RTEMS 6.1-rc4
apbuart_termios.h
2
3/*
4 * COPYRIGHT (c) 1989-1998.
5 * On-Line Applications Research Corporation (OAR).
6 *
7 * Modified for LEON3 BSP.
8 * COPYRIGHT (c) 2004.
9 * Gaisler Research.
10 *
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions
13 * are met:
14 * 1. Redistributions of source code must retain the above copyright
15 * notice, this list of conditions and the following disclaimer.
16 * 2. Redistributions in binary form must reproduce the above copyright
17 * notice, this list of conditions and the following disclaimer in the
18 * documentation and/or other materials provided with the distribution.
19 *
20 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 * POSSIBILITY OF SUCH DAMAGE.
31 */
32
33#ifndef APBUART_TERMIOS_H
34#define APBUART_TERMIOS_H
35
36#include <rtems/termiostypes.h>
37#include "apbuart.h"
38
39#ifdef __cplusplus
40extern "C" {
41#endif /* __cplusplus */
42
45 apbuart *regs;
46 unsigned int freq_hz;
48 volatile int sending;
49 char *buf;
50};
51
52extern const rtems_termios_device_handler apbuart_handler_interrupt;
53
54extern const rtems_termios_device_handler apbuart_handler_polled;
55
56#ifdef __cplusplus
57}
58#endif /* __cplusplus */
59
60#endif /* APBUART_TERMIOS_H */
This header file defines the APBUART interface.
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: apbuart_termios.h:43
This structure defines the APBUART register block memory map.
Definition: apbuart-regs.h:248
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
