RTEMS 6.1-rc2
Header file of Delay Block module. More...
#include "stm32h7xx_hal_def.h"
#define | DLYB_MAX_UNIT ((uint32_t)0x00000080U) |
#define | DLYB_MAX_SELECT ((uint32_t)0x0000000CU) |
HAL_StatusTypeDef | DelayBlock_Enable (DLYB_TypeDef *DLYBx) |
HAL_StatusTypeDef | DelayBlock_Disable (DLYB_TypeDef *DLYBx) |
HAL_StatusTypeDef | DelayBlock_Configure (DLYB_TypeDef *DLYBx, uint32_t PhaseSel, uint32_t Units) |
