIFSEL:1;
3802 uint32_t MSBFEPOL:1;
3803 uint32_t MDBFEPOL:1;
3804 } B;
3805 } MCR;
3806
3807 union { /* MLB Blank Register */
3808 uint32_t R;
3809 struct {
3810 uint32_t:31;
3811 uint32_t BLANK:1;
3812 } B;
3813 } MBR;
3814
3815 union { /* MLB Status Register */
3816 uint32_t R;
3817 struct {
3818 uint32_t:29;
3819 uint32_t MDATRQS:1;
3820 uint32_t MSYSS:1;
3821 uint32_t MSVRQS:1;
3822 } B;
3823 } MSR;
3824
3825 union { /* RX Control Channel Address Register */
3826 uint32_t R;
3827 struct {
3828 uint32_t RXCCHA_ACEN:1;
3829 uint32_t:25;
3830 uint32_t RXCCHA:5;
3831 uint32_t:1;
3832 } B;
3833 } RXCCHAR;
3834
3835 union { /* RX Async Channel Address Register */
3836 uint32_t R;
3837 struct {
3838 uint32_t RXACHA_ACEN:1;
3839 uint32_t:25;
3840 uint32_t RXACHA:5;
3841 uint32_t:1;
3842 } B;
3843 } RXACHAR;
3844
3845 union { /* TX Control Channel Address Register */
3846 uint32_t R;
3847 struct {
3848 uint32_t TXCCHA_ACEN:1;
3849 uint32_t:25;
3850 uint32_t TXCCHA:5;
3851 uint32_t:1;
3852 } B;
3853 } TXCCHAR;
3854
3855 union { /* TX Async Channel Address Register */
3856 uint32_t R;
3857 struct {
3858 uint32_t TXACHA_ACEN:1;
3859 uint32_t:25;
3860 uint32_t TXACHA:5;
3861 uint32_t:1;
3862 } B;
3863 } TXACHAR;
3864
3865 union { /* TX Sync Channel Address Register */
3866 uint32_t R;
3867 struct {
3868 uint32_t TXSCHA_ACEN:1;
3869 uint32_t:25;
3870 uint32_t TXSCHA:5;
3871 uint32_t:1;
3872 } B;
3873 } TXSCHAR;
3874
3875 union { /* TX Sync Channel Address Mask Register */
3876 uint32_t R;
3877 struct {
3878 uint32_t:26;
3879 uint32_t TXSCHAM:5;
3880 uint32_t:1;
3881 } B;
3882 } TXSCHAMR;
3883
3884 union { /* Clock Adjust Control Register */
3885 uint32_t R;
3886 struct {
3887 uint32_t:16;
3888 uint32_t PDLY:16;
3889 } B;
3890 } CLKACR;
3891
3892 union { /* RX Isochronous Channel Address Register */
3893 uint32_t R;
3894 struct {
3895 uint32_t RXICHA_ACEN:1;
3896 uint32_t:25;
3897 uint32_t RXICHA:5;
3898 uint32_t:1;
3899 } B;
3900 } RXICHAR;
3901
3902 union { /* TX Isochronous Channel Address Register */
3903 uint32_t R;
3904 struct {
3905 uint32_t TXICHA_ACEN:1;
3906 uint32_t:25;
3907 uint32_t TXICHA:5;
3908 uint32_t:1;
3909 } B;
3910 } TXICHAR;
3911
3912 };
3913
3914/* Define memories */
3915
3916#define SRAM_START 0x40000000UL
3917#define SRAM_SIZE 0x14000UL
3918#define SRAM_END 0x40013FFFUL
3919
3920#define FLASH_START 0x0UL
3921#define FLASH_SIZE 0x180000UL
3922#define FLASH_END 0x17FFFFUL
3923
3924/* Define instances of modules */
3925#define SEMA4 (*(volatile struct SEMA4_tag *) 0xFFF10000UL)
3926#define MPU (*(volatile struct MPU_tag *) 0xFFF14000UL)
3927#define MCM (*(volatile struct MCM_tag *) 0xFFF40000UL)
3928#define EDMA (*(volatile struct EDMA_tag *) 0xFFF44000UL)
3929#define INTC (*(volatile struct INTC_tag *) 0xFFF48000UL)
