RTEMS 6.1-rc2
stm32h7xx_hal_rtc_ex.h File Reference
Header file of RTC HAL Extension module. More...
#include "stm32h7xx_hal_def.h"
struct  RTC_TamperTypeDef
#define BKP_REG_NUMBER   RTC_BKP_NUMBER
#define RTC_BKP_DR0   0x00u
#define RTC_BKP_DR1   0x01u
#define RTC_BKP_DR2   0x02u
#define RTC_BKP_DR3   0x03u
#define RTC_BKP_DR4   0x04u
#define RTC_BKP_DR5   0x05u
#define RTC_BKP_DR6   0x06u
#define RTC_BKP_DR7   0x07u
#define RTC_BKP_DR8   0x08u
#define RTC_BKP_DR9   0x09u
#define RTC_BKP_DR10   0x0Au
#define RTC_BKP_DR11   0x0Bu
#define RTC_BKP_DR12   0x0Cu
#define RTC_BKP_DR13   0x0Du
#define RTC_BKP_DR14   0x0Eu
#define RTC_BKP_DR15   0x0Fu
#define RTC_BKP_DR16   0x10u
#define RTC_BKP_DR17   0x11u
#define RTC_BKP_DR18   0x12u
#define RTC_BKP_DR19   0x13u
#define RTC_BKP_DR20   0x14u
#define RTC_BKP_DR21   0x15u
#define RTC_BKP_DR22   0x16u
#define RTC_BKP_DR23   0x17u
#define RTC_BKP_DR24   0x18u
#define RTC_BKP_DR25   0x19u
#define RTC_BKP_DR26   0x1Au
#define RTC_BKP_DR27   0x1Bu
#define RTC_BKP_DR28   0x1Cu
#define RTC_BKP_DR29   0x1Du
#define RTC_BKP_DR30   0x1Eu
#define RTC_BKP_DR31   0x1Fu
#define RTC_TIMESTAMPEDGE_RISING   0x00000000u
#define RTC_TIMESTAMPEDGE_FALLING   RTC_CR_TSEDGE
#define RTC_TIMESTAMPPIN_DEFAULT   0x00000000u
#define RTC_TAMPER_1   RTC_TAMPCR_TAMP1E
#define RTC_TAMPER_2   RTC_TAMPCR_TAMP2E
#define RTC_TAMPER_3   RTC_TAMPCR_TAMP3E
#define RTC_TAMPER_ALL   (RTC_TAMPER_1 | RTC_TAMPER_2 | RTC_TAMPER_3)
#define RTC_IT_TAMP1   RTC_TAMPCR_TAMP1IE
#define RTC_IT_TAMP2   RTC_TAMPCR_TAMP2IE
#define RTC_IT_TAMP3   RTC_TAMPCR_TAMP3IE
#define RTC_IT_TAMP   RTC_TAMPCR_TAMPIE
#define RTC_IT_TAMPALL   RTC_IT_TAMP
#define RTC_TAMPERTRIGGER_RISINGEDGE   0x01u
#define RTC_TAMPERTRIGGER_FALLINGEDGE   0x02u
#define RTC_TAMPERTRIGGER_LOWLEVEL   0x04u
#define RTC_TAMPERTRIGGER_HIGHLEVEL   0x08u
#define RTC_TAMPER_1_TRIGGER   RTC_TAMPCR_TAMP1TRG
#define RTC_TAMPER_2_TRIGGER   RTC_TAMPCR_TAMP2TRG
#define RTC_TAMPER_3_TRIGGER   RTC_TAMPCR_TAMP3TRG
#define RTC_TAMPER_X_TRIGGER
#define RTC_TAMPER_ERASE_BACKUP_ENABLE   0x00000000u
#define RTC_TAMPER_ERASE_BACKUP_DISABLE   RTC_TAMPCR_TAMP1NOERASE
#define RTC_DISABLE_BKP_ERASE_ON_TAMPER_1   RTC_TAMPCR_TAMP1NOERASE
#define RTC_DISABLE_BKP_ERASE_ON_TAMPER_2   RTC_TAMPCR_TAMP2NOERASE
#define RTC_DISABLE_BKP_ERASE_ON_TAMPER_3   RTC_TAMPCR_TAMP3NOERASE
