RTEMS 6.1-rc2
stm32h7xx_hal_smbus.h File Reference
Header file of SMBUS HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_smbus_ex.h"
struct  SMBUS_InitTypeDef
struct  SMBUS_HandleTypeDef
#define HAL_SMBUS_STATE_RESET   (0x00000000U)
#define HAL_SMBUS_STATE_READY   (0x00000001U)
#define HAL_SMBUS_STATE_BUSY   (0x00000002U)
#define HAL_SMBUS_STATE_MASTER_BUSY_TX   (0x00000012U)
#define HAL_SMBUS_STATE_MASTER_BUSY_RX   (0x00000022U)
#define HAL_SMBUS_STATE_SLAVE_BUSY_TX   (0x00000032U)
#define HAL_SMBUS_STATE_SLAVE_BUSY_RX   (0x00000042U)
#define HAL_SMBUS_STATE_TIMEOUT   (0x00000003U)
#define HAL_SMBUS_STATE_ERROR   (0x00000004U)
#define HAL_SMBUS_STATE_LISTEN   (0x00000008U)
#define HAL_SMBUS_ERROR_NONE   (0x00000000U)
#define HAL_SMBUS_ERROR_BERR   (0x00000001U)
#define HAL_SMBUS_ERROR_ARLO   (0x00000002U)
#define HAL_SMBUS_ERROR_ACKF   (0x00000004U)
#define HAL_SMBUS_ERROR_OVR   (0x00000008U)
#define HAL_SMBUS_ERROR_HALTIMEOUT   (0x00000010U)
#define HAL_SMBUS_ERROR_BUSTIMEOUT   (0x00000020U)
#define HAL_SMBUS_ERROR_ALERT   (0x00000040U)
#define HAL_SMBUS_ERROR_PECERR   (0x00000080U)
#define HAL_SMBUS_ERROR_INVALID_PARAM   (0x00000200U)
#define SMBUS_ANALOGFILTER_ENABLE   (0x00000000U)
#define SMBUS_ANALOGFILTER_DISABLE   I2C_CR1_ANFOFF
#define SMBUS_ADDRESSINGMODE_7BIT   (0x00000001U)
#define SMBUS_ADDRESSINGMODE_10BIT   (0x00000002U)
#define SMBUS_DUALADDRESS_DISABLE   (0x00000000U)
#define SMBUS_DUALADDRESS_ENABLE   I2C_OAR2_OA2EN
#define SMBUS_OA2_NOMASK   ((uint8_t)0x00U)
#define SMBUS_OA2_MASK01   ((uint8_t)0x01U)
#define SMBUS_OA2_MASK02   ((uint8_t)0x02U)
#define SMBUS_OA2_MASK03   ((uint8_t)0x03U)
#define SMBUS_OA2_MASK04   ((uint8_t)0x04U)
#define SMBUS_OA2_MASK05   ((uint8_t)0x05U)
#define SMBUS_OA2_MASK06   ((uint8_t)0x06U)
#define SMBUS_OA2_MASK07   ((uint8_t)0x07U)
#define SMBUS_GENERALCALL_DISABLE   (0x00000000U)
#define SMBUS_GENERALCALL_ENABLE   I2C_CR1_GCEN
#define SMBUS_NOSTRETCH_DISABLE   (0x00000000U)
#define SMBUS_NOSTRETCH_ENABLE   I2C_CR1_NOSTRETCH
#define SMBUS_PEC_DISABLE   (0x00000000U)
#define SMBUS_PEC_ENABLE   I2C_CR1_PECEN
#define SMBUS_PERIPHERAL_MODE_SMBUS_HOST   I2C_CR1_SMBHEN
#define SMBUS_PERIPHERAL_MODE_SMBUS_SLAVE   (0x00000000U)
#define SMBUS_PERIPHERAL_MODE_SMBUS_SLAVE_ARP   I2C_CR1_SMBDEN
#define SMBUS_SOFTEND_MODE   (0x00000000U)
#define SMBUS_RELOAD_MODE   I2C_CR2_RELOAD
#define SMBUS_AUTOEND_MODE   I2C_CR2_AUTOEND
#define SMBUS_SENDPEC_MODE   I2C_CR2_PECBYTE
#define SMBUS_NO_STARTSTOP   (0x00000000U)
#define SMBUS_GENERATE_STOP   (uint32_t)(0x80000000U | I2C_CR2_STOP)
#define SMBUS_GENERATE_START_READ   (uint32_t)(0x80000000U | I2C_CR2_START | I2C_CR2_RD_WRN)
#define SMBUS_GENERATE_START_WRITE   (uint32_t)(0x80000000U | I2C_CR2_START)
#define SMBUS_FIRST_FRAME   SMBUS_SOFTEND_MODE
#define SMBUS_NEXT_FRAME   ((uint32_t)(SMBUS_RELOAD_MODE | SMBUS_SOFTEND_MODE))
#define SMBUS_FIRST_AND_LAST_FRAME_NO_PEC   SMBUS_AUTOEND_MODE
