RTEMS 6.1-rc2
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_nor.h File Reference
Header file of NOR HAL module. More...
#include "stm32h7xx_ll_fmc.h"
struct  NOR_IDTypeDef
 FMC NOR ID typedef. More...
struct  NOR_CFITypeDef
 FMC NOR CFI typedef. More...
struct  NOR_HandleTypeDef
 NOR handle Structure definition. More...
#define __HAL_NOR_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_NOR_STATE_RESET)
 Reset NOR handle state.
#define MC_ADDRESS   ((uint16_t)0x0000)
#define DEVICE_CODE1_ADDR   ((uint16_t)0x0001)
#define DEVICE_CODE2_ADDR   ((uint16_t)0x000E)
#define DEVICE_CODE3_ADDR   ((uint16_t)0x000F)
#define CFI1_ADDRESS   ((uint16_t)0x0061)
#define CFI2_ADDRESS   ((uint16_t)0x0062)
#define CFI3_ADDRESS   ((uint16_t)0x0063)
#define CFI4_ADDRESS   ((uint16_t)0x0064)
#define NOR_TMEOUT   ((uint16_t)0xFFFF)
#define NOR_MEMORY_8B   ((uint8_t)0x00)
#define NOR_MEMORY_16B   ((uint8_t)0x01)
#define NOR_MEMORY_ADRESS1   (0x60000000U)
#define NOR_MEMORY_ADRESS2   (0x64000000U)
#define NOR_MEMORY_ADRESS3   (0x68000000U)
#define NOR_MEMORY_ADRESS4   (0x6C000000U)
#define NOR_ADDR_SHIFT(__NOR_ADDRESS, __NOR_MEMORY_WIDTH_, __ADDRESS__)
 NOR memory address shifting.
#define NOR_WRITE(__ADDRESS__, __DATA__)
 NOR memory write data to specified address.
enum  HAL_NOR_StateTypeDef {
  HAL_NOR_STATE_RESET = 0x00U , HAL_NOR_STATE_READY = 0x01U , HAL_NOR_STATE_BUSY = 0x02U , HAL_NOR_STATE_ERROR = 0x03U ,
  HAL_NOR_STATE_PROTECTED = 0x04U
 HAL SRAM State structures definition. More...
enum  HAL_NOR_StatusTypeDef { HAL_NOR_STATUS_SUCCESS = 0U , HAL_NOR_STATUS_ONGOING , HAL_NOR_STATUS_ERROR , HAL_NOR_STATUS_TIMEOUT }
 FMC NOR Status typedef.
HAL_StatusTypeDef HAL_NOR_Init (NOR_HandleTypeDef *hnor, FMC_NORSRAM_TimingTypeDef *Timing, FMC_NORSRAM_TimingTypeDef *ExtTiming)
HAL_StatusTypeDef HAL_NOR_DeInit (NOR_HandleTypeDef *hnor)
void HAL_NOR_MspInit (NOR_HandleTypeDef *hnor)
void HAL_NOR_MspDeInit (NOR_HandleTypeDef *hnor)
void HAL_NOR_MspWait (NOR_HandleTypeDef *hnor, uint32_t Timeout)
HAL_StatusTypeDef HAL_NOR_Read_ID (NOR_HandleTypeDef *hnor, NOR_IDTypeDef *pNOR_ID)
HAL_StatusTypeDef HAL_NOR_ReturnToReadMode (NOR_HandleTypeDef *hnor)
HAL_StatusTypeDef HAL_NOR_Read (NOR_HandleTypeDef *hnor, uint32_t *pAddress, uint16_t *pData)
HAL_StatusTypeDef HAL_NOR_Program (NOR_HandleTypeDef *hnor, uint32_t *pAddress, uint16_t *pData)
HAL_StatusTypeDef HAL_NOR_ReadBuffer (NOR_HandleTypeDef *hnor, uint32_t uwAddress, uint16_t *pData, uint32_t uwBufferSize)
HAL_StatusTypeDef HAL_NOR_ProgramBuffer (NOR_HandleTypeDef *hnor, uint32_t uwAddress, uint16_t *pData, uint32_t uwBufferSize)
HAL_StatusTypeDef HAL_NOR_Erase_Block (NOR_HandleTypeDef *hnor, uint32_t BlockAddress, uint32_t Address)
HAL_StatusTypeDef HAL_NOR_Erase_Chip (NOR_HandleTypeDef *hnor, uint32_t Address)
HAL_StatusTypeDef HAL_NOR_Read_CFI (NOR_HandleTypeDef *hnor, NOR_CFITypeDef *pNOR_CFI)
HAL_StatusTypeDef HAL_NOR_WriteOperation_Enable (NOR_HandleTypeDef *hnor)
HAL_StatusTypeDef HAL_NOR_WriteOperation_Disable (NOR_HandleTypeDef *hnor)
HAL_NOR_StateTypeDef HAL_NOR_GetState (NOR_HandleTypeDef *hnor)
HAL_NOR_StatusTypeDef HAL_NOR_GetStatus (NOR_HandleTypeDef *hnor, uint32_t Address, uint32_t Timeout)
Author
MCD Application Team
Attention
