RTEMS 6.1-rc2
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_rtc.h File Reference
Header file of RTC HAL module. More...
#include "stm32h7xx_hal_def.h"
#include "stm32h7xx_hal_rtc_ex.h"
struct  RTC_InitTypeDef
 RTC Configuration Structure definition. More...
struct  RTC_TimeTypeDef
 RTC Time structure definition. More...
struct  RTC_DateTypeDef
 RTC Date structure definition. More...
struct  RTC_AlarmTypeDef
 RTC Alarm structure definition. More...
struct  RTC_HandleTypeDef
 RTC Handle Structure definition. More...
#define RTC_HOURFORMAT_24   0x00000000u
#define RTC_HOURFORMAT_12   RTC_CR_FMT
#define RTC_OUTPUT_DISABLE   0x00000000u
#define RTC_OUTPUT_ALARMA   RTC_CR_OSEL_0
#define RTC_OUTPUT_ALARMB   RTC_CR_OSEL_1
#define RTC_OUTPUT_WAKEUP   RTC_CR_OSEL
#define RTC_OUTPUT_POLARITY_HIGH   0x00000000u
#define RTC_OUTPUT_POLARITY_LOW   RTC_CR_POL
#define RTC_OUTPUT_TYPE_PUSHPULL   RTC_OR_ALARMOUTTYPE
#define RTC_OUTPUT_TYPE_OPENDRAIN   0x00000000u
#define RTC_ALARM_OUTPUT_TYPE   RTC_OR_ALARMOUTTYPE
#define RTC_OUTPUT_REMAP_NONE   0x00000000u
#define RTC_OUTPUT_REMAP_POS1   RTC_OR_OUT_RMP
#define RTC_HOURFORMAT12_AM   ((uint8_t)0x00)
#define RTC_HOURFORMAT12_PM   ((uint8_t)0x01)
#define RTC_DAYLIGHTSAVING_SUB1H   RTC_CR_SUB1H
#define RTC_DAYLIGHTSAVING_ADD1H   RTC_CR_ADD1H
#define RTC_DAYLIGHTSAVING_NONE   0x00000000u
#define RTC_STOREOPERATION_RESET   0x00000000u
#define RTC_STOREOPERATION_SET   RTC_CR_BKP
#define RTC_FORMAT_BIN   0x00000000u
#define RTC_FORMAT_BCD   0x00000001u
#define RTC_MONTH_JANUARY   ((uint8_t)0x01)
#define RTC_MONTH_FEBRUARY   ((uint8_t)0x02)
#define RTC_MONTH_MARCH   ((uint8_t)0x03)
#define RTC_MONTH_APRIL   ((uint8_t)0x04)
#define RTC_MONTH_MAY   ((uint8_t)0x05)
#define RTC_MONTH_JUNE   ((uint8_t)0x06)
#define RTC_MONTH_JULY   ((uint8_t)0x07)
#define RTC_MONTH_AUGUST   ((uint8_t)0x08)
#define RTC_MONTH_SEPTEMBER   ((uint8_t)0x09)
#define RTC_MONTH_OCTOBER   ((uint8_t)0x10)
#define RTC_MONTH_NOVEMBER   ((uint8_t)0x11)
#define RTC_MONTH_DECEMBER   ((uint8_t)0x12)
#define RTC_WEEKDAY_MONDAY   ((uint8_t)0x01)
#define RTC_WEEKDAY_TUESDAY   ((uint8_t)0x02)
#define RTC_WEEKDAY_WEDNESDAY   ((uint8_t)0x03)
#define RTC_WEEKDAY_THURSDAY   ((uint8_t)0x04)
#define RTC_WEEKDAY_FRIDAY   ((uint8_t)0x05)
#define RTC_WEEKDAY_SATURDAY   ((uint8_t)0x06)
#define RTC_WEEKDAY_SUNDAY   ((uint8_t)0x07)
#define RTC_ALARMDATEWEEKDAYSEL_DATE   0x00000000u
#define RTC_ALARMDATEWEEKDAYSEL_WEEKDAY   RTC_ALRMAR_WDSEL
#define RTC_ALARMMASK_NONE   0x00000000u
#define RTC_ALARMMASK_DATEWEEKDAY   RTC_ALRMAR_MSK4
#define RTC_ALARMMASK_HOURS   RTC_ALRMAR_MSK3
#define RTC_ALARMMASK_MINUTES   RTC_ALRMAR_MSK2
#define RTC_ALARMMASK_SECONDS   RTC_ALRMAR_MSK1
#define RTC_ALARMMASK_ALL
#define RTC_ALARM_A   RTC_CR_ALRAE
#define RTC_ALARM_B   RTC_CR_ALRBE
#define RTC_ALARMSUBSECONDMASK_ALL   0x00000000u
#define RTC_ALARMSUBSECONDMASK_SS14_1   RTC_ALRMASSR_MASKSS_0
#define RTC_ALARMSUBSECONDMASK_SS14_2   RTC_ALRMASSR_MASKSS_1
