RTEMS 6.1-rc4
arm-pl111-fb.h
2
11/*
12 * Copyright (c) 2013 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_SHARED_ARM_PL111_FB_H
37#define LIBBSP_ARM_SHARED_ARM_PL111_FB_H
38
39#include <bsp/arm-pl111-regs.h>
40
41typedef struct pl111_fb_config {
42 volatile pl111 *regs;
43 uint32_t timing0;
44 uint32_t timing1;
45 uint32_t timing2;
46 uint32_t timing3;
47 uint32_t control;
48 uint32_t power_delay_in_us;
49 void (*set_up)(const struct pl111_fb_config *cfg);
50 void (*pins_set_up)(const struct pl111_fb_config *cfg);
51 void (*pins_tear_down)(const struct pl111_fb_config *cfg);
52 void (*tear_down)(const struct pl111_fb_config *cfg);
54
55const pl111_fb_config *arm_pl111_fb_get_config(void);
56
57#endif /* LIBBSP_ARM_SHARED_ARM_PL111_FB_H */
ARM PL111 Register definitions.
Definition: intercom.c:87
Definition: arm-pl111-fb.h:41
Definition: arm-pl111-regs.h:191