3930#define EQADC (*(volatile struct EQADC_tag *) 0xFFF80000UL)
3931#define MLB (*(volatile struct MLB_tag *) 0xFFF84000UL)
3932#define I2C (*(volatile struct I2C_tag *) 0xFFF88000UL)
3933#define DSPI_A (*(volatile struct DSPI_tag *) 0xFFF90000UL)
3934#define DSPI_B (*(volatile struct DSPI_tag *) 0xFFF94000UL)
3935#define DSPI_C (*(volatile struct DSPI_tag *) 0xFFF98000UL)
3936#define DSPI_D (*(volatile struct DSPI_tag *) 0xFFF9C000UL)
3937#define ESCI_A (*(volatile struct ESCI_tag *) 0xFFFA0000UL)
3938#define ESCI_B (*(volatile struct ESCI_tag *) 0xFFFA4000UL)
3939#define ESCI_C (*(volatile struct ESCI_tag *) 0xFFFA8000UL)
3940#define ESCI_D (*(volatile struct ESCI_tag *) 0xFFFAC000UL)
3941#define ESCI_E (*(volatile struct ESCI_tag *) 0xFFFB0000UL)
3942#define ESCI_F (*(volatile struct ESCI_tag *) 0xFFFB4000UL)
3943#define ESCI_G (*(volatile struct ESCI_tag *) 0xFFFB8000UL)
3944#define ESCI_H (*(volatile struct ESCI_tag *) 0xFFFBC000UL)
3945#define CAN_A (*(volatile struct FLEXCAN_tag *) 0xFFFC0000UL)
3946#define CAN_B (*(volatile struct FLEXCAN_tag *) 0xFFFC4000UL)
3947#define CAN_C (*(volatile struct FLEXCAN_tag *) 0xFFFC8000UL)
3948#define CAN_D (*(volatile struct FLEXCAN_tag *) 0xFFFCC000UL)
3949#define CAN_E (*(volatile struct FLEXCAN_tag *) 0xFFFD0000UL)
3950#define CAN_F (*(volatile struct FLEXCAN_tag *) 0xFFFD4000UL)
3951#define FR (*(volatile struct FR_tag *) 0xFFFD8000UL)
3952#define DMAMUX (*(volatile struct DMAMUX_tag *) 0xFFFDC000UL)
3953#define PIT (*(volatile struct PIT_tag *) 0xFFFE0000UL)
3954#define EMIOS (*(volatile struct EMIOS_tag *) 0xFFFE4000UL)
3955#define SIU (*(volatile struct SIU_tag *) 0xFFFE8000UL)
3956#define CRP (*(volatile struct CRP_tag *) 0xFFFEC000UL)
3957#define FMPLL (*(volatile struct FMPLL_tag *) 0xFFFF0000UL)
3958#define EBI (*(volatile struct EBI_tag *) 0xFFFF4000UL)
3959#define FLASH (*(volatile struct FLASH_tag *) 0xFFFF8000UL)
3960
3961#ifdef __MWERKS__
3962#pragma pop
3963#endif
3964
3965#ifdef __cplusplus
3966}
3967#endif
3968#endif /* ASM */
3969#endif /* ifdef _MPC5510_H */
3970/*********************************************************************
3971 *
3972 * Copyright:
3973 * Freescale Semiconductor, INC. All Rights Reserved.
3974 * You are hereby granted a copyright license to use, modify, and
3975 * distribute the SOFTWARE so long as this entire notice is
3976 * retained without alteration in any modified and/or redistributed
3977 * versions, and that such modified versions are clearly identified
3978 * as such. No licenses are granted by implication, estoppel or
3979 * otherwise under any patents or trademarks of Freescale
3980 * Semiconductor, Inc. This software is provided on an "AS IS"
3981 * basis and without warranty.