#define SMBUS_LAST_FRAME_NO_PEC   SMBUS_AUTOEND_MODE
#define SMBUS_FIRST_FRAME_WITH_PEC   ((uint32_t)(SMBUS_SOFTEND_MODE | SMBUS_SENDPEC_MODE))
#define SMBUS_FIRST_AND_LAST_FRAME_WITH_PEC   ((uint32_t)(SMBUS_AUTOEND_MODE | SMBUS_SENDPEC_MODE))
#define SMBUS_LAST_FRAME_WITH_PEC   ((uint32_t)(SMBUS_AUTOEND_MODE | SMBUS_SENDPEC_MODE))
#define SMBUS_OTHER_FRAME_NO_PEC   (0x000000AAU)
#define SMBUS_OTHER_FRAME_WITH_PEC   (0x0000AA00U)
#define SMBUS_OTHER_AND_LAST_FRAME_NO_PEC   (0x00AA0000U)
#define SMBUS_OTHER_AND_LAST_FRAME_WITH_PEC   (0xAA000000U)
#define SMBUS_IT_ERRI   I2C_CR1_ERRIE
#define SMBUS_IT_TCI   I2C_CR1_TCIE
#define SMBUS_IT_STOPI   I2C_CR1_STOPIE
#define SMBUS_IT_NACKI   I2C_CR1_NACKIE
#define SMBUS_IT_ADDRI   I2C_CR1_ADDRIE
#define SMBUS_IT_RXI   I2C_CR1_RXIE
#define SMBUS_IT_TXI   I2C_CR1_TXIE
#define SMBUS_IT_TX
#define SMBUS_IT_RX
#define SMBUS_IT_ALERT   (SMBUS_IT_ERRI)
#define SMBUS_IT_ADDR   (SMBUS_IT_ADDRI | SMBUS_IT_STOPI | SMBUS_IT_NACKI)
#define SMBUS_FLAG_TXE   I2C_ISR_TXE
#define SMBUS_FLAG_TXIS   I2C_ISR_TXIS
#define SMBUS_FLAG_RXNE   I2C_ISR_RXNE
#define SMBUS_FLAG_ADDR   I2C_ISR_ADDR
#define SMBUS_FLAG_AF   I2C_ISR_NACKF
#define SMBUS_FLAG_STOPF   I2C_ISR_STOPF
#define SMBUS_FLAG_TC   I2C_ISR_TC
#define SMBUS_FLAG_TCR   I2C_ISR_TCR
#define SMBUS_FLAG_BERR   I2C_ISR_BERR
#define SMBUS_FLAG_ARLO   I2C_ISR_ARLO
#define SMBUS_FLAG_OVR   I2C_ISR_OVR
#define SMBUS_FLAG_PECERR   I2C_ISR_PECERR
#define SMBUS_FLAG_TIMEOUT   I2C_ISR_TIMEOUT
#define SMBUS_FLAG_ALERT   I2C_ISR_ALERT
#define SMBUS_FLAG_BUSY   I2C_ISR_BUSY
#define SMBUS_FLAG_DIR   I2C_ISR_DIR
#define __HAL_SMBUS_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_SMBUS_STATE_RESET)
 Reset SMBUS handle state.
#define __HAL_SMBUS_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR1 |= (__INTERRUPT__))
 Enable the specified SMBUS interrupts.
#define __HAL_SMBUS_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR1 &= (~(__INTERRUPT__)))
 Disable the specified SMBUS interrupts.
#define __HAL_SMBUS_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)    ((((__HANDLE__)->Instance->CR1 & (__INTERRUPT__)) == (__INTERRUPT__)) ? SET : RESET)
 Check whether the specified SMBUS interrupt source is enabled or not.
#define SMBUS_FLAG_MASK   (0x0001FFFFU)
 Check whether the specified SMBUS flag is set or not.
#define __HAL_SMBUS_GET_FLAG(__HANDLE__, __FLAG__)
#define __HAL_SMBUS_CLEAR_FLAG(__HANDLE__, __FLAG__)
 Clear the SMBUS pending flags which are cleared by writing 1 in a specific bit.
#define __HAL_SMBUS_ENABLE(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
 Enable the specified SMBUS peripheral.
#define __HAL_SMBUS_DISABLE(__HANDLE__)   (CLEAR_BIT((__HANDLE__)->Instance->CR1, I2C_CR1_PE))
 Disable the specified SMBUS peripheral.
#define __HAL_SMBUS_GENERATE_NACK(__HANDLE__)   (SET_BIT((__HANDLE__)->Instance->CR2, I2C_CR2_NACK))
 Generate a Non-Acknowledge SMBUS peripheral in Slave mode.