#define RTC_ALARMSUBSECONDMASK_SS14_3   (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_1)
#define RTC_ALARMSUBSECONDMASK_SS14_4   RTC_ALRMASSR_MASKSS_2
#define RTC_ALARMSUBSECONDMASK_SS14_5   (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_2)
#define RTC_ALARMSUBSECONDMASK_SS14_6   (RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_2)
#define RTC_ALARMSUBSECONDMASK_SS14_7   (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_2)
#define RTC_ALARMSUBSECONDMASK_SS14_8   RTC_ALRMASSR_MASKSS_3
#define RTC_ALARMSUBSECONDMASK_SS14_9   (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_3)
#define RTC_ALARMSUBSECONDMASK_SS14_10   (RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_3)
#define RTC_ALARMSUBSECONDMASK_SS14_11   (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_3)
#define RTC_ALARMSUBSECONDMASK_SS14_12   (RTC_ALRMASSR_MASKSS_2 | RTC_ALRMASSR_MASKSS_3)
#define RTC_ALARMSUBSECONDMASK_SS14_13   (RTC_ALRMASSR_MASKSS_0 | RTC_ALRMASSR_MASKSS_2 | RTC_ALRMASSR_MASKSS_3)
#define RTC_ALARMSUBSECONDMASK_SS14   (RTC_ALRMASSR_MASKSS_1 | RTC_ALRMASSR_MASKSS_2 | RTC_ALRMASSR_MASKSS_3)
#define RTC_ALARMSUBSECONDMASK_NONE   RTC_ALRMASSR_MASKSS
#define RTC_IT_TS   RTC_CR_TSIE
#define RTC_IT_WUT   RTC_CR_WUTIE
#define RTC_IT_ALRA   RTC_CR_ALRAIE
#define RTC_IT_ALRB   RTC_CR_ALRBIE
#define RTC_FLAG_RECALPF   RTC_ISR_RECALPF
#define RTC_FLAG_TSOVF   RTC_ISR_TSOVF
#define RTC_FLAG_TSF   RTC_ISR_TSF
#define RTC_FLAG_ITSF   RTC_ISR_ITSF
#define RTC_FLAG_WUTF   RTC_ISR_WUTF
#define RTC_FLAG_ALRBF   RTC_ISR_ALRBF
#define RTC_FLAG_ALRAF   RTC_ISR_ALRAF
#define RTC_FLAG_INITF   RTC_ISR_INITF
#define RTC_FLAG_RSF   RTC_ISR_RSF
#define RTC_FLAG_INITS   RTC_ISR_INITS
#define RTC_FLAG_SHPF   RTC_ISR_SHPF
#define RTC_FLAG_WUTWF   RTC_ISR_WUTWF
#define RTC_FLAG_ALRBWF   RTC_ISR_ALRBWF
#define RTC_FLAG_ALRAWF   RTC_ISR_ALRAWF
#define __HAL_RTC_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_RTC_STATE_RESET)
 Reset RTC handle state.
#define __HAL_RTC_WRITEPROTECTION_DISABLE(__HANDLE__)
 Disable the write protection for RTC registers.
#define __HAL_RTC_WRITEPROTECTION_ENABLE(__HANDLE__)
 Enable the write protection for RTC registers.
#define __HAL_RTC_IS_CALENDAR_INITIALIZED(__HANDLE__)   (((((__HANDLE__)->Instance->ISR) & (RTC_FLAG_INITS)) == RTC_FLAG_INITS) ? 1U : 0U)
 Check whether the RTC Calendar is initialized.
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_ADD1H(__HANDLE__, __BKP__)
 Add 1 hour (summer time change).
#define __HAL_RTC_DAYLIGHT_SAVING_TIME_SUB1H(__HANDLE__, __BKP__)
 Subtract 1 hour (winter time change).
#define __HAL_RTC_ALARMA_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRAE))
 Enable the RTC ALARMA peripheral.
#define __HAL_RTC_ALARMA_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRAE))
 Disable the RTC ALARMA peripheral.
#define __HAL_RTC_ALARMB_ENABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR |= (RTC_CR_ALRBE))
 Enable the RTC ALARMB peripheral.