#define RTC_DISABLE_BKP_ERASE_ON_TAMPER_MASK
#define RTC_TAMPERMASK_FLAG_DISABLE   0x00000000u
#define RTC_TAMPERMASK_FLAG_ENABLE   RTC_TAMPCR_TAMP1MF
#define RTC_TAMPER_1_MASK_FLAG   RTC_TAMPCR_TAMP1MF
#define RTC_TAMPER_2_MASK_FLAG   RTC_TAMPCR_TAMP2MF
#define RTC_TAMPER_3_MASK_FLAG   RTC_TAMPCR_TAMP3MF
#define RTC_TAMPER_X_MASK_FLAG
#define RTC_TAMPERFILTER_DISABLE   0x00000000u
#define RTC_TAMPERFILTER_2SAMPLE   RTC_TAMPCR_TAMPFLT_0
#define RTC_TAMPERFILTER_4SAMPLE   RTC_TAMPCR_TAMPFLT_1
#define RTC_TAMPERFILTER_8SAMPLE   RTC_TAMPCR_TAMPFLT
#define RTC_TAMPERFILTER_MASK   RTC_TAMPCR_TAMPFLT
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV32768   0x00000000u
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV16384   RTC_TAMPCR_TAMPFREQ_0
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV8192   RTC_TAMPCR_TAMPFREQ_1
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV4096   (RTC_TAMPCR_TAMPFREQ_0 | RTC_TAMPCR_TAMPFREQ_1)
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV2048   RTC_TAMPCR_TAMPFREQ_2
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV1024   (RTC_TAMPCR_TAMPFREQ_0 | RTC_TAMPCR_TAMPFREQ_2)
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV512   (RTC_TAMPCR_TAMPFREQ_1 | RTC_TAMPCR_TAMPFREQ_2)
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_DIV256   RTC_TAMPCR_TAMPFREQ
#define RTC_TAMPERSAMPLINGFREQ_RTCCLK_MASK   RTC_TAMPCR_TAMPFREQ
#define RTC_TAMPERPRECHARGEDURATION_1RTCCLK   0x00000000u
#define RTC_TAMPERPRECHARGEDURATION_2RTCCLK   RTC_TAMPCR_TAMPPRCH_0
#define RTC_TAMPERPRECHARGEDURATION_4RTCCLK   RTC_TAMPCR_TAMPPRCH_1
#define RTC_TAMPERPRECHARGEDURATION_8RTCCLK   RTC_TAMPCR_TAMPPRCH
#define RTC_TAMPERPRECHARGEDURATION_MASK   RTC_TAMPCR_TAMPPRCH
#define RTC_TIMESTAMPONTAMPERDETECTION_DISABLE   0x00000000u
#define RTC_TIMESTAMPONTAMPERDETECTION_ENABLE   RTC_TAMPCR_TAMPTS
#define RTC_TIMESTAMPONTAMPERDETECTION_MASK   RTC_TAMPCR_TAMPTS
#define RTC_TAMPER_PULLUP_ENABLE   0x00000000u
#define RTC_TAMPER_PULLUP_DISABLE   RTC_TAMPCR_TAMPPUDIS
#define RTC_TAMPER_PULLUP_MASK   RTC_TAMPCR_TAMPPUDIS
#define RTC_FLAG_TAMP1F   RTC_ISR_TAMP1F
#define RTC_FLAG_TAMP2F   RTC_ISR_TAMP2F
#define RTC_FLAG_TAMP3F   RTC_ISR_TAMP3F
#define RTC_ATAMP_ENABLE   1u
#define RTC_ATAMP_DISABLE   0u
#define RTC_ATAMP_INTERRUPT_ENABLE   1u
