RTEMS 6.1-rc4
ecc_priv.h
2
11/*
12 * Copyright (C) 2024 On-Line Applications Research Corporation (OAR)
13 * Written by Kinsey Moore <kinsey.moore@oarcorp.com>
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_ECC_PRIV_H
38#define LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_ECC_PRIV_H
39
46#include <bspopts.h>
47
48#ifndef ASM
49
50#include <rtems.h>
51
52#ifdef __cplusplus
53extern "C" {
54#endif /* __cplusplus */
55
56#include <bsp/ecc.h>
57
63void zynqmp_ecc_init( void );
64
71void zynqmp_ecc_init_bsp( void );
72
77
82
87
94void zynqmp_invoke_ecc_handler( ECC_Event_Type event, void *data );
95
96#ifdef __cplusplus
97}
98#endif /* __cplusplus */
99
100#endif /* ASM */
101
104#endif /* LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_ECC_PRIV_H */
This header file provides internal APIs for managing ECC events.
rtems_status_code
Definition: status.h:85
void zynqmp_ecc_init_bsp(void)
Initialize BSP-specific ECC reporting.
Definition: bspstartecc_cfc400x.c:40
void zynqmp_ecc_init(void)
Initialize ECC reporting support.
Definition: bspstartecc_hw.c:84
ECC_Event_Type
Enumeration describing the possible types of ECC events.
Definition: ecc.h:57
rtems_status_code zynqmp_configure_ocm_ecc(void)
Configure On-Chip Memory (OCM) ECC reporting.
Definition: ocm.c:255
rtems_status_code zynqmp_configure_cache_ecc(void)
Configure Cache ECC reporting.
Definition: cache.c:115
rtems_status_code zynqmp_configure_ddr_ecc(void)
Configure DDR Memory ECC reporting.
Definition: ddr.c:607
void zynqmp_invoke_ecc_handler(ECC_Event_Type event, void *data)
Invoke the ECC error handler.
Definition: bspstartecc_hw.c:49