#define __HAL_RTC_ALARMB_DISABLE(__HANDLE__)   ((__HANDLE__)->Instance->CR &= ~(RTC_CR_ALRBE))
 Disable the RTC ALARMB peripheral.
#define __HAL_RTC_ALARM_ENABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR |= (__INTERRUPT__))
 Enable the RTC Alarm interrupt.
#define __HAL_RTC_ALARM_DISABLE_IT(__HANDLE__, __INTERRUPT__)   ((__HANDLE__)->Instance->CR &= ~(__INTERRUPT__))
 Disable the RTC Alarm interrupt.
#define __HAL_RTC_ALARM_GET_IT(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->ISR)& (__INTERRUPT__ >> 4)) != 0U)? 1U : 0U)
 Check whether the specified RTC Alarm interrupt has occurred or not.
#define __HAL_RTC_ALARM_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__)   (((((__HANDLE__)->Instance->CR) & (__INTERRUPT__)) != 0U) ? 1U : 0U)
 Check whether the specified RTC Alarm interrupt has been enabled or not.
#define __HAL_RTC_ALARM_GET_FLAG(__HANDLE__, __FLAG__)   (((((__HANDLE__)->Instance->ISR) & (__FLAG__)) != 0U) ? 1U : 0U)
 Get the selected RTC Alarm's flag status.
#define __HAL_RTC_ALARM_CLEAR_FLAG(__HANDLE__, __FLAG__)   ((__HANDLE__)->Instance->ISR = (~((__FLAG__) | RTC_ISR_INIT)|((__HANDLE__)->Instance->ISR & RTC_ISR_INIT)))
 Clear the RTC Alarm's pending flags.
#define __HAL_RTC_ALARM_EXTI_ENABLE_IT()   (EXTI->IMR1 |= RTC_EXTI_LINE_ALARM_EVENT)
 Enable interrupt on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_IT()   (EXTI->IMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
 Disable interrupt on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_EVENT()   (EXTI->EMR1 |= RTC_EXTI_LINE_ALARM_EVENT)
 Enable event on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_EVENT()   (EXTI->EMR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
 Disable event on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_FALLING_EDGE()   (EXTI->FTSR1 |= RTC_EXTI_LINE_ALARM_EVENT)
 Enable falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_FALLING_EDGE()   (EXTI->FTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
 Disable falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_EDGE()   (EXTI->RTSR1 |= RTC_EXTI_LINE_ALARM_EVENT)
 Enable rising edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_EDGE()   (EXTI->RTSR1 &= ~(RTC_EXTI_LINE_ALARM_EVENT))
 Disable rising edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable rising & falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable rising & falling edge trigger on the RTC Alarm associated Exti line.
#define __HAL_RTC_ALARM_EXTI_GET_FLAG()   (EXTI->PR1 & RTC_EXTI_LINE_ALARM_EVENT)
 Check whether the RTC Alarm associated Exti line interrupt flag is set or not.
#define __HAL_RTC_ALARM_EXTI_CLEAR_FLAG()   (EXTI->PR1 = (RTC_EXTI_LINE_ALARM_EVENT))
 Clear the RTC Alarm associated Exti line flag.
#define __HAL_RTC_ALARM_EXTI_GENERATE_SWIT()   (EXTI->SWIER1 |= RTC_EXTI_LINE_ALARM_EVENT)
 Generate a Software interrupt on RTC Alarm associated Exti line.
