20#ifndef STM32H7xx_LL_LPTIM_H
21#define STM32H7xx_LL_LPTIM_H
34#if defined (LPTIM1) || defined (LPTIM2) || defined (LPTIM3) || defined (LPTIM4) || defined (LPTIM5)
47#if defined(USE_FULL_LL_DRIVER) || defined(__rtems__)
58#if defined(USE_FULL_LL_DRIVER) || defined(__rtems__)
92} LL_LPTIM_InitTypeDef;
110#define LL_LPTIM_ISR_CMPM LPTIM_ISR_CMPM
111#define LL_LPTIM_ISR_CMPOK LPTIM_ISR_CMPOK
112#define LL_LPTIM_ISR_ARRM LPTIM_ISR_ARRM
113#define LL_LPTIM_ISR_EXTTRIG LPTIM_ISR_EXTTRIG
114#define LL_LPTIM_ISR_ARROK LPTIM_ISR_ARROK
115#define LL_LPTIM_ISR_UP LPTIM_ISR_UP
116#define LL_LPTIM_ISR_DOWN LPTIM_ISR_DOWN
126#define LL_LPTIM_IER_CMPMIE LPTIM_IER_CMPMIE
127#define LL_LPTIM_IER_CMPOKIE LPTIM_IER_CMPOKIE
128#define LL_LPTIM_IER_ARRMIE LPTIM_IER_ARRMIE
129#define LL_LPTIM_IER_EXTTRIGIE LPTIM_IER_EXTTRIGIE
130#define LL_LPTIM_IER_ARROKIE LPTIM_IER_ARROKIE
131#define LL_LPTIM_IER_UPIE LPTIM_IER_UPIE
132#define LL_LPTIM_IER_DOWNIE LPTIM_IER_DOWNIE
141#define LL_LPTIM_OPERATING_MODE_CONTINUOUS LPTIM_CR_CNTSTRT
142#define LL_LPTIM_OPERATING_MODE_ONESHOT LPTIM_CR_SNGSTRT
151#define LL_LPTIM_UPDATE_MODE_IMMEDIATE 0x00000000U
152#define LL_LPTIM_UPDATE_MODE_ENDOFPERIOD LPTIM_CFGR_PRELOAD
161#define LL_LPTIM_COUNTER_MODE_INTERNAL 0x00000000U
162#define LL_LPTIM_COUNTER_MODE_EXTERNAL LPTIM_CFGR_COUNTMODE
171#define LL_LPTIM_OUTPUT_WAVEFORM_PWM 0x00000000U
172#define LL_LPTIM_OUTPUT_WAVEFORM_SETONCE LPTIM_CFGR_WAVE
181#define LL_LPTIM_OUTPUT_POLARITY_REGULAR 0x00000000U
182#define LL_LPTIM_OUTPUT_POLARITY_INVERSE LPTIM_CFGR_WAVPOL
191#define LL_LPTIM_PRESCALER_DIV1 0x00000000U
192#define LL_LPTIM_PRESCALER_DIV2 LPTIM_CFGR_PRESC_0
193#define LL_LPTIM_PRESCALER_DIV4 LPTIM_CFGR_PRESC_1
194#define LL_LPTIM_PRESCALER_DIV8 (LPTIM_CFGR_PRESC_1 | LPTIM_CFGR_PRESC_0)
195#define LL_LPTIM_PRESCALER_DIV16 LPTIM_CFGR_PRESC_2
196#define LL_LPTIM_PRESCALER_DIV32 (LPTIM_CFGR_PRESC_2 | LPTIM_CFGR_PRESC_0)
197#define LL_LPTIM_PRESCALER_DIV64 (LPTIM_CFGR_PRESC_2 | LPTIM_CFGR_PRESC_1)
198#define LL_LPTIM_PRESCALER_DIV128 LPTIM_CFGR_PRESC
207#define LL_LPTIM_TRIG_SOURCE_GPIO 0x00000000U
208#define LL_LPTIM_TRIG_SOURCE_RTCALARMA LPTIM_CFGR_TRIGSEL_0
209#define LL_LPTIM_TRIG_SOURCE_RTCALARMB LPTIM_CFGR_TRIGSEL_1
210#define LL_LPTIM_TRIG_SOURCE_RTCTAMP1 (LPTIM_CFGR_TRIGSEL_1 | LPTIM_CFGR_TRIGSEL_0)
211#define LL_LPTIM_TRIG_SOURCE_RTCTAMP2 LPTIM_CFGR_TRIGSEL_2
212#define LL_LPTIM_TRIG_SOURCE_RTCTAMP3 (LPTIM_CFGR_TRIGSEL_2 | LPTIM_CFGR_TRIGSEL_0)
213#define LL_LPTIM_TRIG_SOURCE_COMP1 (LPTIM_CFGR_TRIGSEL_2 | LPTIM_CFGR_TRIGSEL_1)
214#define LL_LPTIM_TRIG_SOURCE_COMP2 LPTIM_CFGR_TRIGSEL
215#define LL_LPTIM_TRIG_SOURCE_LPTIM2 0x00000000U
216#define LL_LPTIM_TRIG_SOURCE_LPTIM3 LPTIM_CFGR_TRIGSEL_0
