152#ifndef __ACGLOBAL_H__
153#define __ACGLOBAL_H__
170ACPI_INIT_GLOBAL (
char *, AcpiGbl_CDAT, NULL);
171ACPI_INIT_GLOBAL (UINT32, AcpiGbl_DsdtIndex, ACPI_INVALID_TABLE_INDEX);
172ACPI_INIT_GLOBAL (UINT32, AcpiGbl_FacsIndex, ACPI_INVALID_TABLE_INDEX);
173ACPI_INIT_GLOBAL (UINT32, AcpiGbl_XFacsIndex, ACPI_INVALID_TABLE_INDEX);
174ACPI_INIT_GLOBAL (UINT32, AcpiGbl_FadtIndex, ACPI_INVALID_TABLE_INDEX);
176#if (!ACPI_REDUCED_HARDWARE)
194ACPI_GLOBAL (UINT8, AcpiGbl_IntegerBitWidth);
195ACPI_GLOBAL (UINT8, AcpiGbl_IntegerByteWidth);
196ACPI_GLOBAL (UINT8, AcpiGbl_IntegerNybbleWidth);
218ACPI_GLOBAL (ACPI_SEMAPHORE, AcpiGbl_GlobalLockSemaphore);
219ACPI_GLOBAL (ACPI_SPINLOCK, AcpiGbl_GlobalLockPendingLock);
220ACPI_GLOBAL (UINT16, AcpiGbl_GlobalLockHandle);
221ACPI_GLOBAL (BOOLEAN, AcpiGbl_GlobalLockAcquired);
222ACPI_GLOBAL (BOOLEAN, AcpiGbl_GlobalLockPresent);
223ACPI_GLOBAL (BOOLEAN, AcpiGbl_GlobalLockPending);
229ACPI_GLOBAL (ACPI_SPINLOCK, AcpiGbl_GpeLock);
230ACPI_GLOBAL (ACPI_SPINLOCK, AcpiGbl_HardwareLock);
231ACPI_GLOBAL (ACPI_SPINLOCK, AcpiGbl_ReferenceCountLock);
235ACPI_GLOBAL (ACPI_MUTEX, AcpiGbl_OsiMutex);
250ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_NamespaceCache);
251ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_StateCache);
252ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_PsNodeCache);
253ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_PsNodeExtCache);
254ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_OperandCache);
258ACPI_INIT_GLOBAL (UINT32, AcpiGbl_StartupFlags, 0);
259ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_Shutdown, TRUE);
260ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_EarlyInitialization, TRUE);
265ACPI_GLOBAL (ACPI_EXCEPTION_HANDLER, AcpiGbl_ExceptionHandler);
266ACPI_GLOBAL (ACPI_INIT_HANDLER, AcpiGbl_InitHandler);
267ACPI_GLOBAL (ACPI_TABLE_HANDLER, AcpiGbl_TableHandler);
268ACPI_GLOBAL (
void *, AcpiGbl_TableHandlerContext);
269ACPI_GLOBAL (ACPI_INTERFACE_HANDLER, AcpiGbl_InterfaceHandler);
275ACPI_GLOBAL (UINT32, AcpiGbl_OwnerIdMask[ACPI_NUM_OWNERID_MASKS]);
276ACPI_GLOBAL (UINT8, AcpiGbl_LastOwnerIdIndex);
277ACPI_GLOBAL (UINT8, AcpiGbl_NextOwnerIdOffset);
281ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_NamespaceInitialized, FALSE);
285ACPI_GLOBAL (UINT32, AcpiGbl_OriginalMode);
286ACPI_GLOBAL (UINT32, AcpiGbl_NsLookupCount);
287ACPI_GLOBAL (UINT32, AcpiGbl_PsFindCount);
288ACPI_GLOBAL (UINT16, AcpiGbl_Pm1EnableRegisterSave);
289ACPI_GLOBAL (UINT8, AcpiGbl_DebuggerConfiguration);
290ACPI_GLOBAL (BOOLEAN, AcpiGbl_StepToNextCall);
291ACPI_GLOBAL (BOOLEAN, AcpiGbl_AcpiHardwarePresent);
292ACPI_GLOBAL (BOOLEAN, AcpiGbl_EventsInitialized);
298extern const char *AcpiGbl_SleepStateNames[ACPI_S_STATE_COUNT];
299extern const char *AcpiGbl_LowestDstateNames[ACPI_NUM_SxW_METHODS];
300extern const char *AcpiGbl_HighestDstateNames[ACPI_NUM_SxD_METHODS];
301extern const char *AcpiGbl_RegionTypes[ACPI_NUM_PREDEFINED_REGIONS];
302extern const char AcpiGbl_LowerHexDigits[];
303extern const char AcpiGbl_UpperHexDigits[];
