RTEMS 6.1-rc2
stm32h7xx_ll_delayblock.c File Reference
DelayBlock Low Layer HAL module driver. More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
     This file provides firmware functions to manage the following
     functionalities of the Delay Block peripheral:
      + input clock frequency range 25MHz to 208MHz
      + up to 12 oversampling phases
Attention
                     ##### DelayBlock peripheral features #####
  [..] The Delay block is used to generate an Output clock which is de-phased from the Input
        clock. The phase of the Output clock is programmed by FW. The Output clock is then used
        to clock the receive data in i.e. a SDMMC or QSPI interface.
       The delay is Voltage and Temperature dependent, which may require FW to do re-tuning
        and recenter the Output clock phase to the receive data.
  [..] The Delay Block features include the following:
       (+) Input clock frequency range 25MHz to 208MHz.
       (+) Up to 12 oversampling phases.
                         ##### How to use this driver #####
    This driver is a considered as a driver of service for external devices drivers
    that interfaces with the DELAY peripheral.
    The DelayBlock_Enable() function, enables the DelayBlock instance, configure the delay line length
    and configure the Output clock phase.
    The DelayBlock_Disable() function, disables the DelayBlock instance by setting DEN flag to 0.
