RTEMS 6.1-rc2
priority.h File Reference
This header file provides interfaces of the process priority support. More...
#define PRI_ITHD   1 /* Interrupt thread. */
#define PRI_REALTIME   2 /* Real time process. */
#define PRI_TIMESHARE   3 /* Time sharing process. */
#define PRI_IDLE   4 /* Idle process. */
#define PRI_MIN   (0) /* Highest priority. */
#define PRI_MAX   (255) /* Lowest priority. */
#define PRI_MIN_ITHD   (PRI_MIN)
#define PRI_MAX_ITHD   (PRI_MIN_REALTIME - 1)
#define PI_REALTIME   (PRI_MIN_ITHD + 0)
#define PI_AV   (PRI_MIN_ITHD + 4)
#define PI_NET   (PRI_MIN_ITHD + 8)
#define PI_DISK   (PRI_MIN_ITHD + 12)
#define PI_TTY   (PRI_MIN_ITHD + 16)
#define PI_DULL   (PRI_MIN_ITHD + 20)
#define PI_SOFT   (PRI_MIN_ITHD + 24)
#define PI_SWI(x)   (PI_SOFT + (x) * RQ_PPQ)
#define PRI_MIN_REALTIME   (48)
#define PRI_MAX_REALTIME   (PRI_MIN_KERN - 1)
#define PRI_MIN_KERN   (80)
#define PRI_MAX_KERN   (PRI_MIN_TIMESHARE - 1)
#define PSWP   (PRI_MIN_KERN + 0)
#define PVM   (PRI_MIN_KERN + 4)
#define PINOD   (PRI_MIN_KERN + 8)
#define PRIBIO   (PRI_MIN_KERN + 12)
#define PVFS   (PRI_MIN_KERN + 16)
#define PZERO   (PRI_MIN_KERN + 20)
#define PSOCK   (PRI_MIN_KERN + 24)
#define PWAIT   (PRI_MIN_KERN + 28)
#define PLOCK   (PRI_MIN_KERN + 32)
#define PPAUSE   (PRI_MIN_KERN + 36)
#define PRI_MIN_TIMESHARE   (120)
#define PRI_MAX_TIMESHARE   (PRI_MIN_IDLE - 1)
#define PUSER   (PRI_MIN_TIMESHARE)
#define PRI_MIN_IDLE   (224)
#define PRI_MAX_IDLE   (PRI_MAX)
