RTEMS 6.1-rc2
Data Structures | Macros | Enumerations | Functions
stm32h7xx_hal_nand.h File Reference
Header file of NAND HAL module. More...
#include "stm32h7xx_ll_fmc.h"
struct  NAND_IDTypeDef
 NAND Memory electronic signature Structure definition. More...
struct  NAND_AddressTypeDef
 NAND Memory address Structure definition. More...
struct  NAND_DeviceConfigTypeDef
 NAND Memory info Structure definition. More...
struct  NAND_HandleTypeDef
 NAND handle Structure definition. More...
#define __HAL_NAND_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = HAL_NAND_STATE_RESET)
 Reset NAND handle state.
#define NAND_DEVICE   0x80000000UL
#define NAND_WRITE_TIMEOUT   0x01000000UL
#define CMD_AREA   (1UL<<16U) /* A16 = CLE high */
#define ADDR_AREA   (1UL<<17U) /* A17 = ALE high */
#define NAND_CMD_AREA_A   ((uint8_t)0x00)
#define NAND_CMD_AREA_B   ((uint8_t)0x01)
#define NAND_CMD_AREA_C   ((uint8_t)0x50)
#define NAND_CMD_AREA_TRUE1   ((uint8_t)0x30)
#define NAND_CMD_WRITE0   ((uint8_t)0x80)
#define NAND_CMD_WRITE_TRUE1   ((uint8_t)0x10)
#define NAND_CMD_ERASE0   ((uint8_t)0x60)
#define NAND_CMD_ERASE1   ((uint8_t)0xD0)
#define NAND_CMD_READID   ((uint8_t)0x90)
#define NAND_CMD_STATUS   ((uint8_t)0x70)
#define NAND_CMD_LOCK_STATUS   ((uint8_t)0x7A)
#define NAND_CMD_RESET   ((uint8_t)0xFF)
#define NAND_VALID_ADDRESS   0x00000100UL
#define NAND_INVALID_ADDRESS   0x00000200UL
#define NAND_TIMEOUT_ERROR   0x00000400UL
#define NAND_BUSY   0x00000000UL
#define NAND_ERROR   0x00000001UL
#define NAND_READY   0x00000040UL
#define ARRAY_ADDRESS(__ADDRESS__, __HANDLE__)
 NAND memory address computation.
#define COLUMN_ADDRESS(__HANDLE__)   ((__HANDLE__)->Config.PageSize)
 NAND memory Column address computation.
#define ADDR_1ST_CYCLE(__ADDRESS__)   (uint8_t)(__ADDRESS__) /* 1st addressing cycle */
 NAND memory address cycling.
#define ADDR_2ND_CYCLE(__ADDRESS__)   (uint8_t)((__ADDRESS__) >> 8) /* 2nd addressing cycle */
#define ADDR_3RD_CYCLE(__ADDRESS__)   (uint8_t)((__ADDRESS__) >> 16) /* 3rd addressing cycle */
#define ADDR_4TH_CYCLE(__ADDRESS__)   (uint8_t)((__ADDRESS__) >> 24) /* 4th addressing cycle */
#define COLUMN_1ST_CYCLE(__ADDRESS__)   (uint8_t)((__ADDRESS__) & 0xFFU) /* 1st Column addressing cycle */
 NAND memory Columns cycling.
#define COLUMN_2ND_CYCLE(__ADDRESS__)   (uint8_t)((__ADDRESS__) >> 8) /* 2nd Column addressing cycle */
enum  HAL_NAND_StateTypeDef { HAL_NAND_STATE_RESET = 0x00U , HAL_NAND_STATE_READY = 0x01U , HAL_NAND_STATE_BUSY = 0x02U , HAL_NAND_STATE_ERROR = 0x03U }
 HAL NAND State structures definition. More...
HAL_StatusTypeDef HAL_NAND_Init (NAND_HandleTypeDef *hnand, FMC_NAND_PCC_TimingTypeDef *ComSpace_Timing, FMC_NAND_PCC_TimingTypeDef *AttSpace_Timing)
HAL_StatusTypeDef HAL_NAND_DeInit (NAND_HandleTypeDef *hnand)
HAL_StatusTypeDef HAL_NAND_ConfigDevice (NAND_HandleTypeDef *hnand, NAND_DeviceConfigTypeDef *pDeviceConfig)
HAL_StatusTypeDef HAL_NAND_Read_ID (NAND_HandleTypeDef *hnand, NAND_IDTypeDef *pNAND_ID)
void HAL_NAND_MspInit (NAND_HandleTypeDef *hnand)
void HAL_NAND_MspDeInit (NAND_HandleTypeDef *hnand)
void HAL_NAND_IRQHandler (NAND_HandleTypeDef *hnand)
void HAL_NAND_ITCallback (NAND_HandleTypeDef *hnand)
HAL_StatusTypeDef HAL_NAND_Reset (NAND_HandleTypeDef *hnand)
HAL_StatusTypeDef HAL_NAND_Read_Page_8b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint8_t *pBuffer, uint32_t NumPageToRead)
HAL_StatusTypeDef HAL_NAND_Write_Page_8b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint8_t *pBuffer, uint32_t NumPageToWrite)
HAL_StatusTypeDef HAL_NAND_Read_SpareArea_8b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint8_t *pBuffer, uint32_t NumSpareAreaToRead)
HAL_StatusTypeDef HAL_NAND_Write_SpareArea_8b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint8_t *pBuffer, uint32_t NumSpareAreaTowrite)
HAL_StatusTypeDef HAL_NAND_Read_Page_16b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint16_t *pBuffer, uint32_t NumPageToRead)
HAL_StatusTypeDef HAL_NAND_Write_Page_16b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint16_t *pBuffer, uint32_t NumPageToWrite)
HAL_StatusTypeDef HAL_NAND_Read_SpareArea_16b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint16_t *pBuffer, uint32_t NumSpareAreaToRead)
HAL_StatusTypeDef HAL_NAND_Write_SpareArea_16b (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress, uint16_t *pBuffer, uint32_t NumSpareAreaTowrite)
HAL_StatusTypeDef HAL_NAND_Erase_Block (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress)
uint32_t HAL_NAND_Address_Inc (NAND_HandleTypeDef *hnand, NAND_AddressTypeDef *pAddress)
HAL_StatusTypeDef HAL_NAND_ECC_Enable (NAND_HandleTypeDef *hnand)
HAL_StatusTypeDef HAL_NAND_ECC_Disable (NAND_HandleTypeDef *hnand)
HAL_StatusTypeDef HAL_NAND_GetECC (NAND_HandleTypeDef *hnand, uint32_t *ECCval, uint32_t Timeout)
HAL_NAND_StateTypeDef HAL_NAND_GetState (NAND_HandleTypeDef *hnand)
uint32_t HAL_NAND_Read_Status (NAND_HandleTypeDef *hnand)
Author
MCD Application Team
Attention
