RTEMS 6.1-rc4
152#ifndef __ACOPCODE_H__
153#define __ACOPCODE_H__
155#define MAX_EXTENDED_OPCODE 0x88
156#define NUM_EXTENDED_OPCODE (MAX_EXTENDED_OPCODE + 1)
157#define MAX_INTERNAL_OPCODE
158#define NUM_INTERNAL_OPCODE (MAX_INTERNAL_OPCODE + 1)
179#define ARGP_ACCESSFIELD_OP ARGP_LIST1 (ARGP_NAMESTRING)
180#define ARGP_ACQUIRE_OP ARGP_LIST2 (ARGP_SUPERNAME, ARGP_WORDDATA)
181#define ARGP_ADD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
182#define ARGP_ALIAS_OP ARGP_LIST2 (ARGP_NAMESTRING, ARGP_NAME)
183#define ARGP_ARG0 ARG_NONE
184#define ARGP_ARG1 ARG_NONE
185#define ARGP_ARG2 ARG_NONE
186#define ARGP_ARG3 ARG_NONE
187#define ARGP_ARG4 ARG_NONE
188#define ARGP_ARG5 ARG_NONE
189#define ARGP_ARG6 ARG_NONE
190#define ARGP_BANK_FIELD_OP ARGP_LIST6 (ARGP_PKGLENGTH, ARGP_NAMESTRING, ARGP_NAMESTRING,ARGP_TERMARG, ARGP_BYTEDATA, ARGP_FIELDLIST)
191#define ARGP_BIT_AND_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
192#define ARGP_BIT_NAND_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
193#define ARGP_BIT_NOR_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
194#define ARGP_BIT_NOT_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
195#define ARGP_BIT_OR_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
196#define ARGP_BIT_XOR_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
197#define ARGP_BREAK_OP ARG_NONE
198#define ARGP_BREAK_POINT_OP ARG_NONE
199#define ARGP_BUFFER_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_TERMARG, ARGP_BYTELIST)
200#define ARGP_BYTE_OP ARGP_LIST1 (ARGP_BYTEDATA)
201#define ARGP_BYTELIST_OP ARGP_LIST1 (ARGP_NAMESTRING)
202#define ARGP_COMMENT_OP ARGP_LIST2 (ARGP_BYTEDATA, ARGP_COMMENT)
203#define ARGP_CONCAT_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
204#define ARGP_CONCAT_RES_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
205#define ARGP_COND_REF_OF_OP ARGP_LIST2 (ARGP_SIMPLENAME, ARGP_TARGET)
206#define ARGP_CONNECTFIELD_OP ARGP_LIST1 (ARGP_NAMESTRING)
207#define ARGP_CONTINUE_OP ARG_NONE
208#define ARGP_COPY_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_SIMPLENAME)
209#define ARGP_CREATE_BIT_FIELD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_NAME)
210#define ARGP_CREATE_BYTE_FIELD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_NAME)
211#define ARGP_CREATE_DWORD_FIELD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_NAME)
212#define ARGP_CREATE_FIELD_OP ARGP_LIST4 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG, ARGP_NAME)
213#define ARGP_CREATE_QWORD_FIELD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_NAME)
214#define ARGP_CREATE_WORD_FIELD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_NAME)
215#define ARGP_DATA_REGION_OP ARGP_LIST4 (ARGP_NAME, ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG)
216#define ARGP_DEBUG_OP ARG_NONE
217#define ARGP_DECREMENT_OP ARGP_LIST1 (ARGP_SUPERNAME)
218#define ARGP_DEREF_OF_OP ARGP_LIST1 (ARGP_SUPERNAME)
219#define ARGP_DEVICE_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_NAME, ARGP_OBJLIST)
220#define ARGP_DIVIDE_OP ARGP_LIST4 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET, ARGP_TARGET)
221#define ARGP_DWORD_OP ARGP_LIST1 (ARGP_DWORDDATA)
222#define ARGP_ELSE_OP ARGP_LIST2 (ARGP_PKGLENGTH, ARGP_TERMLIST)
223#define ARGP_EVENT_OP ARGP_LIST1 (ARGP_NAME)
