RTEMS 6.1-rc2
umon.h
2
3/*
4 * umon.h - RTEMS specific interface to MicroMonitor.
5 *
6 * COPYRIGHT (c) 1989-2009.
7 * On-Line Applications Research Corporation (OAR).
8 *
9 * Modified by Fernando Nicodemos <fgnicodemos@terra.com.br>
10 * from NCB - Sistemas Embarcados Ltda. (Brazil)
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32*/
33
34#ifndef __rtems_umon_h
35#define __rtems_umon_h
36
37#include <umon/monlib.h>
38
39#ifdef __cplusplus
40extern "C" {
41#endif
42
49void rtems_umon_connect(void);
50
59void *rtems_bsp_get_umon_monptr(void);
60
71 const char *path
72);
73
81int umoncons_poll_read(int minor);
82
83#ifdef __cplusplus
84}
85#endif
86
87#endif /* __rtems_umon_h */
Used by both the monitor and the application that may reside on top of the monitor.
int rtems_initialize_tfs_filesystem(const char *path)
Initialize the TFS-RTEMS file system.
Definition: tfsDriver.c:127