#define RTC_ATAMP_INTERRUPT_DISABLE   0u
#define RTC_ATAMP_FILTER_ENABLE   TAMP_ATCR1_FLTEN
#define RTC_ATAMP_FILTER_DISABLE   0u
#define RTC_ATAMP_ASYNCPRES_RTCCLK   0u
#define RTC_ATAMP_ASYNCPRES_RTCCLK_2   TAMP_ATCR1_ATCKSEL_0
#define RTC_ATAMP_ASYNCPRES_RTCCLK_4   TAMP_ATCR1_ATCKSEL_1
#define RTC_ATAMP_ASYNCPRES_RTCCLK_8   (TAMP_ATCR1_ATCKSEL_1 | TAMP_ATCR1_ATCKSEL_0)
#define RTC_ATAMP_ASYNCPRES_RTCCLK_16   TAMP_ATCR1_ATCKSEL_2
#define RTC_ATAMP_ASYNCPRES_RTCCLK_32   (TAMP_ATCR1_ATCKSEL_2 | TAMP_ATCR1_ATCKSEL_0)
#define RTC_ATAMP_ASYNCPRES_RTCCLK_64   (TAMP_ATCR1_ATCKSEL_2 | TAMP_ATCR1_ATCKSEL_1)
#define RTC_ATAMP_ASYNCPRES_RTCCLK_128   (TAMP_ATCR1_ATCKSEL_2 | TAMP_ATCR1_ATCKSEL_1 | TAMP_ATCR1_ATCKSEL_0)
#define RTC_ATAMP_1   0u
#define RTC_ATAMP_2   1u
#define RTC_ATAMP_3   2u
#define RTC_ATAMP_4   3u
#define RTC_ATAMP_5   4u
#define RTC_ATAMP_6   5u
#define RTC_ATAMP_7   6u
#define RTC_ATAMP_8   7u
#define RTC_MONOTONIC_COUNTER_1   0u
#define RTC_WAKEUPCLOCK_RTCCLK_DIV16   0x00000000u
#define RTC_WAKEUPCLOCK_RTCCLK_DIV8   RTC_CR_WUCKSEL_0
#define RTC_WAKEUPCLOCK_RTCCLK_DIV4   RTC_CR_WUCKSEL_1
#define RTC_WAKEUPCLOCK_RTCCLK_DIV2   (RTC_CR_WUCKSEL_0 | RTC_CR_WUCKSEL_1)
#define RTC_WAKEUPCLOCK_CK_SPRE_16BITS   RTC_CR_WUCKSEL_2
#define RTC_WAKEUPCLOCK_CK_SPRE_17BITS   (RTC_CR_WUCKSEL_1 | RTC_CR_WUCKSEL_2)
#define RTC_SMOOTHCALIB_PERIOD_32SEC   0x00000000u
#define RTC_SMOOTHCALIB_PERIOD_16SEC   RTC_CALR_CALW16
#define RTC_SMOOTHCALIB_PERIOD_8SEC   RTC_CALR_CALW8
#define RTC_SMOOTHCALIB_PLUSPULSES_SET   RTC_CALR_CALP
#define RTC_SMOOTHCALIB_PLUSPULSES_RESET   0x00000000u
#define RTC_CALIBOUTPUT_512HZ   0x00000000u
#define RTC_CALIBOUTPUT_1HZ   RTC_CR_COSEL
#define RTC_SHIFTADD1S_RESET   0x00000000u
#define RTC_SHIFTADD1S_SET   RTC_SHIFTR_ADD1S
#define __HAL_RTC_WAKEUPTIMER_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_WUTE))
 Enable the RTC WakeUp Timer peripheral.
#define __HAL_RTC_WAKEUPTIMER_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_WUTE))
 Disable the RTC WakeUp Timer peripheral.
#define __HAL_RTC_WAKEUPTIMER_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR |= (__INTERRUPT__))
 Enable the RTC WakeUpTimer interrupt.
#define __HAL_RTC_WAKEUPTIMER_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__))
 Disable the RTC WakeUpTimer interrupt.
