RTEMS 6.1-rc2
vmeintr.h
2
13/*
14 * COPYRIGHT (c) 1989-1999.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef _RTEMS_VMEINTR_H
40#define _RTEMS_VMEINTR_H
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46/*
47 * This defines the mask which is used to determine which
48 * interrupt levels are affected by a call to this package.
49 * The LSB corresponds to VME interrupt 0 and the MSB
50 * to VME interrupt 7.
51 *
52 */
53
54typedef uint8_t VME_interrupt_Mask;
55
56/*
57 * VME_interrupt_Disable
58 *
59 */
60
61void VME_interrupt_Disable (
62 VME_interrupt_Mask mask /* IN */
63);
64
65/*
66 * VME_interrupt_Disable
67 *
68 */
69
70void VME_interrupt_Enable (
71 VME_interrupt_Mask mask /* IN */
72);
73
74#ifdef __cplusplus
75}
76#endif
77
78#endif /* end of include file */