224#define ARGP_EXTERNAL_OP ARGP_LIST3 (ARGP_NAME, ARGP_BYTEDATA, ARGP_BYTEDATA)
225#define ARGP_FATAL_OP ARGP_LIST3 (ARGP_BYTEDATA, ARGP_DWORDDATA, ARGP_TERMARG)
226#define ARGP_FIELD_OP ARGP_LIST4 (ARGP_PKGLENGTH, ARGP_NAMESTRING, ARGP_BYTEDATA, ARGP_FIELDLIST)
227#define ARGP_FIND_SET_LEFT_BIT_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
228#define ARGP_FIND_SET_RIGHT_BIT_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
229#define ARGP_FROM_BCD_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
230#define ARGP_IF_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_TERMARG, ARGP_TERMLIST)
231#define ARGP_INCREMENT_OP ARGP_LIST1 (ARGP_SUPERNAME)
232#define ARGP_INDEX_FIELD_OP ARGP_LIST5 (ARGP_PKGLENGTH, ARGP_NAMESTRING, ARGP_NAMESTRING,ARGP_BYTEDATA, ARGP_FIELDLIST)
233#define ARGP_INDEX_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
234#define ARGP_LAND_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
235#define ARGP_LEQUAL_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
236#define ARGP_LGREATER_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
237#define ARGP_LGREATEREQUAL_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
238#define ARGP_LLESS_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
239#define ARGP_LLESSEQUAL_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
240#define ARGP_LNOT_OP ARGP_LIST1 (ARGP_TERMARG)
241#define ARGP_LNOTEQUAL_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
242#define ARGP_LOAD_OP ARGP_LIST2 (ARGP_NAMESTRING, ARGP_SUPERNAME)
243#define ARGP_LOAD_TABLE_OP ARGP_LIST6 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG)
244#define ARGP_LOCAL0 ARG_NONE
245#define ARGP_LOCAL1 ARG_NONE
246#define ARGP_LOCAL2 ARG_NONE
247#define ARGP_LOCAL3 ARG_NONE
248#define ARGP_LOCAL4 ARG_NONE
249#define ARGP_LOCAL5 ARG_NONE
250#define ARGP_LOCAL6 ARG_NONE
251#define ARGP_LOCAL7 ARG_NONE
252#define ARGP_LOR_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TERMARG)
253#define ARGP_MATCH_OP ARGP_LIST6 (ARGP_TERMARG, ARGP_BYTEDATA, ARGP_TERMARG, ARGP_BYTEDATA, ARGP_TERMARG, ARGP_TERMARG)
254#define ARGP_METHOD_OP ARGP_LIST4 (ARGP_PKGLENGTH, ARGP_NAME, ARGP_BYTEDATA, ARGP_TERMLIST)
255#define ARGP_METHODCALL_OP ARGP_LIST1 (ARGP_NAMESTRING)
256#define ARGP_MID_OP ARGP_LIST4 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
257#define ARGP_MOD_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
258#define ARGP_MULTIPLY_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
259#define ARGP_MUTEX_OP ARGP_LIST2 (ARGP_NAME, ARGP_BYTEDATA)
260#define ARGP_NAME_OP ARGP_LIST2 (ARGP_NAME, ARGP_DATAOBJ)
261#define ARGP_NAMEDFIELD_OP ARGP_LIST1 (ARGP_NAMESTRING)
262#define ARGP_NAMEPATH_OP ARGP_LIST1 (ARGP_NAMESTRING)
263#define ARGP_NOOP_OP ARG_NONE
264#define ARGP_NOTIFY_OP ARGP_LIST2 (ARGP_SUPERNAME, ARGP_TERMARG)
265#define ARGP_OBJECT_TYPE_OP ARGP_LIST1 (ARGP_SIMPLENAME)
266#define ARGP_ONE_OP ARG_NONE
267#define ARGP_ONES_OP ARG_NONE
268#define ARGP_PACKAGE_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_BYTEDATA, ARGP_DATAOBJLIST)
269#define ARGP_POWER_RES_OP ARGP_LIST5 (ARGP_PKGLENGTH, ARGP_NAME, ARGP_BYTEDATA, ARGP_WORDDATA, ARGP_OBJLIST)
270#define ARGP_PROCESSOR_OP ARGP_LIST6 (ARGP_PKGLENGTH, ARGP_NAME, ARGP_BYTEDATA, ARGP_DWORDDATA, ARGP_BYTEDATA, ARGP_OBJLIST)
271#define ARGP_QWORD_OP ARGP_LIST1 (ARGP_QWORDDATA)
