RTEMS 6.1-rc4
devzero.h
2
12/*
13 * Copyright (c) 2011 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_DEVZERO_H
38#define _RTEMS_DEVZERO_H
39
40#include <rtems/io.h>
41
49#ifdef __cplusplus
50extern "C" {
51#endif /* __cplusplus */
52
53#define DEVZERO_DEVICE_NAME "/dev/zero"
54
55#define DEVZERO_DRIVER_TABLE_ENTRY \
56 { \
57 dev_zero_initialize, \
58 dev_zero_open, \
59 dev_zero_close, \
60 dev_zero_read, \
61 dev_zero_write, \
62 dev_zero_control \
63 }
64
65rtems_device_driver dev_zero_initialize(
68 void *arg
69);
70
71rtems_device_driver dev_zero_open(
74 void *arg
75);
76
77rtems_device_driver dev_zero_close(
80 void *arg
81);
82
83rtems_device_driver dev_zero_read(
86 void *arg
87);
88
89rtems_device_driver dev_zero_write(
92 void *arg
93);
94
95rtems_device_driver dev_zero_control(
98 void *arg
99);
100
101#ifdef __cplusplus
102}
103#endif /* __cplusplus */
105#endif /* _RTEMS_DEVZERO_H */
This header file defines the IO Manager API.
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
