#define | Xil_AssertVoid(Expression) |
| This assert macro is to be used for void functions. This in conjunction with the Xil_AssertWait boolean can be used to accommodate tests so that asserts which fail allow execution to continue.
#define | Xil_AssertNonvoid(Expression) |
| This assert macro is to be used for functions that do return a value. This in conjunction with the Xil_AssertWait boolean can be used to accommodate tests so that asserts which fail allow execution to continue.
#define | Xil_AssertVoidAlways() |
| Always assert. This assert macro is to be used for void functions. Use for instances where an assert should always occur.
#define | Xil_AssertNonvoidAlways() |
| Always assert. This assert macro is to be used for functions that do return a value. Use for instances where an assert should always occur.
void | XNullHandler (void *NullParameter) |
| Null handler function. This follows the XInterruptHandler signature for interrupt handlers. It can be used to assign a null handler (a stub) to an interrupt controller vector table.
void | Xil_AssertSetCallback (Xil_AssertCallback Routine) |
| Set up a callback function to be invoked when an assert occurs. If a callback is already installed, then it will be replaced.
