RTEMS
6.1-rc4
bsps
include
grlib
ahbstat.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
/* AHBSTAT driver interface
4
5
* COPYRIGHT (c) 2011.
6
* Cobham Gaisler AB.
7
8
9
* modification, are permitted provided that the following conditions
10
* are met:
11
* 1. Redistributions of source code must retain the above copyright
12
* notice, this list of conditions and the following disclaimer.
13
* 2. Redistributions in binary form must reproduce the above copyright
14
* notice, this list of conditions and the following disclaimer in the
15
* documentation and/or other materials provided with the distribution.
16
17
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27
* POSSIBILITY OF SUCH DAMAGE.
28
29
30
#ifndef __AHBSTAT_H__
31
#define __AHBSTAT_H__
32
33
#include <stdint.h>
34
35
#ifdef __cplusplus
36
extern
"C"
37
#endif
38
39
/* AHBSTAT Registers layout */
40
struct
ahbstat_regs
41
volatile
uint32_t status;
42
volatile
uint32_t failing;
43
volatile
uint32_t status2;
44
volatile
uint32_t failing2;
45
46
47
/* AHB fail interrupt callback to user. This function is declared weak so that
48
* the user can define a function pointer variable containing the address
49
* responsible for handling errors
50
51
* minor Index of AHBSTAT hardware
52
* regs Register address of AHBSTAT
53
* status AHBSTAT status register at IRQ
54
* failing_address AHBSTAT Failing address register at IRQ
55
56
* * User return
57
* 0: print error onto terminal with printk and reenable AHBSTAT
58
* 1: just re-enable AHBSTAT
59
* 2: just print error
60
* 3: do nothing, let user do custom handling
61
62
extern
int (*ahbstat_error)(
63
int
minor,
64
struct
ahbstat_regs
*regs,
65
uint32_t status,
66
uint32_t failing_address);
67
68
/* Get Last received AHB Error
69
70
* \param minor Index used to indentify a specific AHBSTAT core
71
* \param status Status register at time of error IRQ was recevied
72
* \param address Failing address register at time of error IRQ
73
74
* Return
75
* 0: No error received
76
* 1: Error Received, last status and address stored into argument pointers
77
* -1: No such AHBSTAT device
78
79
extern
int
ahbstat_last_error(
int
minor, uint32_t *status, uint32_t *address);
80
81
/* Get AHBSTAT registers address from minor. Can also be used to check if
82
* AHBSTAT hardware is present.
83
84
* Return
85
* NULL returned if no such device
86
* non-zero Address to AHBSTAT register
87
88
extern
struct
ahbstat_regs
*ahbstat_get_regs(
int
minor);
89
90
/* Registers the AHBSTAT driver to the Driver Manager */
91
void
ahbstat_register_drv (
void
92
93
#ifdef __cplusplus
94
95
#endif
96
97
#endif
ahbstat_regs
Definition:
ahbstat.h:40