272#define ARGP_REF_OF_OP ARGP_LIST1 (ARGP_SIMPLENAME)
273#define ARGP_REGION_OP ARGP_LIST4 (ARGP_NAME, ARGP_BYTEDATA, ARGP_TERMARG, ARGP_TERMARG)
274#define ARGP_RELEASE_OP ARGP_LIST1 (ARGP_SUPERNAME)
275#define ARGP_RESERVEDFIELD_OP ARGP_LIST1 (ARGP_NAMESTRING)
276#define ARGP_RESET_OP ARGP_LIST1 (ARGP_SUPERNAME)
277#define ARGP_RETURN_OP ARGP_LIST1 (ARGP_TERMARG)
278#define ARGP_REVISION_OP ARG_NONE
279#define ARGP_SCOPE_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_NAME, ARGP_TERMLIST)
280#define ARGP_SERIALFIELD_OP ARGP_LIST1 (ARGP_NAMESTRING)
281#define ARGP_SHIFT_LEFT_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
282#define ARGP_SHIFT_RIGHT_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
283#define ARGP_SIGNAL_OP ARGP_LIST1 (ARGP_SUPERNAME)
284#define ARGP_SIZE_OF_OP ARGP_LIST1 (ARGP_SUPERNAME)
285#define ARGP_SLEEP_OP ARGP_LIST1 (ARGP_TERMARG)
286#define ARGP_STALL_OP ARGP_LIST1 (ARGP_TERMARG)
287#define ARGP_STATICSTRING_OP ARGP_LIST1 (ARGP_NAMESTRING)
288#define ARGP_STORE_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_SUPERNAME)
289#define ARGP_STRING_OP ARGP_LIST1 (ARGP_CHARLIST)
290#define ARGP_SUBTRACT_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
291#define ARGP_THERMAL_ZONE_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_NAME, ARGP_OBJLIST)
292#define ARGP_TIMER_OP ARG_NONE
293#define ARGP_TO_BCD_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
294#define ARGP_TO_BUFFER_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
295#define ARGP_TO_DEC_STR_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
296#define ARGP_TO_HEX_STR_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
297#define ARGP_TO_INTEGER_OP ARGP_LIST2 (ARGP_TERMARG, ARGP_TARGET)
298#define ARGP_TO_STRING_OP ARGP_LIST3 (ARGP_TERMARG, ARGP_TERMARG, ARGP_TARGET)
299#define ARGP_UNLOAD_OP ARGP_LIST1 (ARGP_SUPERNAME)
300#define ARGP_VAR_PACKAGE_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_TERMARG, ARGP_DATAOBJLIST)
301#define ARGP_WAIT_OP ARGP_LIST2 (ARGP_SUPERNAME, ARGP_TERMARG)
302#define ARGP_WHILE_OP ARGP_LIST3 (ARGP_PKGLENGTH, ARGP_TERMARG, ARGP_TERMLIST)
303#define ARGP_WORD_OP ARGP_LIST1 (ARGP_WORDDATA)
304#define ARGP_ZERO_OP ARG_NONE
314#define ARGI_ACCESSFIELD_OP ARGI_INVALID_OPCODE
315#define ARGI_ACQUIRE_OP ARGI_LIST2 (ARGI_MUTEX, ARGI_INTEGER)
316#define ARGI_ADD_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
317#define ARGI_ALIAS_OP ARGI_INVALID_OPCODE
318#define ARGI_ARG0 ARG_NONE
319#define ARGI_ARG1 ARG_NONE
320#define ARGI_ARG2 ARG_NONE
321#define ARGI_ARG3 ARG_NONE
322#define ARGI_ARG4 ARG_NONE
323#define ARGI_ARG5 ARG_NONE
324#define ARGI_ARG6 ARG_NONE
325#define ARGI_BANK_FIELD_OP ARGI_LIST1 (ARGI_INTEGER)
326#define ARGI_BIT_AND_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
327#define ARGI_BIT_NAND_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
328#define ARGI_BIT_NOR_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
329#define ARGI_BIT_NOT_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_TARGETREF)
330#define ARGI_BIT_OR_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
331#define ARGI_BIT_XOR_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
332#define ARGI_BREAK_OP ARG_NONE
333#define ARGI_BREAK_POINT_OP ARG_NONE
334#define ARGI_BUFFER_OP ARGI_LIST1 (ARGI_INTEGER)