217#define LL_LPTIM_TRIG_SOURCE_LPTIM4 LPTIM_CFGR_TRIGSEL_1
218#define LL_LPTIM_TRIG_SOURCE_LPTIM5 (LPTIM_CFGR_TRIGSEL_1 | LPTIM_CFGR_TRIGSEL_0)
219#define LL_LPTIM_TRIG_SOURCE_SAI1_FS_A LPTIM_CFGR_TRIGSEL_2
220#define LL_LPTIM_TRIG_SOURCE_SAI1_FS_B (LPTIM_CFGR_TRIGSEL_2 | LPTIM_CFGR_TRIGSEL_0)
221#define LL_LPTIM_TRIG_SOURCE_SAI2_FS_A LPTIM_CFGR_TRIGSEL_2
222#define LL_LPTIM_TRIG_SOURCE_SAI2_FS_B (LPTIM_CFGR_TRIGSEL_2 | LPTIM_CFGR_TRIGSEL_0)
223#define LL_LPTIM_TRIG_SOURCE_SAI4_FS_A (LPTIM_CFGR_TRIGSEL_1 | LPTIM_CFGR_TRIGSEL_0)
224#define LL_LPTIM_TRIG_SOURCE_SAI4_FS_B LPTIM_CFGR_TRIGSEL_2
225#define LL_LPTIM_TRIG_SOURCE_DFSDM2_BRK (LPTIM_CFGR_TRIGSEL_2 | LPTIM_CFGR_TRIGSEL_1)
234#define LL_LPTIM_TRIG_FILTER_NONE 0x00000000U
235#define LL_LPTIM_TRIG_FILTER_2 LPTIM_CFGR_TRGFLT_0
236#define LL_LPTIM_TRIG_FILTER_4 LPTIM_CFGR_TRGFLT_1
237#define LL_LPTIM_TRIG_FILTER_8 LPTIM_CFGR_TRGFLT
246#define LL_LPTIM_TRIG_POLARITY_RISING LPTIM_CFGR_TRIGEN_0
247#define LL_LPTIM_TRIG_POLARITY_FALLING LPTIM_CFGR_TRIGEN_1
248#define LL_LPTIM_TRIG_POLARITY_RISING_FALLING LPTIM_CFGR_TRIGEN
257#define LL_LPTIM_CLK_SOURCE_INTERNAL 0x00000000U
258#define LL_LPTIM_CLK_SOURCE_EXTERNAL LPTIM_CFGR_CKSEL
267#define LL_LPTIM_CLK_FILTER_NONE 0x00000000U
268#define LL_LPTIM_CLK_FILTER_2 LPTIM_CFGR_CKFLT_0
269#define LL_LPTIM_CLK_FILTER_4 LPTIM_CFGR_CKFLT_1
270#define LL_LPTIM_CLK_FILTER_8 LPTIM_CFGR_CKFLT
279#define LL_LPTIM_CLK_POLARITY_RISING 0x00000000U
280#define LL_LPTIM_CLK_POLARITY_FALLING LPTIM_CFGR_CKPOL_0
281#define LL_LPTIM_CLK_POLARITY_RISING_FALLING LPTIM_CFGR_CKPOL_1
290#define LL_LPTIM_ENCODER_MODE_RISING 0x00000000U
291#define LL_LPTIM_ENCODER_MODE_FALLING LPTIM_CFGR_CKPOL_0
292#define LL_LPTIM_ENCODER_MODE_RISING_FALLING LPTIM_CFGR_CKPOL_1
301#define LL_LPTIM_INPUT1_SRC_GPIO 0x00000000U
302#define LL_LPTIM_INPUT1_SRC_COMP1 LPTIM_CFGR2_IN1SEL_0
303#define LL_LPTIM_INPUT1_SRC_COMP2 LPTIM_CFGR2_IN1SEL_1
304#define LL_LPTIM_INPUT1_SRC_COMP1_COMP2 (LPTIM_CFGR2_IN1SEL_1 | LPTIM_CFGR2_IN1SEL_0)
305#define LL_LPTIM_INPUT1_SRC_SAI4_FS_A LPTIM_CFGR2_IN1SEL_0
306#define LL_LPTIM_INPUT1_SRC_SAI4_FS_B LPTIM_CFGR2_IN1SEL_1
315#define LL_LPTIM_INPUT2_SRC_GPIO 0x00000000U
316#define LL_LPTIM_INPUT2_SRC_COMP2 LPTIM_CFGR2_IN2SEL_0
343#define LL_LPTIM_WriteReg(__INSTANCE__, __REG__, __VALUE__) WRITE_REG((__INSTANCE__)->__REG__, (__VALUE__))
351#define LL_LPTIM_ReadReg(__INSTANCE__, __REG__) READ_REG((__INSTANCE__)->__REG__)
369#define LL_LPTIM_ClearFLAG_CMPM LL_LPTIM_ClearFlag_CMPM
370#define LL_LPTIM_ClearFLAG_CC1 LL_LPTIM_ClearFlag_CC1
371#define LL_LPTIM_ClearFLAG_CC2 LL_LPTIM_ClearFlag_CC2
372#define LL_LPTIM_ClearFLAG_CC1O LL_LPTIM_ClearFlag_CC1O
373#define LL_LPTIM_ClearFLAG_CC2O LL_LPTIM_ClearFlag_CC2O