#define __HAL_RTC_WAKEUPTIMER_GET_IT(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->ISR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC WakeUpTimer interrupt has occurred or not.
#define __HAL_RTC_WAKEUPTIMER_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC Wake Up timer interrupt has been enabled or not.
#define __HAL_RTC_WAKEUPTIMER_GET_FLAG(__HANDLE__, __FLAG__)   (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
 Get the selected RTC WakeUpTimer's flag status.
#define __HAL_RTC_WAKEUPTIMER_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ISR) = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))
 Clear the RTC Wake Up timer's pending flags.
#define __HAL_RTC_TAMPER1_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR |= (RTC_TAMPCR_TAMP1E))
 Enable the RTC Tamper1 input detection.
#define __HAL_RTC_TAMPER1_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TAMPCR_TAMP1E))
 Disable the RTC Tamper1 input detection.
#define __HAL_RTC_TAMPER2_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR |= (RTC_TAMPCR_TAMP2E))
 Enable the RTC Tamper2 input detection.
#define __HAL_RTC_TAMPER2_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TAMPCR_TAMP2E))
 Disable the RTC Tamper2 input detection.
#define __HAL_RTC_TAMPER3_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR |= (RTC_TAMPCR_TAMP3E))
 Enable the RTC Tamper3 input detection.
#define __HAL_RTC_TAMPER3_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TAMPCR_TAMP3E))
 Disable the RTC Tamper3 input detection.
#define __HAL_RTC_TAMPER_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->TAMPCR |= (__INTERRUPT__))
 Enable the RTC Tamper interrupt.
#define __HAL_RTC_TAMPER_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->TAMPCR &= ~(__INTERRUPT__))
 Disable the RTC Tamper interrupt.
#define __HAL_RTC_TAMPER_GET_IT(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->ISR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC Tamper interrupt has occurred or not.
#define __HAL_RTC_TAMPER_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->TAMPCR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC Tamper interrupt has been enabled or not.
#define __HAL_RTC_TAMPER_GET_FLAG(__HANDLE__, __FLAG__)   (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
 Get the selected RTC Tamper's flag status.
#define __HAL_RTC_TAMPER_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ISR) = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT))
 Clear the RTC Tamper's pending flags.
#define __HAL_RTC_TAMPER_GET_SAMPLING_FREQ(__HANDLE__)   ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPERSAMPLINGFREQ_RTCCLK_MASK)))
 Get the frequency at which each of the Tamper inputs are sampled.
#define __HAL_RTC_TAMPER_GET_SAMPLES_COUNT(__HANDLE__)   ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPERFILTER_MASK)))
 Get the number of consecutive samples at the specified level needed to activate a Tamper event.
#define __HAL_RTC_TAMPER_GET_PRCHRG_DURATION(__HANDLE__)   ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPERPRECHARGEDURATION_MASK)))
 Get the pull-up resistors precharge duration.
#define __HAL_RTC_TAMPER_GET_PULLUP_STATUS(__HANDLE__)   ((uint32_t)(((__HANDLE__)->Instance->TAMPCR) & (RTC_TAMPER_PULLUP_MASK)))
 Get the pull-up resistors status.
#define __HAL_RTC_TIMESTAMP_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_TSE))
 Enable the RTC TimeStamp peripheral.
#define __HAL_RTC_TIMESTAMP_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_TSE))
 Disable the RTC TimeStamp peripheral.
#define __HAL_RTC_TIMESTAMP_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR |= (__INTERRUPT__))
 Enable the RTC TimeStamp interrupt.
#define __HAL_RTC_TIMESTAMP_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__))
 Disable the RTC TimeStamp interrupt.
#define __HAL_RTC_TIMESTAMP_GET_IT(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->ISR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC TimeStamp interrupt has occurred or not.
#define __HAL_RTC_TIMESTAMP_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC Time Stamp interrupt has been enabled or not.
#define __HAL_RTC_TIMESTAMP_GET_FLAG(__HANDLE__, __FLAG__)   (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
 Get the selected RTC TimeStamp's flag status.
