RTEMS 6.1-rc2
Public Types | |
enum | { METHOD , FLAG , BLOCKS , CHECK4 , CHECK3 , CHECK2 , CHECK1 , DONE , BAD } |
Data Fields | |
enum internal_state:: { ... } | mode |
union { | |
uInt method | |
struct { | |
uLong was | |
uLong need | |
} check | |
uInt marker | |
} | sub |
int | nowrap |
uInt | wbits |
inflate_blocks_statef * | blocks |
int | dummy |
z_streamp | strm |
int | status |
Bytef * | pending_buf |
ulg | pending_buf_size |
Bytef * | pending_out |
ulg | pending |
int | wrap |
gz_headerp | gzhead |
ulg | gzindex |
Byte | method |
int | last_flush |
uInt | w_size |
uInt | w_bits |
uInt | w_mask |
Bytef * | window |
ulg | window_size |
Posf * | prev |
Posf * | head |
uInt | ins_h |
uInt | hash_size |
uInt | hash_bits |
uInt | hash_mask |
uInt | hash_shift |
long | block_start |
uInt | match_length |
IPos | prev_match |
int | match_available |
uInt | strstart |
uInt | match_start |
uInt | lookahead |
uInt | prev_length |
uInt | max_chain_length |
uInt | max_lazy_match |
int | level |
int | strategy |
uInt | good_match |
int | nice_match |
struct ct_data_s | dyn_ltree [HEAP_SIZE] |
struct ct_data_s | dyn_dtree [2 *D_CODES+1] |
struct ct_data_s | bl_tree [2 *BL_CODES+1] |
struct tree_desc_s | l_desc |
struct tree_desc_s | d_desc |
struct tree_desc_s | bl_desc |
ush | bl_count [MAX_BITS+1] |
int | heap [2 *L_CODES+1] |
int | heap_len |
int | heap_max |
uch | depth [2 *L_CODES+1] |
uchf * | sym_buf |
uInt | lit_bufsize |
uInt | sym_next |
uInt | sym_end |
ulg | opt_len |
ulg | static_len |
uInt | matches |
uInt | insert |
ush | bi_buf |
int | bi_valid |
ulg | high_water |
