RTEMS 6.1-rc2
vgacons.h
2
11/*
12 * COPYRIGHT (c) 1989-2011.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _VGACONS_H_
38#define _VGACONS_H_
39
40#include <libchip/serial.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46/*
47 * This is the ASCII for "PC" in the upper word and 0386
48 * in the lower which should be unique enough to
49 * distinguish this type of serial device from others.
50 */
51
52#define VGA_CONSOLE 0x80670386
53
54#define VGACONS_UART0 0
55#define VGACONS_UART1 1
56
57bool vgacons_probe( int minor );
58
59/*
60 * Driver function table
61 */
62extern const console_fns vgacons_fns;
63
64#ifdef __cplusplus
65}
66#endif
67
68#endif /* _VGACONS_H_ */
The generic libchip serial driver interface.
Definition: serial.h:95
