RTEMS
6.1-rc2
include
sys
utsname.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* COPYRIGHT (c) 1989-2011.
13
* On-Line Applications Research Corporation (OAR).
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef __POSIX_SYS_UTSNAME_h
38
#define __POSIX_SYS_UTSNAME_h
39
47
#ifdef __cplusplus
48
extern
"C"
49
#endif
50
51
52
* 4.4.1 Get System Name (Table 4-1), P1003.1b-1993, p. 90
53
54
* NOTE: The lengths of the strings in this structure are
55
* just long enough to reliably contain the RTEMS information.
56
* For example, the fields are not long enough to support
57
* Internet hostnames.
58
59
60
#ifdef _KERNEL
61
#define SYS_NMLN 48
/* uname(2) for the FreeBSD 1.1 ABI. */
62
#endif
63
64
#ifndef SYS_NMLN
65
#define SYS_NMLN 48
/* User can override. */
66
#endif
67
68
struct
utsname
69
char
sysname[SYS_NMLN];
/* Name of this implementation of the */
70
/* operating system */
71
char
nodename[SYS_NMLN];
/* Name of this node within an implementation */
72
/* specified communication network */
73
char
release[SYS_NMLN];
/* Current release level of this implementation */
74
char
version[SYS_NMLN];
/* Current version level of this release */
75
char
machine[SYS_NMLN];
/* Name of the hardware type on which the system */
76
/* is running */
77
78
84
int
uname
85
struct
utsname
*name
86
87
90
#ifdef __cplusplus
91
92
#endif
93
94
#endif
95
/* end of include file */
uname
int uname(struct utsname *name)
Get system name.
Definition:
utsname.c:53
utsname
Definition:
utsname.h:68