3982 *
3983 * To the maximum extent permitted by applicable law, Freescale
3984 * Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
3985 * INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
3986 * PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
3987 * REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
3988 * AND ANY ACCOMPANYING WRITTEN MATERIALS.
3989 *
3990 * To the maximum extent permitted by applicable law, IN NO EVENT
3991 * SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
3992 * (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
3993 * BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
3994 * PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
3995 *
3996 * Freescale Semiconductor assumes no responsibility for the
3997 * maintenance and support of this software
3998 *
3999 ********************************************************************/
Definition: fsl-mpc551x.h:67
Definition: fsl-mpc551x.h:224
Definition: fsl-mpc551x.h:238
Definition: fsl-mpc551x.h:473
Definition: fsl-mpc551x.h:441
Definition: fsl-mpc551x.h:477
Definition: fsl-mpc551x.h:636
Definition: fsl-mpc551x.h:525
Definition: fsl-mpc551x.h:710
Definition: fsl-mpc551x.h:893
Definition: fsl-mpc551x.h:1021
Definition: fsl-mpc551x.h:1432
Definition: fsl-mpc551x.h:1165
Definition: fsl-mpc551x.h:1478
Definition: fsl-mpc551x.h:3616
Definition: fsl-mpc551x.h:1533
Definition: fsl-mpc551x.h:1597
Definition: fsl-mpc551x.h:1686
Definition: fsl-mpc551x.h:3785
Definition: fsl-mpc551x.h:1837
Definition: fsl-mpc551x.h:1985
Definition: fsl-mpc551x.h:2081
Definition: fsl-mpc551x.h:2215
Definition: fsl-mpc551x.h:3777
Definition: fsl-mpc551x.h:3475
Definition: fsl-mpc551x.h:278
Definition: fsl-mpc551x.h:239
Definition: fsl-mpc551x.h:356
Definition: fsl-mpc551x.h:338
Definition: fsl-mpc551x.h:319
Definition: fsl-mpc551x.h:297
Definition: fsl-mpc551x.h:478
Definition: fsl-mpc551x.h:661
Definition: fsl-mpc551x.h:685
Definition: fsl-mpc551x.h:526
Definition: fsl-mpc551x.h:894
Definition: fsl-mpc551x.h:918
Definition: fsl-mpc551x.h:940
Definition: fsl-mpc551x.h:950
Definition: fsl-mpc551x.h:1064
Definition: fsl-mpc551x.h:1051
Definition: fsl-mpc551x.h:1073
Definition: fsl-mpc551x.h:1499
Definition: fsl-mpc551x.h:1511
Definition: fsl-mpc551x.h:1482
Definition: fsl-mpc551x.h:2288
Definition: fsl-mpc551x.h:2311
Definition: fsl-mpc551x.h:2263
Definition: fsl-mpc551x.h:2419
Definition: fsl-mpc551x.h:2394
Definition: fsl-mpc551x.h:2369
Definition: fsl-mpc551x.h:2346
Definition: fsl-mpc551x.h:2454
Definition: fsl-mpc551x.h:3534
Definition: fsl-mpc551x.h:3537
Definition: fsl-mpc551x.h:2933
Definition: fsl-mpc551x.h:3031
Definition: fsl-mpc551x.h:3540
Definition: fsl-mpc551x.h:3718
Definition: fsl-mpc551x.h:2836
