RTEMS 6.1-rc2
Header file of I2S HAL module. More...
#include "stm32h7xx_hal_def.h"
struct | I2S_InitTypeDef |
I2S Init structure definition. More... | |
struct | __I2S_HandleTypeDef |
I2S handle Structure definition. More... | |
#define | HAL_I2S_ERROR_NONE (0x00000000UL) |
#define | HAL_I2S_ERROR_TIMEOUT (0x00000001UL) |
#define | HAL_I2S_ERROR_OVR (0x00000002UL) |
#define | HAL_I2S_ERROR_UDR (0x00000004UL) |
#define | HAL_I2S_ERROR_DMA (0x00000008UL) |
#define | HAL_I2S_ERROR_PRESCALER (0x00000010UL) |
#define | HAL_I2S_ERROR_FRE (0x00000020UL) |
#define | HAL_I2S_ERROR_NO_OGT (0x00000040UL) |
#define | HAL_I2S_ERROR_NOT_SUPPORTED (0x00000080UL) |
#define | I2S_MODE_SLAVE_TX (0x00000000UL) |
#define | I2S_MODE_SLAVE_RX (SPI_I2SCFGR_I2SCFG_0) |
#define | I2S_MODE_MASTER_TX (SPI_I2SCFGR_I2SCFG_1) |
#define | I2S_MODE_MASTER_RX (SPI_I2SCFGR_I2SCFG_0 | SPI_I2SCFGR_I2SCFG_1) |
#define | I2S_MODE_SLAVE_FULLDUPLEX (SPI_I2SCFGR_I2SCFG_2) |
#define | I2S_MODE_MASTER_FULLDUPLEX (SPI_I2SCFGR_I2SCFG_2 | SPI_I2SCFGR_I2SCFG_0) |
#define | I2S_STANDARD_PHILIPS (0x00000000UL) |
#define | I2S_STANDARD_MSB (SPI_I2SCFGR_I2SSTD_0) |
#define | I2S_STANDARD_LSB (SPI_I2SCFGR_I2SSTD_1) |
#define | I2S_STANDARD_PCM_SHORT (SPI_I2SCFGR_I2SSTD_0 | SPI_I2SCFGR_I2SSTD_1) |
#define | I2S_STANDARD_PCM_LONG (SPI_I2SCFGR_I2SSTD_0 | SPI_I2SCFGR_I2SSTD_1 | SPI_I2SCFGR_PCMSYNC) |
#define | I2S_DATAFORMAT_16B (0x00000000UL) |
#define | I2S_DATAFORMAT_16B_EXTENDED (SPI_I2SCFGR_CHLEN) |
#define | I2S_DATAFORMAT_24B (SPI_I2SCFGR_DATLEN_0) |
#define | I2S_DATAFORMAT_32B (SPI_I2SCFGR_DATLEN_1) |
#define | I2S_MCLKOUTPUT_ENABLE (SPI_I2SCFGR_MCKOE) |
#define | I2S_MCLKOUTPUT_DISABLE (0x00000000UL) |
#define | I2S_AUDIOFREQ_192K (192000UL) |
#define | I2S_AUDIOFREQ_96K (96000UL) |
#define | I2S_AUDIOFREQ_48K (48000UL) |
#define | I2S_AUDIOFREQ_44K (44100UL) |
#define | I2S_AUDIOFREQ_32K (32000UL) |
#define | I2S_AUDIOFREQ_22K (22050UL) |
#define | I2S_AUDIOFREQ_16K (16000UL) |
#define | I2S_AUDIOFREQ_11K (11025UL) |
#define | I2S_AUDIOFREQ_8K (8000UL) |
#define | I2S_AUDIOFREQ_DEFAULT (2UL) |
#define | I2S_CPOL_LOW (0x00000000UL) |
#define | I2S_CPOL_HIGH (SPI_I2SCFGR_CKPOL) |
#define | I2S_FIRSTBIT_MSB (0x00000000UL) |
#define | I2S_FIRSTBIT_LSB SPI_CFG2_LSBFRST |
#define | I2S_WS_INVERSION_DISABLE (0x00000000UL) |
#define | I2S_WS_INVERSION_ENABLE SPI_I2SCFGR_WSINV |
#define | I2S_DATA_24BIT_ALIGNMENT_RIGHT (0x00000000UL) |
#define | I2S_DATA_24BIT_ALIGNMENT_LEFT SPI_I2SCFGR_DATFMT |
#define | I2S_MASTER_KEEP_IO_STATE_DISABLE (0x00000000U) |
#define | I2S_MASTER_KEEP_IO_STATE_ENABLE SPI_CFG2_AFCNTR |
#define | I2S_IT_RXP SPI_IER_RXPIE |
#define | I2S_IT_TXP SPI_IER_TXPIE |
#define | I2S_IT_DXP SPI_IER_DXPIE |
#define | I2S_IT_UDR SPI_IER_UDRIE |
#define | I2S_IT_OVR SPI_IER_OVRIE |
#define | I2S_IT_FRE SPI_IER_TIFREIE |
#define | I2S_IT_ERR (SPI_IER_UDRIE | SPI_IER_OVRIE | SPI_IER_TIFREIE) |
#define | I2S_FLAG_RXP SPI_SR_RXP /* I2S status flag : Rx-Packet available flag */ |
#define | I2S_FLAG_TXP SPI_SR_TXP /* I2S status flag : Tx-Packet space available flag */ |
#define | I2S_FLAG_DXP SPI_SR_DXP /* I2S status flag : Dx-Packet space available flag */ |
#define | I2S_FLAG_UDR SPI_SR_UDR /* I2S Error flag : Underrun flag */ |
#define | I2S_FLAG_OVR SPI_SR_OVR /* I2S Error flag : Overrun flag */ |
#define | I2S_FLAG_FRE SPI_SR_TIFRE /* I2S Error flag : TI mode frame format error flag */ |
#define | I2S_FLAG_MASK (SPI_SR_RXP | SPI_SR_TXP | SPI_SR_DXP |SPI_SR_UDR | SPI_SR_OVR | SPI_SR_TIFRE) |
#define | __HAL_I2S_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_I2S_STATE_RESET) |
Reset I2S handle state. | |
#define | __HAL_I2S_ENABLE(__HANDLE__) (SET_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_SPE)) |
Enable the specified SPI peripheral (in I2S mode). | |
#define | __HAL_I2S_DISABLE(__HANDLE__) (CLEAR_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_SPE)) |
Disable the specified SPI peripheral (in I2S mode). | |
#define | __HAL_I2S_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->IER |= (__INTERRUPT__)) |
