RTEMS 6.1-rc2
MDIOS HAL module driver. This file provides firmware functions to manage the following functionalities of the MDIOS Peripheral. More...
#include "stm32h7xx_hal.h"
=============================================================================== ##### How to use this driver ##### =============================================================================== [..] The MDIOS HAL driver can be used as follow: (#) Declare a MDIOS_HandleTypeDef handle structure. (#) Initialize the MDIOS low level resources by implementing the HAL_MDIOS_MspInit() API: (##) Enable the MDIOS interface clock. (##) MDIOS pins configuration: (+++) Enable clocks for the MDIOS GPIOs. (+++) Configure the MDIOS pins as alternate function. (##) NVIC configuration if you need to use interrupt process: (+++) Configure the MDIOS interrupt priority. (+++) Enable the NVIC MDIOS IRQ handle. (#) Program the Port Address and the Preamble Check in the Init structure. (#) Initialize the MDIOS registers by calling the HAL_MDIOS_Init() API. (#) Perform direct slave read/write operations using the following APIs: (##) Read the value of a DINn register: HAL_MDIOS_ReadReg() (##) Write a value to a DOUTn register: HAL_MDIOS_WriteReg() (#) Get the Master read/write operations flags using the following APIs: (##) Bit map of DOUTn registers read by Master: HAL_MDIOS_GetReadRegAddress() (##) Bit map of DINn registers written by Master : HAL_MDIOS_GetWrittenRegAddress() (#) Clear the read/write flags using the following APIs: (##) Clear read flags of a set of registers: HAL_MDIOS_ClearReadRegAddress() (##) Clear write flags of a set of registers: HAL_MDIOS_ClearWriteRegAddress() (#) Enable interrupts on events using HAL_MDIOS_EnableEvents(), when called the MDIOS will generate an interrupt in the following cases: (##) a DINn register written by the Master (##) a DOUTn register read by the Master (##) an error occur (@) A callback is executed for each genereted interrupt, so the driver provide the following HAL_MDIOS_WriteCpltCallback(), HAL_MDIOS_ReadCpltCallback() and HAL_MDIOS_ErrorCallback() (@) HAL_MDIOS_IRQHandler() must be called from the MDIOS IRQ Handler, to handle the interrupt and execute the previous callbacks (#) Reset the MDIOS peripheral and all related resources by calling the HAL_MDIOS_DeInit() API. (##) HAL_MDIOS_MspDeInit() must be implemented to reset low level resources (GPIO, Clocks, NVIC configuration ...) *** Callback registration *** ============================================= The compilation define USE_HAL_MDIOS_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use Function @ref HAL_MDIOS_RegisterCallback() to register an interrupt callback. Function @ref HAL_MDIOS_RegisterCallback() allows to register following callbacks: (+) WriteCpltCallback : Write Complete Callback. (+) ReadCpltCallback : Read Complete Callback. (+) ErrorCallback : Error Callback. (+) WakeUpCallback : Wake UP Callback (+) MspInitCallback : MspInit Callback. (+) MspDeInitCallback : MspDeInit Callback. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. Use function @ref HAL_MDIOS_UnRegisterCallback() to reset a callback to the default weak function. @ref HAL_MDIOS_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) WriteCpltCallback : Write Complete Callback. (+) ReadCpltCallback : Read Complete Callback. (+) ErrorCallback : Error Callback. (+) WakeUpCallback : Wake UP Callback (+) MspInitCallback : MspInit Callback. (+) MspDeInitCallback : MspDeInit Callback. By default, after the HAL_MDIOS_Init and when the state is HAL_MDIOS_STATE_RESET all callbacks are set to the corresponding weak functions: examples @ref HAL_MDIOS_WriteCpltCallback(), @ref HAL_MDIOS_ReadCpltCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak function in the HAL_MDIOS_Init/ @ref HAL_MDIOS_DeInit only when these callbacks are null (not registered beforehand). if not, MspInit or MspDeInit are not null, the HAL_MDIOS_Init/ @ref HAL_MDIOS_DeInit keep and use the user MspInit/MspDeInit callbacks (registered beforehand) Callbacks can be registered/unregistered in HAL_MDIOS_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_MDIOS_STATE_READY or HAL_MDIOS_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using @ref HAL_MDIOS_RegisterCallback() before calling @ref HAL_MDIOS_DeInit or HAL_MDIOS_Init function. When The compilation define USE_HAL_MDIOS_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
