RTEMS 6.1-rc2
Enumerations | Functions
stm32h7xx_hal_sd_ex.h File Reference
Header file of SD HAL extended module. More...
#include "stm32h7xx_hal_def.h"
enum  HAL_SDEx_DMABuffer_MemoryTypeDef { SD_DMA_BUFFER0 = 0x00U , SD_DMA_BUFFER1 = 0x01U }
HAL_StatusTypeDef HAL_SDEx_ConfigDMAMultiBuffer (SD_HandleTypeDef *hsd, uint32_t *pDataBuffer0, uint32_t *pDataBuffer1, uint32_t BufferSize)
HAL_StatusTypeDef HAL_SDEx_ReadBlocksDMAMultiBuffer (SD_HandleTypeDef *hsd, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_SDEx_WriteBlocksDMAMultiBuffer (SD_HandleTypeDef *hsd, uint32_t BlockAdd, uint32_t NumberOfBlocks)
HAL_StatusTypeDef HAL_SDEx_ChangeDMABuffer (SD_HandleTypeDef *hsd, HAL_SDEx_DMABuffer_MemoryTypeDef Buffer, uint32_t *pDataBuffer)
void HAL_SDEx_Read_DMADoubleBuf0CpltCallback (SD_HandleTypeDef *hsd)
void HAL_SDEx_Read_DMADoubleBuf1CpltCallback (SD_HandleTypeDef *hsd)
void HAL_SDEx_Write_DMADoubleBuf0CpltCallback (SD_HandleTypeDef *hsd)
void HAL_SDEx_Write_DMADoubleBuf1CpltCallback (SD_HandleTypeDef *hsd)
Author
MCD Application Team
Attention
