RTEMS 6.1-rc2
RAMECC HAL module driver. This file provides firmware functions to manage the following functionalities of the RAM ECC monitoring (RAMECC) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] (#) Enable and latch error information through HAL_RAMECC_Init(). (#) For a given Monitor, enable and disable interrupt through HAL_RAMECC_EnableNotification(). To enable a notification for a given RAMECC instance, use global interrupts. To enable a notification for only RAMECC monitor, use monitor interrupts. All possible notifications are defined in the driver header file under RAMECC_Interrupt group. *** Silent mode *** =================== [..] (+) Use HAL_RAMECC_StartMonitor() to start RAMECC latch failing information without enabling any notification. *** Interrupt mode *** ====================== [..] (+) Use HAL_RAMECC_EnableNotification() to enable interrupts for a given error. (+) Configure the RAMECC interrupt priority using HAL_NVIC_SetPriority(). (+) Enable the RAMECC IRQ handler using HAL_NVIC_EnableIRQ(). (+) Start RAMECC latch failing information using HAL_RAMECC_StartMonitor(). *** Failing information *** ====================== [..] (#) Use HAL_RAMECC_GetFailingAddress() function to return the RAMECC failing address. (#) Use HAL_RAMECC_GetFailingDataLow() function to return the RAMECC failing data low. (#) Use HAL_RAMECC_GetFailingDataHigh() function to return the RAMECC failing data high. (#) Use HAL_RAMECC_GetHammingErrorCode() function to return the RAMECC Hamming bits injected. (#) Use HAL_RAMECC_IsECCSingleErrorDetected() function to check if a single error was detected and corrected. (#) Use HAL_RAMECC_IsECCDoubleErrorDetected() function to check if a double error was dedetected. *** RAMECC HAL driver macros list *** ============================================= [..] Below the list of used macros in RAMECC HAL driver. (+) __HAL_RAMECC_ENABLE_IT : Enable the specified ECCRAM Monitor interrupts. (+) __HAL_RAMECC_DISABLE_IT : Disable the specified ECCRAM Monitor interrupts. (+) __HAL_RAMECC_GET_FLAG : Return the current RAMECC Monitor selected flag. (+) __HAL_RAMECC_CLEAR_FLAG : Clear the current RAMECC Monitor selected flag.
