RTEMS 6.1-rc4
dbg_console.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
36#ifndef _DBG_CONSOLE_
37#define _DBG_CONSOLE_
38
39#include <stdint.h>
40
41extern void DBG_Configure(uint32_t dwBaudrate, uint32_t dwMasterClock);
42extern void DBG_PutChar(uint8_t uc);
43extern uint32_t DBG_GetChar(void);
44extern uint32_t DBG_IsRxReady(void);
45
46
47extern void DBG_DumpFrame(uint8_t *pucFrame, uint32_t dwSize);
48extern void DBG_DumpMemory(uint8_t *pucBuffer, uint32_t dwSize,
49 uint32_t dwAddress);
50extern uint32_t DBG_GetInteger(int32_t *pdwValue);
51extern uint32_t DBG_GetIntegerMinMax(int32_t *pdwValue, int32_t dwMin,
52 int32_t dwMax);
53extern uint32_t DBG_GetHexa32(uint32_t *pdwValue);
54
55#endif /* _DBG_CONSOLE_ */
Input a character from the UART line.
Definition: dbg_console.c:279
Check if there is Input from UART line.
Definition: dbg_console.c:309
Configures an USART peripheral with the specified parameters.
Definition: dbg_console.c:170
Definition: dbg_console.c:411
Definition: dbg_console.c:337
uint32_t DBG_GetIntegerMinMax(int32_t *pdwValue, int32_t dwMin, int32_t dwMax)
Definition: dbg_console.c:462
void DBG_DumpMemory(uint8_t *pucBuffer, uint32_t dwSize, uint32_t dwAddress)
Definition: dbg_console.c:354
Outputs a character on the UART line.
Definition: dbg_console.c:236
Definition: dbg_console.c:489