335#define ARGI_BYTE_OP ARGI_INVALID_OPCODE
336#define ARGI_BYTELIST_OP ARGI_INVALID_OPCODE
337#define ARGI_COMMENT_OP ARGI_INVALID_OPCODE
338#define ARGI_CONCAT_OP ARGI_LIST3 (ARGI_ANYTYPE, ARGI_ANYTYPE, ARGI_TARGETREF)
339#define ARGI_CONCAT_RES_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_BUFFER, ARGI_TARGETREF)
340#define ARGI_COND_REF_OF_OP ARGI_LIST2 (ARGI_OBJECT_REF, ARGI_TARGETREF)
341#define ARGI_CONNECTFIELD_OP ARGI_INVALID_OPCODE
342#define ARGI_CONTINUE_OP ARGI_INVALID_OPCODE
343#define ARGI_COPY_OP ARGI_LIST2 (ARGI_ANYTYPE, ARGI_SIMPLE_TARGET)
344#define ARGI_CREATE_BIT_FIELD_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_INTEGER, ARGI_REFERENCE)
345#define ARGI_CREATE_BYTE_FIELD_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_INTEGER, ARGI_REFERENCE)
346#define ARGI_CREATE_DWORD_FIELD_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_INTEGER, ARGI_REFERENCE)
347#define ARGI_CREATE_FIELD_OP ARGI_LIST4 (ARGI_BUFFER, ARGI_INTEGER, ARGI_INTEGER, ARGI_REFERENCE)
348#define ARGI_CREATE_QWORD_FIELD_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_INTEGER, ARGI_REFERENCE)
349#define ARGI_CREATE_WORD_FIELD_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_INTEGER, ARGI_REFERENCE)
350#define ARGI_DATA_REGION_OP ARGI_LIST3 (ARGI_STRING, ARGI_STRING, ARGI_STRING)
351#define ARGI_DEBUG_OP ARG_NONE
352#define ARGI_DECREMENT_OP ARGI_LIST1 (ARGI_TARGETREF)
353#define ARGI_DEREF_OF_OP ARGI_LIST1 (ARGI_REF_OR_STRING)
354#define ARGI_DEVICE_OP ARGI_INVALID_OPCODE
355#define ARGI_DIVIDE_OP ARGI_LIST4 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF, ARGI_TARGETREF)
356#define ARGI_DWORD_OP ARGI_INVALID_OPCODE
357#define ARGI_ELSE_OP ARGI_INVALID_OPCODE
358#define ARGI_EVENT_OP ARGI_INVALID_OPCODE
359#define ARGI_EXTERNAL_OP ARGI_LIST3 (ARGI_STRING, ARGI_INTEGER, ARGI_INTEGER)
360#define ARGI_FATAL_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_INTEGER)
361#define ARGI_FIELD_OP ARGI_INVALID_OPCODE
362#define ARGI_FIND_SET_LEFT_BIT_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_TARGETREF)
363#define ARGI_FIND_SET_RIGHT_BIT_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_TARGETREF)
364#define ARGI_FROM_BCD_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_FIXED_TARGET)
365#define ARGI_IF_OP ARGI_INVALID_OPCODE
366#define ARGI_INCREMENT_OP ARGI_LIST1 (ARGI_TARGETREF)
367#define ARGI_INDEX_FIELD_OP ARGI_INVALID_OPCODE
368#define ARGI_INDEX_OP ARGI_LIST3 (ARGI_COMPLEXOBJ, ARGI_INTEGER, ARGI_TARGETREF)
369#define ARGI_LAND_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_INTEGER)
370#define ARGI_LEQUAL_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_COMPUTEDATA)
371#define ARGI_LGREATER_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_COMPUTEDATA)
372#define ARGI_LGREATEREQUAL_OP ARGI_INVALID_OPCODE
373#define ARGI_LLESS_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_COMPUTEDATA)
374#define ARGI_LLESSEQUAL_OP ARGI_INVALID_OPCODE
375#define ARGI_LNOT_OP ARGI_LIST1 (ARGI_INTEGER)
376#define ARGI_LNOTEQUAL_OP ARGI_INVALID_OPCODE
377#define ARGI_LOAD_OP ARGI_LIST2 (ARGI_REGION_OR_BUFFER,ARGI_TARGETREF)
378#define ARGI_LOAD_TABLE_OP ARGI_LIST6 (ARGI_STRING, ARGI_STRING, ARGI_STRING, ARGI_STRING, ARGI_STRING, ARGI_ANYTYPE)
379#define ARGI_LOCAL0 ARG_NONE
380#define ARGI_LOCAL1 ARG_NONE
381#define ARGI_LOCAL2 ARG_NONE
