RTEMS 6.1-rc2
wkspacedata.h
2
13/*
14 * Copyright (C) 2020 embedded brains GmbH & Co. KG
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_WKSPACEDATA_H
39#define _RTEMS_SCORE_WKSPACEDATA_H
40
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
47struct Heap_Control;
48
69extern const uintptr_t _Workspace_Size;
70
77extern const bool _Workspace_Is_unified;
78
85
93
101extern struct Heap_Control *( * const _Workspace_Malloc_initializer )( void );
102
105#ifdef __cplusplus
106}
107#endif
108
109#endif /* _RTEMS_SCORE_WKSPACEDATA_H */
This header file provides basic definitions used by the API and the implementation.
struct Heap_Control * _Workspace_Malloc_initialize_separate(void)
Initializes the C Program Heap separated from the RTEMS Workspace.
Definition: mallocinitmulti.c:46
Indicates if the workspace and C program heap are unified.
Definition: wkspaceisunifieddefault.c:43
struct Heap_Control *(*const _Workspace_Malloc_initializer)(void)
This constant provides the C Program Heap initialization handler.
Definition: wkspacemallocinitdefault.c:43
The workspace size in bytes.
struct Heap_Control * _Workspace_Malloc_initialize_unified(void)
Initializes the C Program Heap so that it is unified with the RTEMS Workspace.
Definition: wkspacemallocinitunified.c:44
Control block used to manage a heap.
Definition: heap.h:339
