RTEMS 6.1-rc2
versal-uart.h
2
11/*
12 * Copyright (C) 2021 Gedare Bloom <gedare@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_XILINX_VERSAL_UART_H
37#define LIBBSP_ARM_XILINX_VERSAL_UART_H
38
39#include <rtems/termiostypes.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
54typedef struct {
56 volatile struct versal_uart *regs;
57 volatile size_t tx_queued;
58 volatile bool transmitting;
59 bool first_send;
62
63extern const rtems_termios_device_handler versal_uart_handler;
64
65#define VERSAL_UART_DEFAULT_BAUD 115200
66
67int versal_uart_initialize(rtems_termios_device_context *base);
68
69int versal_uart_read_polled(rtems_termios_device_context *base);
70
71void versal_uart_write_polled(
73 char c
74);
75
80
81int versal_cal_baud_rate(
82 uint32_t baudrate,
83 uint32_t maxerror,
84 uint32_t* ibdiv,
85 uint32_t* fbdiv
86);
87
88#ifdef __cplusplus
89}
90#endif /* __cplusplus */
91
92#endif /* LIBBSP_ARM_XILINX_VERSAL_UART_H */
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
Definition: versal-uart.h:54
Definition: versal-uart-regs.h:51
void versal_uart_reset_tx_flush(rtems_termios_device_context *base)
Definition: versal-uart-polled.c:180