382#define ARGI_LOCAL3 ARG_NONE
383#define ARGI_LOCAL4 ARG_NONE
384#define ARGI_LOCAL5 ARG_NONE
385#define ARGI_LOCAL6 ARG_NONE
386#define ARGI_LOCAL7 ARG_NONE
387#define ARGI_LOR_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_INTEGER)
388#define ARGI_MATCH_OP ARGI_LIST6 (ARGI_PACKAGE, ARGI_INTEGER, ARGI_COMPUTEDATA, ARGI_INTEGER,ARGI_COMPUTEDATA,ARGI_INTEGER)
389#define ARGI_METHOD_OP ARGI_INVALID_OPCODE
390#define ARGI_METHODCALL_OP ARGI_INVALID_OPCODE
391#define ARGI_MID_OP ARGI_LIST4 (ARGI_BUFFER_OR_STRING,ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
392#define ARGI_MOD_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
393#define ARGI_MULTIPLY_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
394#define ARGI_MUTEX_OP ARGI_INVALID_OPCODE
395#define ARGI_NAME_OP ARGI_INVALID_OPCODE
396#define ARGI_NAMEDFIELD_OP ARGI_INVALID_OPCODE
397#define ARGI_NAMEPATH_OP ARGI_INVALID_OPCODE
398#define ARGI_NOOP_OP ARG_NONE
399#define ARGI_NOTIFY_OP ARGI_LIST2 (ARGI_DEVICE_REF, ARGI_INTEGER)
400#define ARGI_OBJECT_TYPE_OP ARGI_LIST1 (ARGI_ANYTYPE)
401#define ARGI_ONE_OP ARG_NONE
402#define ARGI_ONES_OP ARG_NONE
403#define ARGI_PACKAGE_OP ARGI_LIST1 (ARGI_INTEGER)
404#define ARGI_POWER_RES_OP ARGI_INVALID_OPCODE
405#define ARGI_PROCESSOR_OP ARGI_INVALID_OPCODE
406#define ARGI_QWORD_OP ARGI_INVALID_OPCODE
407#define ARGI_REF_OF_OP ARGI_LIST1 (ARGI_OBJECT_REF)
408#define ARGI_REGION_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_INTEGER)
409#define ARGI_RELEASE_OP ARGI_LIST1 (ARGI_MUTEX)
410#define ARGI_RESERVEDFIELD_OP ARGI_INVALID_OPCODE
411#define ARGI_RESET_OP ARGI_LIST1 (ARGI_EVENT)
412#define ARGI_RETURN_OP ARGI_INVALID_OPCODE
413#define ARGI_REVISION_OP ARG_NONE
414#define ARGI_SCOPE_OP ARGI_INVALID_OPCODE
415#define ARGI_SERIALFIELD_OP ARGI_INVALID_OPCODE
416#define ARGI_SHIFT_LEFT_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
417#define ARGI_SHIFT_RIGHT_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
418#define ARGI_SIGNAL_OP ARGI_LIST1 (ARGI_EVENT)
419#define ARGI_SIZE_OF_OP ARGI_LIST1 (ARGI_DATAOBJECT)
420#define ARGI_SLEEP_OP ARGI_LIST1 (ARGI_INTEGER)
421#define ARGI_STALL_OP ARGI_LIST1 (ARGI_INTEGER)
422#define ARGI_STATICSTRING_OP ARGI_INVALID_OPCODE
423#define ARGI_STORE_OP ARGI_LIST2 (ARGI_DATAREFOBJ, ARGI_STORE_TARGET)
424#define ARGI_STRING_OP ARGI_INVALID_OPCODE
425#define ARGI_SUBTRACT_OP ARGI_LIST3 (ARGI_INTEGER, ARGI_INTEGER, ARGI_TARGETREF)
426#define ARGI_THERMAL_ZONE_OP ARGI_INVALID_OPCODE
427#define ARGI_TIMER_OP ARG_NONE
428#define ARGI_TO_BCD_OP ARGI_LIST2 (ARGI_INTEGER, ARGI_FIXED_TARGET)
429#define ARGI_TO_BUFFER_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_FIXED_TARGET)
430#define ARGI_TO_DEC_STR_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_FIXED_TARGET)
431#define ARGI_TO_HEX_STR_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_FIXED_TARGET)
432#define ARGI_TO_INTEGER_OP ARGI_LIST2 (ARGI_COMPUTEDATA,ARGI_FIXED_TARGET)
433#define ARGI_TO_STRING_OP ARGI_LIST3 (ARGI_BUFFER, ARGI_INTEGER, ARGI_FIXED_TARGET)
434#define ARGI_UNLOAD_OP ARGI_LIST1 (ARGI_DDBHANDLE)
435#define ARGI_VAR_PACKAGE_OP ARGI_LIST1 (ARGI_INTEGER)
436#define ARGI_WAIT_OP ARGI_LIST2 (ARGI_EVENT, ARGI_INTEGER)
437#define ARGI_WHILE_OP ARGI_INVALID_OPCODE
438#define ARGI_WORD_OP ARGI_INVALID_OPCODE
439#define ARGI_ZERO_OP ARG_NONE
