RTEMS 6.1-rc2
uartlite.h
2
11/*
12 * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
37#define LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
38
39#include <bspopts.h>
40#include <rtems/termiostypes.h>
41
42#include <dev/serial/uartlite_l.h>
43
44#ifdef __cplusplus
45extern "C" {
46#endif /* __cplusplus */
47
48typedef struct {
50 uintptr_t address;
51 uint32_t initial_baud;
52 uint32_t enabled;
53#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
54 struct rtems_termios_tty *tty;
55 bool transmitting;
56 size_t tx_queued;
57 uint32_t irq;
58#endif
60
61extern const rtems_termios_device_handler microblaze_uart_fns;
62
63#ifdef __cplusplus
64}
65#endif /* __cplusplus */
66
67#endif /* LIBBSP_MICROBLAZE_SHARED_UARTLITE_H */
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
Definition: termiostypes.h:94
Definition: uartlite.h:48
