RTEMS 6.1-rc2
switch-nxp-pca9548a.h
2
11/*
12 * Copyright (c) 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _DEV_I2C_SWITCH_NXP_PCA9548A_H
37#define _DEV_I2C_SWITCH_NXP_PCA9548A_H
38
39#include <dev/i2c/i2c.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
55int i2c_dev_register_switch_nxp_pca9548a(
56 const char *bus_path,
57 const char *dev_path,
58 uint16_t address
59);
60
61#define SWITCH_NXP_PCA9548A_GET_CONTROL (I2C_DEV_IO_CONTROL + 0)
62
63#define SWITCH_NXP_PCA9548A_SET_CONTROL (I2C_DEV_IO_CONTROL + 1)
64
65static inline int switch_nxp_pca9548a_get_control(int fd, uint8_t *val)
66{
67 return ioctl(fd, SWITCH_NXP_PCA9548A_GET_CONTROL, val);
68}
69
70static inline int switch_nxp_pca9548a_set_control(int fd, uint8_t val)
71{
72 return ioctl(fd, SWITCH_NXP_PCA9548A_SET_CONTROL, (void *)(uintptr_t) val);
73}
74
77#ifdef __cplusplus
78}
79#endif /* __cplusplus */
80
81#endif /* _DEV_I2C_SWITCH_NXP_PCA9548A_H */
Inter-Integrated Circuit (I2C) Driver API.
