RTEMS 6.1-rc2
x86_64.h
1/*
2 * Copyright (c) 2018.
3 * Amaan Cheval <amaan.cheval@gmail.com>
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 *
14 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24 * SUCH DAMAGE.
25 */
26
27#ifndef _RTEMS_SCORE_X86_64_H
28#define _RTEMS_SCORE_X86_64_H
29
30#ifdef __cplusplus
31extern "C" {
32#endif
33
34#define CPU_NAME "x86-64"
35#define CPU_MODEL_NAME "amd64"
36
37#define COM1_BASE_IO 0x3F8
38#define COM1_CLOCK_RATE (115200 * 16)
39
40#define EFLAGS_INTR_ENABLE 0x200
41
42#if DEBUG
43#define DBG_PRINTF(format, args...) \
44 printf(format, ## args)
45#else
46#define DBG_PRINTF(format, args...)
47#endif
48
49#ifdef __cplusplus
50}
51#endif
52
53#endif /* _RTEMS_SCORE_X86_64_H */
