RTEMS 6.1-rc2
tx3904.h
2
11/*
12 * COPYRIGHT (c) 1989-2012.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef __TX3904_h
38#define __TX3904_h
39
40/*
41 * Timer Base Addresses and Offsets
42 */
43
44#define TX3904_TIMER0_BASE 0xFFFFF000
45#define TX3904_TIMER1_BASE 0xFFFFF100
46#define TX3904_TIMER2_BASE 0xFFFFF200
47
48#define TX3904_TIMER_TCR 0x00
49#define TX3904_TIMER_TISR 0x04
50#define TX3904_TIMER_CPRA 0x08
51#define TX3904_TIMER_CPRB 0x0C
52#define TX3904_TIMER_ITMR 0x10
53#define TX3904_TIMER_CCDR 0x20
54#define TX3904_TIMER_PGMR 0x30
55#define TX3904_TIMER_WTMR 0x40
56#define TX3904_TIMER_TRR 0xF0
57
58#define TX3904_TIMER_READ( _base, _register ) \
59 *((volatile uint32_t*)((_base) + (_register)))
60
61#define TX3904_TIMER_WRITE( _base, _register, _value ) \
62 *((volatile uint32_t*)((_base) + (_register))) = (_value)
63
64#endif