308#ifdef ACPI_DBG_TRACK_ALLOCATIONS
311ACPI_GLOBAL (BOOLEAN, AcpiGbl_DisplayFinalMemStats);
312ACPI_GLOBAL (BOOLEAN, AcpiGbl_DisableMemTracking);
313ACPI_GLOBAL (BOOLEAN, AcpiGbl_VerboseLeakDump);
323#define NUM_PREDEFINED_NAMES 10
329extern const UINT8 AcpiGbl_NsProperties [ACPI_NUM_NS_TYPES];
332#ifdef ACPI_DEBUG_OUTPUT
333ACPI_GLOBAL (UINT32, AcpiGbl_CurrentNodeCount);
334ACPI_GLOBAL (UINT32, AcpiGbl_CurrentNodeSize);
335ACPI_GLOBAL (UINT32, AcpiGbl_MaxConcurrentNodeCount);
336ACPI_GLOBAL (ACPI_SIZE *, AcpiGbl_EntryStackPointer);
337ACPI_GLOBAL (ACPI_SIZE *, AcpiGbl_LowestStackPointer);
338ACPI_GLOBAL (UINT32, AcpiGbl_DeepestNesting);
339ACPI_INIT_GLOBAL (UINT32, AcpiGbl_NestingLevel, 0);
351ACPI_GLOBAL (UINT8, AcpiGbl_CmSingleStep);
357ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_CaptureComments, FALSE);
368ACPI_GLOBAL (UINT8, AcpiGbl_SleepTypeA);
369ACPI_GLOBAL (UINT8, AcpiGbl_SleepTypeB);
370ACPI_GLOBAL (UINT8, AcpiGbl_SleepTypeAS0);
371ACPI_GLOBAL (UINT8, AcpiGbl_SleepTypeBS0);
380#if (!ACPI_REDUCED_HARDWARE)
381ACPI_GLOBAL (UINT8, AcpiGbl_AllGpesInitialized);
384ACPI_GLOBAL (ACPI_GBL_EVENT_HANDLER, AcpiGbl_GlobalEventHandler);
385ACPI_GLOBAL (
void *, AcpiGbl_GlobalEventHandlerContext);
399ACPI_GLOBAL (UINT32, AcpiMethodCount);
400ACPI_GLOBAL (UINT32, AcpiGpeCount);
401ACPI_GLOBAL (UINT32, AcpiSciCount);
402ACPI_GLOBAL (UINT32, AcpiFixedEventCount[ACPI_NUM_FIXED_EVENTS]);
406ACPI_GLOBAL (UINT32, AcpiGbl_OriginalDbgLevel);
407ACPI_GLOBAL (UINT32, AcpiGbl_OriginalDbgLayer);
416ACPI_INIT_GLOBAL (UINT8, AcpiGbl_DbOutputFlags, ACPI_DB_CONSOLE_OUTPUT);
419#ifdef ACPI_DISASSEMBLER
423ACPI_INIT_GLOBAL (UINT8, AcpiGbl_NoResourceDisassembly, FALSE);
424ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_IgnoreNoopOperator, FALSE);
425ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_CstyleDisassembly, TRUE);
426ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_ForceAmlDisassembly, FALSE);
427ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_DmOpt_Verbose, TRUE);
428ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_DmEmitExternalOpcodes, FALSE);
429ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_DoDisassemblerOptimizations, TRUE);
432ACPI_GLOBAL (BOOLEAN, AcpiGbl_DmOpt_Disasm);
433ACPI_GLOBAL (BOOLEAN, AcpiGbl_DmOpt_Listing);
434ACPI_GLOBAL (BOOLEAN, AcpiGbl_NumExternalMethods);
435ACPI_GLOBAL (UINT32, AcpiGbl_ResolvedExternalMethods);
441ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_AbortMethod, FALSE);
442ACPI_INIT_GLOBAL (ACPI_THREAD_ID, AcpiGbl_DbThreadId, ACPI_INVALID_THREAD_ID);
443ACPI_INIT_GLOBAL (UINT32, AcpiGbl_NextCmdNum, 1);
445ACPI_GLOBAL (BOOLEAN, AcpiGbl_DbOpt_NoIniMethods);
446ACPI_GLOBAL (BOOLEAN, AcpiGbl_DbOpt_NoRegionSupport);
447ACPI_GLOBAL (BOOLEAN, AcpiGbl_DbOutputToFile);
448ACPI_GLOBAL (
char *, AcpiGbl_DbBuffer);
449ACPI_GLOBAL (
char *, AcpiGbl_DbFilename);
450ACPI_GLOBAL (UINT32, AcpiGbl_DbDebugLevel);
451ACPI_GLOBAL (UINT32, AcpiGbl_DbConsoleDebugLevel);
453ACPI_GLOBAL (BOOLEAN, AcpiGbl_DbTerminateLoop);
454ACPI_GLOBAL (BOOLEAN, AcpiGbl_DbThreadsTerminated);