#define RTC_TR_RESERVED_MASK
#define RTC_DR_RESERVED_MASK
#define RTC_INIT_MASK   0xFFFFFFFFu
#define RTC_ISR_RESERVED_MASK   0x0003FFFFu
#define RTC_RSF_MASK   (~(RTC_ISR_INIT | RTC_ISR_RSF))
#define RTC_TIMEOUT_VALUE   1000u
#define RTC_EXTI_LINE_ALARM_EVENT   EXTI_IMR1_IM17
#define IS_RTC_OUTPUT(OUTPUT)
#define IS_RTC_HOUR_FORMAT(FORMAT)
#define IS_RTC_OUTPUT_POL(POL)
#define IS_RTC_OUTPUT_TYPE(TYPE)
#define IS_RTC_OUTPUT_REMAP(REMAP)
#define IS_RTC_HOURFORMAT12(PM)
#define IS_RTC_DAYLIGHT_SAVING(SAVE)
#define IS_RTC_STORE_OPERATION(OPERATION)
#define IS_RTC_FORMAT(FORMAT)
#define IS_RTC_YEAR(YEAR)   ((YEAR) <= 99u)
#define IS_RTC_MONTH(MONTH)   (((MONTH) >= 1u) && ((MONTH) <= 12u))
#define IS_RTC_DATE(DATE)   (((DATE) >= 1u) && ((DATE) <= 31u))
#define IS_RTC_WEEKDAY(WEEKDAY)
#define IS_RTC_ALARM_DATE_WEEKDAY_DATE(DATE)   (((DATE) > 0u) && ((DATE) <= 31u))
#define IS_RTC_ALARM_DATE_WEEKDAY_WEEKDAY(WEEKDAY)
#define IS_RTC_ALARM_DATE_WEEKDAY_SEL(SEL)
#define IS_RTC_ALARM_MASK(MASK)   (((MASK) & ~(RTC_ALARMMASK_ALL)) == 0u)
#define IS_RTC_ALARM(ALARM)
#define IS_RTC_ALARM_SUB_SECOND_VALUE(VALUE)   ((VALUE) <= RTC_ALRMASSR_SS)
#define IS_RTC_ALARM_SUB_SECOND_MASK(MASK)
#define IS_RTC_ASYNCH_PREDIV(PREDIV)   ((PREDIV) <= (RTC_PRER_PREDIV_A >> RTC_PRER_PREDIV_A_Pos))
#define IS_RTC_SYNCH_PREDIV(PREDIV)   ((PREDIV) <= (RTC_PRER_PREDIV_S >> RTC_PRER_PREDIV_S_Pos))
#define IS_RTC_HOUR12(HOUR)   (((HOUR) > 0u) && ((HOUR) <= 12u))
#define IS_RTC_HOUR24(HOUR)   ((HOUR) <= 23u)
#define IS_RTC_MINUTES(MINUTES)   ((MINUTES) <= 59u)
#define IS_RTC_SECONDS(SECONDS)   ((SECONDS) <= 59u)
enum  HAL_RTCStateTypeDef {
  HAL_RTC_STATE_RESET = 0x00U , HAL_RTC_STATE_READY = 0x01U , HAL_RTC_STATE_BUSY = 0x02U , HAL_RTC_STATE_TIMEOUT = 0x03U ,
  HAL_RTC_STATE_ERROR = 0x04U
 HAL State structures definition. More...
HAL_StatusTypeDef HAL_RTC_Init (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTC_DeInit (RTC_HandleTypeDef *hrtc)
void HAL_RTC_MspInit (RTC_HandleTypeDef *hrtc)
void HAL_RTC_MspDeInit (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef HAL_RTC_SetTime (RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTime, uint32_t Format)
HAL_StatusTypeDef HAL_RTC_GetTime (RTC_HandleTypeDef *hrtc, RTC_TimeTypeDef *sTime, uint32_t Format)
HAL_StatusTypeDef HAL_RTC_SetDate (RTC_HandleTypeDef *hrtc, RTC_DateTypeDef *sDate, uint32_t Format)
HAL_StatusTypeDef HAL_RTC_GetDate (RTC_HandleTypeDef *hrtc, RTC_DateTypeDef *sDate, uint32_t Format)
HAL_StatusTypeDef HAL_RTC_SetAlarm (RTC_HandleTypeDef *hrtc, RTC_AlarmTypeDef *sAlarm, uint32_t Format)
HAL_StatusTypeDef HAL_RTC_SetAlarm_IT (RTC_HandleTypeDef *hrtc, RTC_AlarmTypeDef *sAlarm, uint32_t Format)
HAL_StatusTypeDef HAL_RTC_DeactivateAlarm (RTC_HandleTypeDef *hrtc, uint32_t Alarm)
HAL_StatusTypeDef HAL_RTC_GetAlarm (RTC_HandleTypeDef *hrtc, RTC_AlarmTypeDef *sAlarm, uint32_t Alarm, uint32_t Format)
void HAL_RTC_AlarmIRQHandler (RTC_HandleTypeDef *hrtc)
void HAL_RTC_AlarmAEventCallback (RTC_HandleTypeDef *hrtc)
 ALARM A Event Callback in non blocking mode.
HAL_StatusTypeDef HAL_RTC_PollForAlarmAEvent (RTC_HandleTypeDef *hrtc, uint32_t Timeout)
HAL_StatusTypeDef HAL_RTC_WaitForSynchro (RTC_HandleTypeDef *hrtc)
HAL_RTCStateTypeDef HAL_RTC_GetState (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef RTC_EnterInitMode (RTC_HandleTypeDef *hrtc)
HAL_StatusTypeDef RTC_ExitInitMode (RTC_HandleTypeDef *hrtc)
uint8_t RTC_ByteToBcd2 (uint8_t Value)
uint8_t RTC_Bcd2ToByte (uint8_t Value)
Author
MCD Application Team
Attention