374#define LL_LPTIM_ClearFLAG_ARRM LL_LPTIM_ClearFlag_ARRM
379#if defined(USE_FULL_LL_DRIVER) || defined(__rtems__)
386void LL_LPTIM_StructInit(LL_LPTIM_InitTypeDef *LPTIM_InitStruct);
387ErrorStatus LL_LPTIM_Init(
LPTIM_TypeDef *LPTIMx,
const LL_LPTIM_InitTypeDef *LPTIM_InitStruct);
418__STATIC_INLINE uint32_t LL_LPTIM_IsEnabled(
const LPTIM_TypeDef *LPTIMx)
436__STATIC_INLINE
void LL_LPTIM_StartCounter(
LPTIM_TypeDef *LPTIMx, uint32_t OperatingMode)
449__STATIC_INLINE
void LL_LPTIM_EnableResetAfterRead(
460__STATIC_INLINE
void LL_LPTIM_DisableResetAfterRead(
471__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledResetAfterRead(
486__STATIC_INLINE
void LL_LPTIM_ResetCounter(
501__STATIC_INLINE
void LL_LPTIM_SetUpdateMode(
LPTIM_TypeDef *LPTIMx, uint32_t UpdateMode)
514__STATIC_INLINE uint32_t LL_LPTIM_GetUpdateMode(
532__STATIC_INLINE
void LL_LPTIM_SetAutoReload(
LPTIM_TypeDef *LPTIMx, uint32_t AutoReload)
543__STATIC_INLINE uint32_t LL_LPTIM_GetAutoReload(
559__STATIC_INLINE
void LL_LPTIM_SetCompare(
LPTIM_TypeDef *LPTIMx, uint32_t CompareValue)
570__STATIC_INLINE uint32_t LL_LPTIM_GetCompare(
585__STATIC_INLINE uint32_t LL_LPTIM_GetCounter(
600__STATIC_INLINE
void LL_LPTIM_SetCounterMode(
LPTIM_TypeDef *LPTIMx, uint32_t CounterMode)
613__STATIC_INLINE uint32_t LL_LPTIM_GetCounterMode(
635__STATIC_INLINE
void LL_LPTIM_ConfigOutput(
LPTIM_TypeDef *LPTIMx, uint32_t Waveform, uint32_t Polarity)
649__STATIC_INLINE
void LL_LPTIM_SetWaveform(
LPTIM_TypeDef *LPTIMx, uint32_t Waveform)
662__STATIC_INLINE uint32_t LL_LPTIM_GetWaveform(
676__STATIC_INLINE
void LL_LPTIM_SetPolarity(
LPTIM_TypeDef *LPTIMx, uint32_t Polarity)
689__STATIC_INLINE uint32_t LL_LPTIM_GetPolarity(
714__STATIC_INLINE
void LL_LPTIM_SetPrescaler(
LPTIM_TypeDef *LPTIMx, uint32_t Prescaler)
733__STATIC_INLINE uint32_t LL_LPTIM_GetPrescaler(
751__STATIC_INLINE
void LL_LPTIM_SetInput1Src(
LPTIM_TypeDef *LPTIMx, uint32_t Src)
765__STATIC_INLINE
void LL_LPTIM_SetInput2Src(
791__STATIC_INLINE
void LL_LPTIM_EnableTimeout(
805__STATIC_INLINE
void LL_LPTIM_DisableTimeout(
816__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledTimeout(
876__STATIC_INLINE
void LL_LPTIM_ConfigTrigger(
LPTIM_TypeDef *LPTIMx, uint32_t Source, uint32_t Filter, uint32_t Polarity)
909__STATIC_INLINE uint32_t LL_LPTIM_GetTriggerSource(
924__STATIC_INLINE uint32_t LL_LPTIM_GetTriggerFilter(
938__STATIC_INLINE uint32_t LL_LPTIM_GetTriggerPolarity(
962__STATIC_INLINE
void LL_LPTIM_SetClockSource(
LPTIM_TypeDef *LPTIMx, uint32_t ClockSource)
975__STATIC_INLINE uint32_t LL_LPTIM_GetClockSource(
1003__STATIC_INLINE
void LL_LPTIM_ConfigClock(
LPTIM_TypeDef *LPTIMx, uint32_t ClockFilter, uint32_t ClockPolarity)
