RTEMS 6.1-rc4
at91rm9200_emac.h File Reference
Atmel AT91RM9200 EMAC Register definitions. More...
#include <bits.h>
#define EMAC_CTL   0x00 /* Network Control Register */
#define EMAC_CFG   0x04 /* Network Configuration Register */
#define EMAC_SR   0x08 /* Network Status Register */
#define EMAC_TAR   0x0C /* Transmit Address Register */
#define EMAC_TCR   0x10 /* Transmit Control Register */
#define EMAC_TSR   0x14 /* Transmit Status Register */
#define EMAC_RBQP   0x18 /* Receive Buffer Queue Pointer */
#define EMAC_RSR   0x20 /* Receive Status Register */
#define EMAC_ISR   0x24 /* Interrupt Enable Register */
#define EMAC_IER   0x28 /* Interrupt Enable Register */
#define EMAC_IDR   0x2C /* Interrupt Disable Register */
#define EMAC_IMR   0x30 /* Interrupt Mask Register */
#define EMAC_MAN   0x34 /* PHY Maintenance Register */
#define EMAC_FRA   0x40 /* Frames Transmitted OK Register */
#define EMAC_SCOL   0x44 /* Single Collision Frame Register */
#define EMAC_MCOL   0x48 /* Multiple Collision Frame Register */
#define EMAC_OK   0x4C /* Frames Received OK Register */
#define EMAC_SEQE   0x50 /* Frame Check Sequence Error Register */
#define EMAC_ALE   0x54 /* Alignment Error Register */
#define EMAC_DTE   0x58 /* Deferred Transmission Frame Register */
#define EMAC_LCOL   0x5C /* Late Collision Register */
#define EMAC_ECOL   0x60 /* Excessive Collision Register */
#define EMAC_CSE   0x64 /* Carrier Sense Error Register */
#define EMAC_TUE   0x68 /* Transmit Underrun Error Register */
#define EMAC_CDE   0x6C /* Code Error Register */
#define EMAC_ELR   0x70 /* Excessive Length Error Register */
#define EMAC_RJB   0x74 /* Receive Jabber Register */
#define EMAC_USF   0x78 /* Undersize Frame Register */
#define EMAC_SQEE   0x7C /* SQE Test Error Register */
#define EMAC_DRFC   0x80 /* Discarded RX Frame Register */
#define EMAC_HSH   0x90 /* Hash Address High[63:32] */
#define EMAC_HSL   0x94 /* Hash Address Low[31:0] */
#define EMAC_SA1L   0x98 /* Specific Addr 1 Low, First 4 bytes */
#define EMAC_SA1H   0x9C /* Specific Addr 1 High, Last 2 bytes */
#define EMAC_SA2L   0xA0 /* Specific Addr 2 Low, First 4 bytes */
#define EMAC_SA2H   0xA4 /* Specific Addr 2 High, Last 2 bytes */
#define EMAC_SA3L   0xA8 /* Specific Addr 3 Low, First 4 bytes */
#define EMAC_SA3H   0xAC /* Specific Addr 3 High, Last 2 bytes */
#define EMAC_SA4L   0xB0 /* Specific Addr 4 Low, First 4 bytes */
#define EMAC_SA4H   0xB4 /* Specific Addr 4 High, Last 2 bytesr */
#define EMAC_CTL_LB   BIT0 /* 1 = Set Loopback output signal */
#define EMAC_CTL_LBL   BIT1 /* 1 = Loopback local. */
#define EMAC_CTL_RE   BIT2 /* 1 = Receive enable. */
#define EMAC_CTL_TE   BIT3 /* 1 = Transmit enable. */
#define EMAC_CTL_MPE   BIT4 /* 1 = Management port enable. */
#define EMAC_CTL_CSR   BIT5 /* Write 1 to clear stats registers. */
#define EMAC_CTL_ISR   BIT6 /* Write to increment stats registers */
#define EMAC_CTL_WES   BIT7 /* 1 = Enable writing to stats regs */
#define EMAC_CTL_BP   BIT8 /* 1 = Force collision on all RX frames */
#define EMAC_CFG_SPD   BIT0 /* 1 = 10/100 Speed (not functional?) */
#define EMAC_CFG_FD   BIT1 /* 1 = Full duplex. */
#define EMAC_CFG_BR   BIT2 /* write 0 */
#define EMAC_CFG_CAF   BIT4 /* 1 = accept all frames */
#define EMAC_CFG_NBC   BIT5 /* 1 = disable reception of bcast frms */
#define EMAC_CFG_MTI   BIT6 /* 1 = Multicast hash enable */
#define EMAC_CFG_UNI   BIT7 /* 1 = Unicast hash enable. */
