RTEMS 6.1-rc2
timestampimpl.h
2
12/*
13 * COPYRIGHT (c) 1989-2009.
14 * On-Line Applications Research Corporation (OAR).
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_TIMESTAMPIMPL_H
39#define _RTEMS_SCORE_TIMESTAMPIMPL_H
40
49
50#include <sys/time.h>
51
52#ifdef __cplusplus
53extern "C" {
54#endif
55
66static inline void _Timestamp_Set(
67 Timestamp_Control *_time,
68 time_t _seconds,
69 long _nanoseconds
70)
71{
72 struct timespec _ts;
73
74 _ts.tv_sec = _seconds;
75 _ts.tv_nsec = _nanoseconds;
76
77 *_time = tstosbt(_ts);
78}
79
89static inline void _Timestamp_Set_to_zero(
91)
92{
93 *_time = 0;
94}
95
108static inline bool _Timestamp_Less_than(
109 const Timestamp_Control *_lhs,
110 const Timestamp_Control *_rhs
111)
112{
113 return *_lhs < *_rhs;
114}
115
128static inline bool _Timestamp_Greater_than(
129 const Timestamp_Control *_lhs,
130 const Timestamp_Control *_rhs
131)
132{
133 return *_lhs > *_rhs;
134}
135
148static inline bool _Timestamp_Equal_to(
149 const Timestamp_Control *_lhs,
150 const Timestamp_Control *_rhs
151)
152{
153 return *_lhs == *_rhs;
154}
155
165static inline void _Timestamp_Add_to(
166 Timestamp_Control *_time,
167 const Timestamp_Control *_add
168)
169{
170 *_time += *_add;
171}
172
184static inline void _Timestamp_Subtract(
186 const Timestamp_Control *_end,
187 Timestamp_Control *_result
188)
189{
190 *_result = *_end - *_start;
191}
192
204static inline void _Timestamp_Divide(
205 const Timestamp_Control *_lhs,
206 const Timestamp_Control *_rhs,
207 uint32_t *_ival_percentage,
208 uint32_t *_fval_percentage
209)
210{
211 struct timespec _ts_left;
212 struct timespec _ts_right;
213
214 _ts_left = sbttots( *_lhs );
215 _ts_right = sbttots( *_rhs );
216
218 &_ts_left,
219 &_ts_right,
220 _ival_percentage,
221 _fval_percentage
222 );
223}
224
234static inline time_t _Timestamp_Get_seconds(
235 const Timestamp_Control *_time
236)
237{
238 return (*_time >> 32);
239}
240
250static inline uint32_t _Timestamp_Get_nanoseconds(
251 const Timestamp_Control *_time
252)
253{
254 struct timespec _ts;
255
256 _ts = sbttots( *_time );
257
258 return (uint32_t) _ts.tv_nsec;
259}
260
270static inline uint64_t _Timestamp_Get_as_nanoseconds(
271 const Timestamp_Control *_time
272)
273{
274 struct timespec _ts;
275
276 _ts = sbttots( *_time );
277
278 return _Timespec_Get_as_nanoseconds( &_ts );
279}
280
287static inline void _Timestamp_To_timespec(
288 const Timestamp_Control *_timestamp,
289 struct timespec *_timespec
290)
291{
292 *_timespec = sbttots( *_timestamp );
293}
294
301static inline void _Timestamp_To_timeval(
302 const Timestamp_Control *_timestamp,
303 struct timeval *_timeval
304)
305{
306 *_timeval = sbttotv( *_timestamp );
307}
308
309#ifdef __cplusplus
310}
311#endif
312
315#endif
316/* end of include file */
This header file provides basic definitions used by the API and the implementation.
void _Timespec_Divide(const struct timespec *lhs, const struct timespec *rhs, uint32_t *ival_percentage, uint32_t *fval_percentage)
Divides a timespec by another timespec.
Definition: timespecdivide.c:45
uint64_t _Timespec_Get_as_nanoseconds(const struct timespec *time)
Gets the timestamp as nanoseconds.
Definition: timespecgetasnanoseconds.c:44
int64_t Timestamp_Control
Definition: timestamp.h:76
void _start(void)
System start entry.
This header file provides interfaces of the Timestamp Handler which are used by the implementation an...