#define __HAL_RTC_TIMESTAMP_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT)))
 Clear the RTC Time Stamp's pending flags.
#define __HAL_RTC_INTERNAL_TIMESTAMP_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_ITSE))
 Enable the RTC internal TimeStamp peripheral.
#define __HAL_RTC_INTERNAL_TIMESTAMP_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ITSE))
 Disable the RTC internal TimeStamp peripheral.
#define __HAL_RTC_INTERNAL_TIMESTAMP_GET_FLAG(__HANDLE__, __FLAG__)   (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
 Get the selected RTC Internal Time Stamp's flag status.
#define __HAL_RTC_INTERNAL_TIMESTAMP_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT)))
 Clear the RTC Internal Time Stamp's pending flags.
#define __HAL_RTC_TAMPTS_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR |= (RTC_TIMESTAMPONTAMPERDETECTION_MASK))
 Enable the RTC TimeStamp on Tamper detection.
#define __HAL_RTC_TAMPTS_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR &= ~(RTC_TIMESTAMPONTAMPERDETECTION_MASK))
 Disable the RTC TimeStamp on Tamper detection.
#define __HAL_RTC_TAMPTS_GET_STATUS(__HANDLE__)   ((__HANDLE__)->Instance->TAMPCR &= RTC_TIMESTAMPONTAMPERDETECTION_MASK)
 Get activation status of the RTC TimeStamp on Tamper detection.
#define __HAL_RTC_CALIBRATION_OUTPUT_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_COE))
 Enable the RTC calibration output.
#define __HAL_RTC_CALIBRATION_OUTPUT_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_COE))
 Disable the calibration output.
#define __HAL_RTC_CLOCKREF_DETECTION_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_REFCKON))
 Enable the clock reference detection.
#define __HAL_RTC_CLOCKREF_DETECTION_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_REFCKON))
 Disable the clock reference detection.
#define __HAL_RTC_SHIFT_GET_FLAG(__HANDLE__, __FLAG__)   (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
 Get the selected RTC shift operation's flag status.
#define __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_IT()   (EXTI->IMR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Enable interrupt on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_IT()   (EXTI->IMR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT))
 Disable interrupt on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_EVENT()   (EXTI->EMR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Enable event on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_EVENT()   (EXTI->EMR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT))
 Disable event on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTID3_ENABLE_EVENT()   (EXTI->D3PMR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Enable event on the RTC WakeUp Timer associated D3 Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTID3_DISABLE_EVENT()   (EXTI->D3PMR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT))
 Disable event on the RTC WakeUp Timer associated D3 Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_FALLING_EDGE()   (EXTI->FTSR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Enable falling edge trigger on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_FALLING_EDGE()   (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT))
 Disable falling edge trigger on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_RISING_EDGE()   (EXTI->RTSR1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Enable rising edge trigger on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_RISING_EDGE()   (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_WAKEUPTIMER_EVENT))
 Disable rising edge trigger on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable rising & falling edge trigger on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_WAKEUPTIMER_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable rising & falling edge trigger on the RTC WakeUp Timer associated Exti line. This parameter can be:
#define __HAL_RTC_WAKEUPTIMER_EXTI_GET_FLAG()   (EXTI->PR1 & RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Check whether the RTC WakeUp Timer associated Exti line interrupt flag is set or not.
#define __HAL_RTC_WAKEUPTIMER_EXTI_CLEAR_FLAG()   (EXTI->PR1 = RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Clear the RTC WakeUp Timer associated Exti line flag.
#define __HAL_RTC_WAKEUPTIMER_EXTID3_GET_FLAG()   (EXTI_D3->PR1 & RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Check whether the RTC WakeUp Timer associated D3 Exti line interrupt flag is set or not.
#define __HAL_RTC_WAKEUPTIMER_EXTID3_CLEAR_FLAG()   (EXTI_D3->PR1 = RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Clear the RTC WakeUp Timer associated D3 Exti line flag.