#define EMAC_CFG_BIG   BIT8 /* 1 = enable reception 1522 byte frms */
#define EMAC_CFG_EAE   BIT9 /* write 0 */
#define EMAC_CFG_CLK_8   (0 << 10) /* MII Clock = HCLK divided by 8 */
#define EMAC_CFG_CLK_16   (1 << 10) /* MII Clock = HCLK divided by 16 */
#define EMAC_CFG_CLK_32   (2 << 10) /* MII Clock = HCLK divided by 32 */
#define EMAC_CFG_CLK_64   (3 << 10) /* MII Clock = HCLK divided by 64 */
#define EMAC_CFG_CLK_MASK   (3 << 10) /* MII Clock mask */
#define EMAC_CFG_RTY   BIT12 /* Retry Test Mode - Must be 0 */
#define EMAC_CFG_RMII   BIT13 /* Reduced MII Mode Enable */
#define EMAC_LINK   BIT0 /* Link pin */
#define EMAC_MDIO   BIT1 /* Real Time state of MDIO pin */
#define EMAC_IDLE   BIT2 /* 0 = PHY Logic is idle */
#define EMAC_TCR_LEN(_x_)   ((_x_ & 0x7FF) << 0) /* Tx frame len minus CRC */
#define EMAC_TCR_NCRC   BIT15 /* Do'nt append CRC on Tx */
#define EMAC_TSR_OVR   BIT0 /* 1 = Transmit buffer overrun */
#define EMAC_TSR_COL   BIT1 /* 1 = Collision occured */
#define EMAC_TSR_RLE   BIT2 /* 1 = Retry lmimt exceeded */
#define EMAC_TSR_TXIDLE   BIT3 /* 1 = Transmitter is idle */
#define EMAC_TSR_BNQ   BIT4 /* 1 = Transmit buffer not queued */
#define EMAC_TSR_COMP   BIT5 /* 1 = Transmit complete */
#define EMAC_TSR_UND   BIT6 /* 1 = Transmit underrun */
#define EMAC_RSR_BNA   BIT0 /* 1 = Buffer not available */
#define EMAC_RSR_REC   BIT1 /* 1 = Frame received */
#define EMAC_RSR_OVR   BIT2 /* 1 = Receive overrun */
#define EMAC_INT_DONE   BIT0 /* Phy management done */
#define EMAC_INT_RCOM   BIT1 /* Receive complete */
#define EMAC_INT_RBNA   BIT2 /* Receive buffer not available */
#define EMAC_INT_TOVR   BIT3 /* Transmit buffer overrun */
#define EMAC_INT_TUND   BIT4 /* Transmit buffer underrun */
#define EMAC_INT_RTRY   BIT5 /* Transmit Retry limt */
#define EMAC_INT_TBRE   BIT6 /* Transmit buffer register empty */
#define EMAC_INT_TCOM   BIT7 /* Transmit complete */
#define EMAC_INT_TIDLE   BIT8 /* Transmit idle */
#define EMAC_INT_LINK   BIT9 /* Link pin changed value */
#define EMAC_INT_ROVR   BIT10 /* Receive overrun */
#define EMAC_INT_ABT   BIT11 /* Abort on DMA transfer */
#define EMAC_MAN_DATA(_x_)   ((_x_ & 0xFFFF) << 0)/* PHY data register */
#define EMAC_MAN_CODE   (0x2 << 16) /* IEEE Code */
#define EMAC_MAN_REGA(_x_)   ((_x_ & 0x1F) << 18) /* PHY register address */
#define EMAC_MAN_PHYA(_x_)   ((_x_ & 0x1F) << 23) /* PHY address */
#define EMAC_MAN_WRITE   (0x1 << 28) /* Transfer is a write */
#define EMAC_MAN_READ   (0x2 << 28) /* Transfer is a read */
#define EMAC_MAN_HIGH   BIT30 /* Must be set */
#define EMAC_MAN_LOW   BIT31
#define RXBUF_ADD_BASE_MASK   0xfffffffc /* Base addr of the rx buf */
#define RXBUF_ADD_WRAP   BIT1 /* set indicates last buf */
#define RXBUF_ADD_OWNED   BIT0 /* 1 = SW owns the pointer */
#define RXBUF_STAT_BCAST   BIT31 /* Global bcast addr detected */
#define RXBUF_STAT_MULTI   BIT30 /* Multicast hash match */
#define RXBUF_STAT_UNI   BIT29 /* Unicast hash match */
#define RXBUF_STAT_EXT   BIT28 /* External address (optional) */
#define RXBUF_STAT_UNK   BIT27 /* Unknown source address */
#define RXBUF_STAT_LOC1   BIT26 /* Local address 1 match */
#define RXBUF_STAT_LOC2   BIT25 /* Local address 2 match */
#define RXBUF_STAT_LOC3   BIT24 /* Local address 3 match */
#define RXBUF_STAT_LOC4   BIT23 /* Local address 4 match */
#define RXBUF_STAT_LEN_MASK   0x7ff /* Len of frame including FCS */