Definition: fsl-mpc551x.h:3609
Definition: fsl-mpc551x.h:3612
Definition: fsl-mpc551x.h:2801
Definition: fsl-mpc551x.h:2954
Definition: fsl-mpc551x.h:2811
Definition: fsl-mpc551x.h:2775
Definition: fsl-mpc551x.h:3543
Definition: fsl-mpc551x.h:3165
Definition: fsl-mpc551x.h:2767
Definition: fsl-mpc551x.h:3570
Definition: fsl-mpc551x.h:3567
Definition: fsl-mpc551x.h:3555
Definition: fsl-mpc551x.h:3528
Definition: fsl-mpc551x.h:3222
Definition: fsl-mpc551x.h:3307
Definition: fsl-mpc551x.h:3316
Definition: fsl-mpc551x.h:3325
Definition: fsl-mpc551x.h:3333
Definition: fsl-mpc551x.h:3341
Definition: fsl-mpc551x.h:3349
Definition: fsl-mpc551x.h:3356
Definition: fsl-mpc551x.h:3364
Definition: fsl-mpc551x.h:3371
Definition: fsl-mpc551x.h:3379
Definition: fsl-mpc551x.h:3230
Definition: fsl-mpc551x.h:3387
Definition: fsl-mpc551x.h:3395
Definition: fsl-mpc551x.h:3403
Definition: fsl-mpc551x.h:3412
Definition: fsl-mpc551x.h:3419
Definition: fsl-mpc551x.h:3428
Definition: fsl-mpc551x.h:3435
Definition: fsl-mpc551x.h:3444
Definition: fsl-mpc551x.h:3451
Definition: fsl-mpc551x.h:3459
Definition: fsl-mpc551x.h:3238
Definition: fsl-mpc551x.h:3467
Definition: fsl-mpc551x.h:3246
Definition: fsl-mpc551x.h:3255
Definition: fsl-mpc551x.h:3263
Definition: fsl-mpc551x.h:3272
Definition: fsl-mpc551x.h:3281
Definition: fsl-mpc551x.h:3289
Definition: fsl-mpc551x.h:3298
Definition: fsl-mpc551x.h:3531
Definition: fsl-mpc551x.h:2895
Definition: fsl-mpc551x.h:2916
Definition: fsl-mpc551x.h:2857
Definition: fsl-mpc551x.h:2878
Definition: fsl-mpc551x.h:2822
Definition: fsl-mpc551x.h:2965
Definition: fsl-mpc551x.h:2981
Definition: fsl-mpc551x.h:2994
Definition: fsl-mpc551x.h:3012
Definition: fsl-mpc551x.h:3591
Definition: fsl-mpc551x.h:3594
Definition: fsl-mpc551x.h:3187
Definition: fsl-mpc551x.h:3606
Definition: fsl-mpc551x.h:3603
Definition: fsl-mpc551x.h:3600
Definition: fsl-mpc551x.h:3597
Definition: fsl-mpc551x.h:3196
Definition: fsl-mpc551x.h:3207
Definition: fsl-mpc551x.h:3588
Definition: fsl-mpc551x.h:3585
Definition: fsl-mpc551x.h:3176
Definition: fsl-mpc551x.h:3552
Definition: fsl-mpc551x.h:3053
Definition: fsl-mpc551x.h:3564
Definition: fsl-mpc551x.h:3561
Definition: fsl-mpc551x.h:3079
Definition: fsl-mpc551x.h:3063
Definition: fsl-mpc551x.h:3558
Definition: fsl-mpc551x.h:3546
Definition: fsl-mpc551x.h:3549
Definition: fsl-mpc551x.h:3128
Definition: fsl-mpc551x.h:3582
Definition: fsl-mpc551x.h:3144
Definition: fsl-mpc551x.h:3117
Definition: fsl-mpc551x.h:2790
Definition: fsl-mpc551x.h:3045
Definition: fsl-mpc551x.h:3522
Definition: fsl-mpc551x.h:3525
Definition: fsl-mpc551x.h:3736
Definition: fsl-mpc551x.h:3573
Definition: fsl-mpc551x.h:3106
Definition: fsl-mpc551x.h:3576
Definition: fsl-mpc551x.h:3579
Definition: fsl-mpc551x.h:3087