#define __HAL_RTC_WAKEUPTIMER_EXTI_GENERATE_SWIT()   (EXTI->SWIER1 |= RTC_EXTI_LINE_WAKEUPTIMER_EVENT)
 Generate a Software interrupt on the RTC WakeUp Timer associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_IT()   (EXTI->IMR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Enable interrupt on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_IT()   (EXTI->IMR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT))
 Disable interrupt on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_EVENT()   (EXTI->EMR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Enable event on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_EVENT()   (EXTI->EMR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT))
 Disable event on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_FALLING_EDGE()   (EXTI->FTSR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Enable falling edge trigger on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_FALLING_EDGE()   (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT))
 Disable falling edge trigger on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_RISING_EDGE()   (EXTI->RTSR1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Enable rising edge trigger on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_RISING_EDGE()   (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT))
 Disable rising edge trigger on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable rising & falling edge trigger on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable rising & falling edge trigger on the RTC Tamper and Timestamp associated Exti line.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_GET_FLAG()   (EXTI->PR1 & RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Check whether the RTC Tamper and Timestamp associated Exti line interrupt flag is set or not.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_CLEAR_FLAG()   (EXTI->PR1 = RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Clear the RTC Tamper and Timestamp associated Exti line flag.
#define __HAL_RTC_TAMPER_TIMESTAMP_EXTI_GENERATE_SWIT()   (EXTI->SWIER1 |= RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT)
 Generate a Software interrupt on the RTC Tamper and Timestamp associated Exti line.
#define RTC_EXTI_LINE_TAMPER_TIMESTAMP_EVENT   EXTI_IMR1_IM18
#define RTC_EXTI_LINE_WAKEUPTIMER_EVENT   EXTI_IMR1_IM19
#define RTC_TAMPER_X   ((uint32_t) (RTC_TAMPER_1 | RTC_TAMPER_2 | RTC_TAMPER_3))
#define RTC_TAMPER_X_INTERRUPT   ((uint32_t) (RTC_IT_TAMP1 | RTC_IT_TAMP2 | RTC_IT_TAMP3))
#define IS_RTC_BKP(__BKP__)   ((__BKP__) < BKP_REG_NUMBER)
#define IS_TIMESTAMP_EDGE(EDGE)
#define IS_RTC_TIMESTAMP_PIN(PIN)   (((PIN) == RTC_TIMESTAMPPIN_DEFAULT))
#define IS_RTC_WAKEUP_CLOCK(CLOCK)
#define IS_RTC_WAKEUP_COUNTER(COUNTER)   ((COUNTER) <= RTC_WUTR_WUT)
#define IS_RTC_SMOOTH_CALIB_PERIOD(PERIOD)
#define IS_RTC_SMOOTH_CALIB_PLUS(PLUS)
#define IS_RTC_SMOOTH_CALIB_MINUS(VALUE)   ((VALUE) <= RTC_CALR_CALM)
#define IS_RTC_SHIFT_ADD1S(SEL)
#define IS_RTC_SHIFT_SUBFS(FS)   ((FS) <= RTC_SHIFTR_SUBFS)
#define IS_RTC_CALIB_OUTPUT(OUTPUT)
#define IS_RTC_TAMPER(__TAMPER__)
#define IS_RTC_TAMPER_INTERRUPT(__INTERRUPT__)
#define IS_RTC_TAMPER_TRIGGER(__TRIGGER__)
#define IS_RTC_TAMPER_ERASE_MODE(__MODE__)
#define IS_RTC_TAMPER_MASKFLAG_STATE(__STATE__)
#define IS_RTC_TAMPER_FILTER(__FILTER__)
#define IS_RTC_TAMPER_SAMPLING_FREQ(__FREQ__)
#define IS_RTC_TAMPER_PRECHARGE_DURATION(__DURATION__)
#define IS_RTC_TAMPER_PULLUP_STATE(__STATE__)
#define IS_RTC_TAMPER_TIMESTAMPONTAMPER_DETECTION(__DETECTION__)
