44#ifndef LIBBSP_ARM_XILINX_VERSAL_UART_REGS_H
45#define LIBBSP_ARM_XILINX_VERSAL_UART_REGS_H
49#define VERSAL_UART_FIFO_DEPTH 64
53#define VERSAL_UARTDR_OE BSP_BIT32(11)
54#define VERSAL_UARTDR_BE BSP_BIT32(10)
55#define VERSAL_UARTDR_PE BSP_BIT32(9)
56#define VERSAL_UARTDR_FE BSP_BIT32(8)
57#define VERSAL_UARTDR_DATA(val) BSP_FLD32(val, 0, 7)
58#define VERSAL_UARTDR_DATA_GET(reg) BSP_FLD32GET(reg, 0, 7)
59#define VERSAL_UARTDR_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
60 uint32_t uartrsr_uartecr;
61#define VERSAL_UARTRSR_UARTECR_OE BSP_BIT32(3)
62#define VERSAL_UARTRSR_UARTECR_BE BSP_BIT32(2)
63#define VERSAL_UARTRSR_UARTECR_PE BSP_BIT32(1)
64#define VERSAL_UARTRSR_UARTECR_FE BSP_BIT32(0)
65 uint32_t reserved_08[4];
67#define VERSAL_UARTFR_RI BSP_BIT32(8)
68#define VERSAL_UARTFR_TXFE BSP_BIT32(7)
69#define VERSAL_UARTFR_RXFF BSP_BIT32(6)
70#define VERSAL_UARTFR_TXFF BSP_BIT32(5)
71#define VERSAL_UARTFR_RXFE BSP_BIT32(4)
72#define VERSAL_UARTFR_BUSY BSP_BIT32(3)
73#define VERSAL_UARTFR_DCD BSP_BIT32(2)
74#define VERSAL_UARTFR_DSR BSP_BIT32(1)
75#define VERSAL_UARTFR_CTS BSP_BIT32(0)
78#define VERSAL_UARTILPR_ILPDVSR(val) BSP_FLD32(val, 0, 7)
79#define VERSAL_UARTILPR_ILPDVSR_GET(reg) BSP_FLD32GET(reg, 0, 7)
80#define VERSAL_UARTILPR_ILPDVSR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
82#define VERSAL_UARTIBRD_BAUD_DIVINT(val) BSP_FLD32(val, 0, 15)
83#define VERSAL_UARTIBRD_BAUD_DIVINT_GET(reg) BSP_FLD32GET(reg, 0, 15)
84#define VERSAL_UARTIBRD_BAUD_DIVINT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
86#define VERSAL_UARTFBRD_BAUD_DIVFRAC(val) BSP_FLD32(val, 0, 5)
87#define VERSAL_UARTFBRD_BAUD_DIVFRAC_GET(reg) BSP_FLD32GET(reg, 0, 5)
88#define VERSAL_UARTFBRD_BAUD_DIVFRAC_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
90#define VERSAL_UARTLCR_H_SPS BSP_BIT32(7)
91#define VERSAL_UARTLCR_H_WLEN(val) BSP_FLD32(val, 5, 6)
92#define VERSAL_UARTLCR_H_WLEN_GET(reg) BSP_FLD32GET(reg, 5, 6)
93#define VERSAL_UARTLCR_H_WLEN_SET(reg, val) BSP_FLD32SET(reg, val, 5, 6)
94#define VERSAL_UARTLCR_H_WLEN_5 0x00U
95#define VERSAL_UARTLCR_H_WLEN_6 0x01U
96#define VERSAL_UARTLCR_H_WLEN_7 0x02U
97#define VERSAL_UARTLCR_H_WLEN_8 0x03U
98#define VERSAL_UARTLCR_H_FEN BSP_BIT32(4)
99#define VERSAL_UARTLCR_H_STP2 BSP_BIT32(3)
100#define VERSAL_UARTLCR_H_EPS BSP_BIT32(2)
101#define VERSAL_UARTLCR_H_PEN BSP_BIT32(1)
102#define VERSAL_UARTLCR_H_BRK BSP_BIT32(0)
104#define VERSAL_UARTCR_CTSEN BSP_BIT32(15)
105#define VERSAL_UARTCR_RTSEN BSP_BIT32(14)
106#define VERSAL_UARTCR_OUT2 BSP_BIT32(13)
107#define VERSAL_UARTCR_OUT1 BSP_BIT32(12)
108#define VERSAL_UARTCR_RTS BSP_BIT32(11)
109#define VERSAL_UARTCR_DTR BSP_BIT32(10)
110#define VERSAL_UARTCR_RXE BSP_BIT32(9)
111#define VERSAL_UARTCR_TXE BSP_BIT32(8)
112#define VERSAL_UARTCR_LBE BSP_BIT32(7)
113#define VERSAL_UARTCR_UARTEN BSP_BIT32(0)
115#define VERSAL_UARTIFLS_RXIFLSEL(val) BSP_FLD32(val, 3, 5)
116#define VERSAL_UARTIFLS_RXIFLSEL_GET(reg) BSP_FLD32GET(reg, 3, 5)
117#define VERSAL_UARTIFLS_RXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
118#define VERSAL_UARTIFLS_TXIFLSEL(val) BSP_FLD32(val, 0, 2)
119#define VERSAL_UARTIFLS_TXIFLSEL_GET(reg) BSP_FLD32GET(reg, 0, 2)
120#define VERSAL_UARTIFLS_TXIFLSEL_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
125#define VERSAL_UARTI_OEI BSP_BIT32(10)
126#define VERSAL_UARTI_BEI BSP_BIT32(9)
127#define VERSAL_UARTI_PEI BSP_BIT32(8)
128#define VERSAL_UARTI_FEI BSP_BIT32(7)
129#define VERSAL_UARTI_RTI BSP_BIT32(6)
130#define VERSAL_UARTI_TXI BSP_BIT32(5)
131#define VERSAL_UARTI_RXI BSP_BIT32(4)
132#define VERSAL_UARTI_DSRMI BSP_BIT32(3)
133#define VERSAL_UARTI_DCDMI BSP_BIT32(2)
134#define VERSAL_UARTI_CTSMI BSP_BIT32(1)
135#define VERSAL_UARTI_RIMI BSP_BIT32(0)
This header file provides utility macros for BSPs.
Definition: versal-uart-regs.h:51