1017__STATIC_INLINE uint32_t LL_LPTIM_GetClockPolarity(
1032__STATIC_INLINE uint32_t LL_LPTIM_GetClockFilter(
1057__STATIC_INLINE
void LL_LPTIM_SetEncoderMode(
LPTIM_TypeDef *LPTIMx, uint32_t EncoderMode)
1071__STATIC_INLINE uint32_t LL_LPTIM_GetEncoderMode(
1087__STATIC_INLINE
void LL_LPTIM_EnableEncoderMode(
1099__STATIC_INLINE
void LL_LPTIM_DisableEncoderMode(
1110__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledEncoderMode(
1131__STATIC_INLINE
void LL_LPTIM_ClearFlag_CMPM(
1142__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_CMPM(
1153__STATIC_INLINE
void LL_LPTIM_ClearFlag_ARRM(
1164__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_ARRM(
1175__STATIC_INLINE
void LL_LPTIM_ClearFlag_EXTTRIG(
1186__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_EXTTRIG(
1197__STATIC_INLINE
void LL_LPTIM_ClearFlag_CMPOK(
1209__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_CMPOK(
1220__STATIC_INLINE
void LL_LPTIM_ClearFlag_ARROK(
1232__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_ARROK(
1243__STATIC_INLINE
void LL_LPTIM_ClearFlag_UP(
1255__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_UP(
1266__STATIC_INLINE
void LL_LPTIM_ClearFlag_DOWN(
1278__STATIC_INLINE uint32_t LL_LPTIM_IsActiveFlag_DOWN(
1298__STATIC_INLINE
void LL_LPTIM_EnableIT_CMPM(
1309__STATIC_INLINE
void LL_LPTIM_DisableIT_CMPM(
1320__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_CMPM(
1331__STATIC_INLINE
void LL_LPTIM_EnableIT_ARRM(
1342__STATIC_INLINE
void LL_LPTIM_DisableIT_ARRM(
1353__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_ARRM(
1364__STATIC_INLINE
void LL_LPTIM_EnableIT_EXTTRIG(
1375__STATIC_INLINE
void LL_LPTIM_DisableIT_EXTTRIG(
1386__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_EXTTRIG(
1397__STATIC_INLINE
void LL_LPTIM_EnableIT_CMPOK(
1408__STATIC_INLINE
void LL_LPTIM_DisableIT_CMPOK(
1419__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_CMPOK(
1430__STATIC_INLINE
void LL_LPTIM_EnableIT_ARROK(
1441__STATIC_INLINE
void LL_LPTIM_DisableIT_ARROK(
1452__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_ARROK(
1463__STATIC_INLINE
void LL_LPTIM_EnableIT_UP(
1474__STATIC_INLINE
void LL_LPTIM_DisableIT_UP(
1485__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_UP(
1496__STATIC_INLINE
void LL_LPTIM_EnableIT_DOWN(
1507__STATIC_INLINE
void LL_LPTIM_DisableIT_DOWN(
1518__STATIC_INLINE uint32_t LL_LPTIM_IsEnabledIT_DOWN(
#define LPTIM_CFGR_CKPOL
Definition: stm32h723xx.h:20190
#define LPTIM_ICR_EXTTRIGCF
Definition: stm32h723xx.h:20146
#define LPTIM_CFGR2_IN1SEL
Definition: stm32h723xx.h:20281
#define LPTIM_CR_RSTARE
Definition: stm32h723xx.h:20260
#define LPTIM_CFGR_TRGFLT
Definition: stm32h723xx.h:20202
#define LPTIM_CFGR_WAVE
Definition: stm32h723xx.h:20231