#define IS_RTC_TAMPER_FILTER_CONFIG_CORRECT(FILTER, TRIGGER)
#define IS_RTC_INTERNAL_TAMPER(__INT_TAMPER__)
HAL_StatusTypeDef HAL_RTCEx_SetTimeStamp (RTC_HandleTypeDef *hrtc, uint32_t TimeStampEdge, uint32_t RTC_TimeStampPin)
HAL_StatusTypeDef HAL_RTCEx_SetTimeStamp_IT (RTC_HandleTypeDef *hrtc, uint32_t TimeStampEdge, uint32_t RTC_TimeStampPin)
HAL_StatusTypeDef HAL_RTCEx_DeactivateTimeStamp (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_SetInternalTimeStamp (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_DeactivateInternalTimeStamp (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_GetTimeStamp (RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTimeStamp, RTC_DateTypeDef *sTimeStampDate, uint32_t Format)
void HAL_RTCEx_TamperTimeStampIRQHandler (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_TimeStampEventCallback (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_PollForTimeStampEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
HAL_StatusTypeDef HAL_RTCEx_SetTamper (RTC_HandleTypeDef *hrtc, RTC_TamperTypeDef *sTamper)
HAL_StatusTypeDef HAL_RTCEx_SetTamper_IT (RTC_HandleTypeDef *hrtc, RTC_TamperTypeDef *sTamper)
HAL_StatusTypeDef HAL_RTCEx_DeactivateTamper (RTC_HandleTypeDef *hrtc, uint32_t Tamper)
HAL_StatusTypeDef HAL_RTCEx_PollForTamper1Event (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
HAL_StatusTypeDef HAL_RTCEx_PollForTamper2Event (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
HAL_StatusTypeDef HAL_RTCEx_PollForTamper3Event (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
void HAL_RTCEx_Tamper1EventCallback (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_Tamper2EventCallback (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_Tamper3EventCallback (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_SetWakeUpTimer (RTC_HandleTypeDef *hrtc, uint32_t WakeUpCounter, uint32_t WakeUpClock)
HAL_StatusTypeDef HAL_RTCEx_SetWakeUpTimer_IT (RTC_HandleTypeDef *hrtc, uint32_t WakeUpCounter, uint32_t WakeUpClock)
HAL_StatusTypeDef HAL_RTCEx_DeactivateWakeUpTimer (RTC_HandleTypeDef *hrtc)
uint32_t HAL_RTCEx_GetWakeUpTimer (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_WakeUpTimerIRQHandler (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_WakeUpTimerEventCallback (RTC_HandleTypeDef *hrtc)
 Wake Up Timer Event Callback in non blocking mode.
HAL_StatusTypeDef HAL_RTCEx_PollForWakeUpTimerEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
void HAL_RTCEx_BKUPWrite (RTC_HandleTypeDef *hrtc, uint32_t BackupRegister, uint32_t Data)
uint32_t HAL_RTCEx_BKUPRead (RTC_HandleTypeDef *hrtc, uint32_t BackupRegister)
HAL_StatusTypeDef HAL_RTCEx_SetSmoothCalib (RTC_HandleTypeDef *hrtc, uint32_t SmoothCalibPeriod, uint32_t SmoothCalibPlusPulses, uint32_t SmoothCalibMinusPulsesValue)
HAL_StatusTypeDef HAL_RTCEx_SetSynchroShift (RTC_HandleTypeDef *hrtc, uint32_t ShiftAdd1S, uint32_t ShiftSubFS)
HAL_StatusTypeDef HAL_RTCEx_SetCalibrationOutPut (RTC_HandleTypeDef *hrtc, uint32_t CalibOutput)
HAL_StatusTypeDef HAL_RTCEx_DeactivateCalibrationOutPut (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_SetRefClock (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_DeactivateRefClock (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_EnableBypassShadow (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_DisableBypassShadow (RTC_HandleTypeDef *hrtc)
void HAL_RTCEx_AlarmBEventCallback (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTCEx_PollForAlarmBEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
Author
MCD Application Team
Attention
