RTEMS 6.1-rc2
Macros | Functions
stm32h7xx_ll_utils.c File Reference
UTILS LL module driver. More...
#include "stm32h7xx_ll_utils.h"
#include "stm32h7xx_ll_rcc.h"
#include "stm32h7xx_ll_pwr.h"
#define assert_param(expr)   ((void)0U)
#define UTILS_PLLVCO_INPUT_MIN1   1000000U
#define UTILS_PLLVCO_INPUT_MAX1   2000000U
#define UTILS_PLLVCO_INPUT_MIN2   2000000U
#define UTILS_PLLVCO_INPUT_MAX2   4000000U
#define UTILS_PLLVCO_INPUT_MIN3   4000000U
#define UTILS_PLLVCO_INPUT_MAX3   8000000U
#define UTILS_PLLVCO_INPUT_MIN4   8000000U
#define UTILS_PLLVCO_INPUT_MAX4   16000000U
#define UTILS_PLLVCO_MEDIUM_OUTPUT_MIN   150000000U
#define UTILS_PLLVCO_WIDE_OUTPUT_MIN   128000000U
#define UTILS_PLLVCO_MEDIUM_OUTPUT_MAX   420000000U
#define UTILS_PLLVCO_WIDE_OUTPUT_MAX   560000000U
#define UTILS_HSE_FREQUENCY_MIN   4000000U
#define UTILS_HSE_FREQUENCY_MAX   48000000U
#define IS_LL_UTILS_SYSCLK_DIV(__VALUE__)
#define IS_LL_UTILS_AHB_DIV(__VALUE__)
#define IS_LL_UTILS_APB1_DIV(__VALUE__)
#define IS_LL_UTILS_APB2_DIV(__VALUE__)
#define IS_LL_UTILS_APB3_DIV(__VALUE__)
#define IS_LL_UTILS_APB4_DIV(__VALUE__)
#define IS_LL_UTILS_PLLM_VALUE(__VALUE__)   ((1U <= (__VALUE__)) && ((__VALUE__) <= 63U))
#define IS_LL_UTILS_PLLN_VALUE(__VALUE__)   ((8U <= (__VALUE__)) && ((__VALUE__) <= 420U))
#define IS_LL_UTILS_PLLP_VALUE(__VALUE__)   ((1U <= (__VALUE__)) && ((__VALUE__) <= 128U))
#define IS_LL_UTILS_FRACN_VALUE(__VALUE__)   ((__VALUE__) <= 0x1FFFU)
#define IS_LL_UTILS_PLLVCO_INPUT(__VALUE__, __RANGE__)
#define IS_LL_UTILS_PLLVCO_OUTPUT(__VALUE__, __RANGE__)
#define IS_LL_UTILS_CHECK_VCO_RANGES(__RANGEIN__, __RANGEOUT__)
#define IS_LL_UTILS_PLL_FREQUENCY(__VALUE__)
#define IS_LL_UTILS_HSE_BYPASS(__STATE__)
#define IS_LL_UTILS_HSE_FREQUENCY(__FREQUENCY__)   (((__FREQUENCY__) >= UTILS_HSE_FREQUENCY_MIN) && ((__FREQUENCY__) <= UTILS_HSE_FREQUENCY_MAX))
void LL_Init1msTick (uint32_t CPU_Frequency)
 This function configures the Cortex-M SysTick source to have 1ms time base.
void LL_mDelay (uint32_t Delay)
 This function provides accurate delay (in milliseconds) based on SysTick counter flag.
void LL_SetSystemCoreClock (uint32_t CPU_Frequency)
 This function sets directly SystemCoreClock CMSIS variable.
ErrorStatus LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct)
 This function configures system clock at maximum frequency with HSI as clock source of the PLL.
ErrorStatus LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct)
 This function configures system clock with HSE as clock source of the PLL.
ErrorStatus LL_SetFlashLatency (uint32_t HCLK_Frequency)
 Update number of Flash wait states in line with new frequency and current voltage range.
Author
MCD Application Team
Attention
