RTEMS 6.1-rc4
ffuart.h
1/*
2 * FFUART for PXA250 CPU by Yang Xi<hiyangxi@gmail.com>
3 *
4 * The license and distribution terms for this file may be
5 * found in the file LICENSE in this distribution or at
6 * http://www.rtems.org/license/LICENSE.
7 */
8
9#ifndef __FFUART_H__
10#define __FFUART_H__
11
12typedef struct {
13 /*
14 *Receive buffer(DLAB=0).Transmit buffer(DLAB=0).
15 *Divisor Latch Low(DLAB=1)
16 */
17 volatile unsigned int rbr;
18 /*Interrupt enable(DLAB=0). Divisor Latch High(DLAB=1)*/
19 volatile unsigned int ier;
20 /*Interrupt identification.FIFO control*/
21 volatile unsigned int iir;
22 /*Line Control*/
23 volatile unsigned int lcr;
24 /*Modem control*/
25 volatile unsigned int mcr;
26 /*Line Status*/
27 volatile unsigned int lsr;
28 /*Modem status*/
29 volatile unsigned int msr;
30 /*Scratch Pad*/
31 volatile unsigned int spr;
32 /*Infrared Selection*/
33 volatile unsigned int isr;
35
36
37#define EIGHT_BITS_NOPARITY_1STOPBIT 0x3
38#define DLAB 0x80
39
40
41/*Divisor = frequency_uart/(16 * BaudRate*)*/
42#define FREQUENCY_UART (14745600)
43
44#define SEND_EMPTY 0x20
45#define FULL_RECEIVE 0x01
46
47#endif
48
Definition: ffuart.h:12
