RTEMS 6.1-rc2
Extended UART HAL module driver. This file provides firmware functions to manage the following extended functionalities of the Universal Asynchronous Receiver Transmitter Peripheral (UART). More...
#include "stm32h7xx_hal.h"
============================================================================== ##### UART peripheral extended features ##### ============================================================================== (#) Declare a UART_HandleTypeDef handle structure. (#) For the UART RS485 Driver Enable mode, initialize the UART registers by calling the HAL_RS485Ex_Init() API. (#) FIFO mode enabling/disabling and RX/TX FIFO threshold programming. -@- When UART operates in FIFO mode, FIFO mode must be enabled prior starting RX/TX transfers. Also RX/TX FIFO thresholds must be configured prior starting RX/TX transfers.