455ACPI_GLOBAL (
char *, AcpiGbl_DbArgs[ACPI_DEBUGGER_MAX_ARGS]);
456ACPI_GLOBAL (ACPI_OBJECT_TYPE, AcpiGbl_DbArgTypes[ACPI_DEBUGGER_MAX_ARGS]);
460ACPI_GLOBAL (
char, AcpiGbl_DbParsedBuf[ACPI_DB_LINE_BUFFER_SIZE]);
461ACPI_GLOBAL (
char, AcpiGbl_DbScopeBuf[ACPI_DB_LINE_BUFFER_SIZE]);
462ACPI_GLOBAL (
char, AcpiGbl_DbDebugFilename[ACPI_DB_LINE_BUFFER_SIZE]);
466ACPI_GLOBAL (UINT16, AcpiGbl_ObjTypeCount[ACPI_TOTAL_TYPES]);
467ACPI_GLOBAL (UINT16, AcpiGbl_NodeTypeCount[ACPI_TOTAL_TYPES]);
468ACPI_GLOBAL (UINT16, AcpiGbl_ObjTypeCountMisc);
469ACPI_GLOBAL (UINT16, AcpiGbl_NodeTypeCountMisc);
470ACPI_GLOBAL (UINT32, AcpiGbl_NumNodes);
471ACPI_GLOBAL (UINT32, AcpiGbl_NumObjects);
474#if defined (ACPI_DISASSEMBLER) || defined (ACPI_ASL_COMPILER)
475ACPI_GLOBAL (
const char, *AcpiGbl_PldPanelList[]);
476ACPI_GLOBAL (
const char, *AcpiGbl_PldVerticalPositionList[]);
477ACPI_GLOBAL (
const char, *AcpiGbl_PldHorizontalPositionList[]);
478ACPI_GLOBAL (
const char, *AcpiGbl_PldShapeList[]);
479ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_DisasmFlag, FALSE);
491#ifdef ACPI_ASL_COMPILER
492ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentInlineComment, NULL);
493ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentEndNodeComment, NULL);
494ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentOpenBraceComment, NULL);
495ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentCloseBraceComment, NULL);
497ACPI_INIT_GLOBAL (
char *, AcpiGbl_RootFilename, NULL);
498ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentFilename, NULL);
499ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentParentFilename, NULL);
500ACPI_INIT_GLOBAL (
char *, AcpiGbl_CurrentIncludeFilename, NULL);
514ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_RegCommentCache);
515ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_CommentAddrCache);
516ACPI_GLOBAL (ACPI_CACHE_T *, AcpiGbl_FileCache);
518ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_DebugAslConversion, FALSE);
519ACPI_INIT_GLOBAL (ACPI_FILE, AcpiGbl_ConvDebugFile, NULL);
520ACPI_GLOBAL (
char, AcpiGbl_TableSig[4]);
523#ifdef ACPI_APPLICATION
524ACPI_INIT_GLOBAL (ACPI_FILE, AcpiGbl_DebugFile, NULL);
525ACPI_INIT_GLOBAL (ACPI_FILE, AcpiGbl_OutputFile, NULL);
526ACPI_INIT_GLOBAL (BOOLEAN, AcpiGbl_DebugTimeout, FALSE);
530ACPI_GLOBAL (ACPI_SPINLOCK, AcpiGbl_PrintLock);
531ACPI_GLOBAL (
char, AcpiGbl_PrintBuffer[1024]);
Definition: aclocal.h:965
Definition: aclocal.h:1262
Definition: aclocal.h:1508
Definition: aclocal.h:1486
Definition: aclocal.h:1120
Definition: aclocal.h:745
Definition: aclocal.h:752
Definition: aclocal.h:773
Definition: aclocal.h:914
Definition: aclocal.h:690
Definition: aclocal.h:709
Definition: aclocal.h:1379
Definition: actypes.h:1494
Definition: aclocal.h:240
Definition: aclocal.h:294
Definition: aclocal.h:984
Definition: aclocal.h:1516
Definition: actypes.h:1179
Definition: aclocal.h:206
Definition: aclocal.h:616
Definition: aclocal.h:341
Definition: aclocal.h:879
Definition: acobject.h:626
Definition: aclocal.h:1194
