RTEMS 6.1-rc2
Data Fields | |
rtems_libi2c_bus_t | i2clib_desc |
struct drvmgr_dev * | dev |
struct spictrl_regs * | regs |
int | irq |
int | minor |
unsigned int | core_freq_hz |
int | fdepth |
int | bits_per_char |
int | lsb_first |
int | txshift |
int | rxshift |
unsigned int | idle_char |
int(* | slvSelFunc )(void *regs, uint32_t addr, int select) |
int | periodic_started |
struct spictrl_ioctl_config | periodic_cfg |
