RTEMS 6.1-rc2
wkspacesupport.h
2
12/*
13 * Copyright (C) 2020 embedded brains GmbH & Co. KG
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_CONFDEFS_WKSPACESUPPORT_H
38#define _RTEMS_CONFDEFS_WKSPACESUPPORT_H
39
40#ifndef __CONFIGURATION_TEMPLATE_h
41#error "Do not include this file directly, use <rtems/confdefs.h> instead"
42#endif
43
44#ifdef CONFIGURE_INIT
45
46#include <rtems/score/heap.h>
47
48#define _Configure_Zero_or_one( _number ) ( ( _number ) != 0 ? 1 : 0 )
49
50#define _Configure_Align_up( _val, _align ) \
51 ( ( ( _val ) + ( _align ) - 1) - ( ( _val ) + ( _align ) - 1 ) % ( _align ) )
52
53#define _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
54 _Configure_Align_up( sizeof( Heap_Block ), CPU_HEAP_ALIGNMENT )
55
56#define _Configure_From_workspace( _size ) \
57 ( (uintptr_t) ( _Configure_Zero_or_one( _size ) \
58 * _Configure_Align_up( \
59 _size + HEAP_BLOCK_HEADER_SIZE, \
60 _CONFIGURE_HEAP_MIN_BLOCK_SIZE \
61 ) ) )
62
63#endif /* CONFIGURE_INIT */
64
65#endif /* _RTEMS_CONFDEFS_WKSPACESUPPORT_H */
This header file provides interfaces of the Heap Handler which are used by the implementation and the...