#define IS_SMBUS_ANALOG_FILTER(FILTER)
#define IS_SMBUS_DIGITAL_FILTER(FILTER)   ((FILTER) <= 0x0000000FU)
#define IS_SMBUS_ADDRESSING_MODE(MODE)
#define IS_SMBUS_DUAL_ADDRESS(ADDRESS)
#define IS_SMBUS_OWN_ADDRESS2_MASK(MASK)
#define IS_SMBUS_GENERAL_CALL(CALL)
#define IS_SMBUS_NO_STRETCH(STRETCH)
#define IS_SMBUS_PEC(PEC)
#define IS_SMBUS_PERIPHERAL_MODE(MODE)
#define IS_SMBUS_TRANSFER_MODE(MODE)
#define IS_SMBUS_TRANSFER_REQUEST(REQUEST)
#define IS_SMBUS_TRANSFER_OPTIONS_REQUEST(REQUEST)
#define IS_SMBUS_TRANSFER_OTHER_OPTIONS_REQUEST(REQUEST)
#define SMBUS_RESET_CR1(__HANDLE__)
#define SMBUS_RESET_CR2(__HANDLE__)
#define SMBUS_GENERATE_START(__ADDMODE__, __ADDRESS__)
#define SMBUS_GET_ADDR_MATCH(__HANDLE__)   (((__HANDLE__)->Instance->ISR & I2C_ISR_ADDCODE) >> 17U)
#define SMBUS_GET_DIR(__HANDLE__)   (((__HANDLE__)->Instance->ISR & I2C_ISR_DIR) >> 16U)
#define SMBUS_GET_STOP_MODE(__HANDLE__)   ((__HANDLE__)->Instance->CR2 & I2C_CR2_AUTOEND)
#define SMBUS_GET_PEC_MODE(__HANDLE__)   ((__HANDLE__)->Instance->CR2 & I2C_CR2_PECBYTE)
#define SMBUS_GET_ALERT_ENABLED(__HANDLE__)   ((__HANDLE__)->Instance->CR1 & I2C_CR1_ALERTEN)
#define SMBUS_CHECK_FLAG(__ISR__, __FLAG__)
#define SMBUS_CHECK_IT_SOURCE(__CR1__, __IT__)   ((((__CR1__) & (__IT__)) == (__IT__)) ? SET : RESET)
#define IS_SMBUS_OWN_ADDRESS1(ADDRESS1)   ((ADDRESS1) <= 0x000003FFU)
#define IS_SMBUS_OWN_ADDRESS2(ADDRESS2)   ((ADDRESS2) <= (uint16_t)0x00FFU)
HAL_StatusTypeDef HAL_SMBUS_Init (SMBUS_HandleTypeDef *hsmbus)
HAL_StatusTypeDef HAL_SMBUS_DeInit (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_MspInit (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_MspDeInit (SMBUS_HandleTypeDef *hsmbus)
HAL_StatusTypeDef HAL_SMBUS_ConfigAnalogFilter (SMBUS_HandleTypeDef *hsmbus, uint32_t AnalogFilter)
HAL_StatusTypeDef HAL_SMBUS_ConfigDigitalFilter (SMBUS_HandleTypeDef *hsmbus, uint32_t DigitalFilter)
HAL_StatusTypeDef HAL_SMBUS_IsDeviceReady (SMBUS_HandleTypeDef *hsmbus, uint16_t DevAddress, uint32_t Trials, uint32_t Timeout)
HAL_StatusTypeDef HAL_SMBUS_Master_Transmit_IT (SMBUS_HandleTypeDef *hsmbus, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_SMBUS_Master_Receive_IT (SMBUS_HandleTypeDef *hsmbus, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_SMBUS_Master_Abort_IT (SMBUS_HandleTypeDef *hsmbus, uint16_t DevAddress)
HAL_StatusTypeDef HAL_SMBUS_Slave_Transmit_IT (SMBUS_HandleTypeDef *hsmbus, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_SMBUS_Slave_Receive_IT (SMBUS_HandleTypeDef *hsmbus, uint8_t *pData, uint16_t Size, uint32_t XferOptions)
HAL_StatusTypeDef HAL_SMBUS_EnableAlert_IT (SMBUS_HandleTypeDef *hsmbus)
HAL_StatusTypeDef HAL_SMBUS_DisableAlert_IT (SMBUS_HandleTypeDef *hsmbus)
HAL_StatusTypeDef HAL_SMBUS_EnableListen_IT (SMBUS_HandleTypeDef *hsmbus)
HAL_StatusTypeDef HAL_SMBUS_DisableListen_IT (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_EV_IRQHandler (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_ER_IRQHandler (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_MasterTxCpltCallback (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_MasterRxCpltCallback (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_SlaveTxCpltCallback (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_SlaveRxCpltCallback (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_AddrCallback (SMBUS_HandleTypeDef *hsmbus, uint8_t TransferDirection, uint16_t AddrMatchCode)
void HAL_SMBUS_ListenCpltCallback (SMBUS_HandleTypeDef *hsmbus)
void HAL_SMBUS_ErrorCallback (SMBUS_HandleTypeDef *hsmbus)
uint32_t HAL_SMBUS_GetState (const SMBUS_HandleTypeDef *hsmbus)
uint32_t HAL_SMBUS_GetError (const SMBUS_HandleTypeDef *hsmbus)
Author
MCD Application Team
Attention