#define LPTIM_CFGR_TIMOUT
Definition: stm32h723xx.h:20228
#define LPTIM_IER_DOWNIE
Definition: stm32h723xx.h:20181
#define LPTIM_CFGR_COUNTMODE
Definition: stm32h723xx.h:20240
#define LPTIM_ISR_CMPOK
Definition: stm32h723xx.h:20126
#define LPTIM_ICR_ARROKCF
Definition: stm32h723xx.h:20152
#define LPTIM_ICR_CMPOKCF
Definition: stm32h723xx.h:20149
#define LPTIM_CR_COUNTRST
Definition: stm32h723xx.h:20257
#define LPTIM_CFGR_TRIGSEL
Definition: stm32h723xx.h:20215
#define LPTIM_ISR_EXTTRIG
Definition: stm32h723xx.h:20123
#define LPTIM_IER_UPIE
Definition: stm32h723xx.h:20178
#define LPTIM_CFGR2_IN2SEL
Definition: stm32h723xx.h:20286
#define LPTIM_CR_CNTSTRT
Definition: stm32h723xx.h:20254
#define LPTIM_IER_CMPMIE
Definition: stm32h723xx.h:20163
#define LPTIM_CR_ENABLE
Definition: stm32h723xx.h:20248
#define LPTIM_ISR_ARRM
Definition: stm32h723xx.h:20120
#define LPTIM_CMP_CMP
Definition: stm32h723xx.h:20266
#define LPTIM_IER_ARROKIE
Definition: stm32h723xx.h:20175
#define LPTIM_IER_EXTTRIGIE
Definition: stm32h723xx.h:20169
#define LPTIM_ICR_UPCF
Definition: stm32h723xx.h:20155
#define LPTIM_CFGR_CKFLT
Definition: stm32h723xx.h:20196
#define LPTIM_CR_SNGSTRT
Definition: stm32h723xx.h:20251
#define LPTIM_ISR_UP
Definition: stm32h723xx.h:20132
#define LPTIM_ISR_CMPM
Definition: stm32h723xx.h:20117
#define LPTIM_ICR_ARRMCF
Definition: stm32h723xx.h:20143
#define LPTIM_ISR_ARROK
Definition: stm32h723xx.h:20129
#define LPTIM_IER_ARRMIE
Definition: stm32h723xx.h:20166
#define LPTIM_IER_CMPOKIE
Definition: stm32h723xx.h:20172
#define LPTIM_ICR_CMPMCF
Definition: stm32h723xx.h:20140
#define LPTIM_ARR_ARR
Definition: stm32h723xx.h:20271
#define LPTIM_CFGR_ENC
Definition: stm32h723xx.h:20243
#define LPTIM_CFGR_PRELOAD
Definition: stm32h723xx.h:20237
#define LPTIM_ICR_DOWNCF
Definition: stm32h723xx.h:20158
#define LPTIM_CFGR_TRIGEN
Definition: stm32h723xx.h:20222
#define LPTIM_CFGR_PRESC
Definition: stm32h723xx.h:20208
#define LPTIM_ISR_DOWN
Definition: stm32h723xx.h:20135
#define LPTIM_CFGR_CKSEL
Definition: stm32h723xx.h:20186
#define LPTIM_CNT_CNT
Definition: stm32h723xx.h:20276
#define LPTIM_CFGR_WAVPOL
Definition: stm32h723xx.h:20234
CMSIS STM32H7xx Device Peripheral Access Layer Header File.
LPTIMIMER.
Definition: stm32h723xx.h:1559
__IO uint32_t ICR
Definition: stm32h723xx.h:1561
__IO uint32_t ARR
Definition: stm32h723xx.h:1566
__IO uint32_t CMP
Definition: stm32h723xx.h:1565
__IO uint32_t CFGR
Definition: stm32h723xx.h:1563
__IO uint32_t IER
Definition: stm32h723xx.h:1562
__IO uint32_t ISR
Definition: stm32h723xx.h:1560
__IO uint32_t CFGR2
Definition: stm32h723xx.h:1569
__IO uint32_t CNT
Definition: stm32h723xx.h:1567
__IO uint32_t CR
Definition: stm32h723xx.h:1564