Enable the specified I2S interrupts. | |
#define | __HAL_I2S_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->IER &= (~(__INTERRUPT__))) |
Disable the specified I2S interrupts. | |
#define | __HAL_I2S_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
Check if the specified I2S interrupt source is enabled or disabled. | |
#define | __HAL_I2S_GET_FLAG(__HANDLE__, __FLAG__) ((((__HANDLE__)->Instance->SR) & (__FLAG__)) == (__FLAG__)) |
Check whether the specified I2S flag is set or not. | |
#define | __HAL_I2S_CLEAR_OVRFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_OVRC) |
Clear the I2S OVR pending flag. | |
#define | __HAL_I2S_CLEAR_UDRFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_UDRC) |
Clear the I2S UDR pending flag. | |
#define | __HAL_I2S_CLEAR_TIFREFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TIFREC) |
Clear the I2S FRE pending flag. | |
#define | I2S_CHECK_FLAG(__SR__, __FLAG__) |
Check whether the specified SPI flag is set or not. | |
#define | I2S_CHECK_IT_SOURCE(__IER__, __INTERRUPT__) |
Check whether the specified SPI Interrupt is set or not. | |
#define | IS_I2S_MODE(__MODE__) |
Checks if I2S Mode parameter is in allowed range. | |
#define | IS_I2S_MASTER(__MODE__) |
#define | IS_I2S_SLAVE(__MODE__) |
#define | IS_I2S_FULLDUPLEX(__MODE__) |
#define | IS_I2S_STANDARD(__STANDARD__) |
#define | IS_I2S_DATA_FORMAT(__FORMAT__) |
#define | IS_I2S_MCLK_OUTPUT(__OUTPUT__) |
#define | IS_I2S_AUDIO_FREQ(__FREQ__) |
#define | IS_I2S_CPOL(__CPOL__) |
#define | IS_I2S_FIRST_BIT(__BIT__) |
#define | IS_I2S_WS_INVERSION(__WSINV__) |
#define | IS_I2S_DATA_24BIT_ALIGNMENT(__ALIGNMENT__) |
#define | IS_I2S_MASTER_KEEP_IO_STATE(__AFCNTR__) |
Typedefs | |
typedef struct __I2S_HandleTypeDef | I2S_HandleTypeDef |
I2S handle Structure definition. | |
Enumerations | |
enum | HAL_I2S_StateTypeDef { HAL_I2S_STATE_RESET = 0x00UL , HAL_I2S_STATE_READY = 0x01UL , HAL_I2S_STATE_BUSY = 0x02UL , HAL_I2S_STATE_BUSY_TX = 0x03UL , HAL_I2S_STATE_BUSY_RX = 0x04UL , HAL_I2S_STATE_BUSY_TX_RX = 0x05UL , HAL_I2S_STATE_TIMEOUT = 0x06UL , HAL_I2S_STATE_ERROR = 0x07UL } |
HAL State structures definition. More... | |
HAL_StatusTypeDef | HAL_I2S_Init (I2S_HandleTypeDef *hi2s) |
HAL_StatusTypeDef | HAL_I2S_DeInit (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_MspInit (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_MspDeInit (I2S_HandleTypeDef *hi2s) |
HAL_StatusTypeDef | HAL_I2S_Transmit (I2S_HandleTypeDef *hi2s, const uint16_t *pData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_I2S_Receive (I2S_HandleTypeDef *hi2s, uint16_t *pData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_I2SEx_TransmitReceive (I2S_HandleTypeDef *hi2s, const uint16_t *pTxData, uint16_t *pRxData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_I2S_Transmit_IT (I2S_HandleTypeDef *hi2s, const uint16_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_I2S_Receive_IT (I2S_HandleTypeDef *hi2s, uint16_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_I2SEx_TransmitReceive_IT (I2S_HandleTypeDef *hi2s, const uint16_t *pTxData, uint16_t *pRxData, uint16_t Size) |
void | HAL_I2S_IRQHandler (I2S_HandleTypeDef *hi2s) |
HAL_StatusTypeDef | HAL_I2S_Transmit_DMA (I2S_HandleTypeDef *hi2s, const uint16_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_I2S_Receive_DMA (I2S_HandleTypeDef *hi2s, uint16_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_I2SEx_TransmitReceive_DMA (I2S_HandleTypeDef *hi2s, const uint16_t *pTxData, uint16_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_I2S_DMAPause (I2S_HandleTypeDef *hi2s) |
HAL_StatusTypeDef | HAL_I2S_DMAResume (I2S_HandleTypeDef *hi2s) |
HAL_StatusTypeDef | HAL_I2S_DMAStop (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_TxHalfCpltCallback (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_TxCpltCallback (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_RxHalfCpltCallback (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_RxCpltCallback (I2S_HandleTypeDef *hi2s) |
void | HAL_I2SEx_TxRxHalfCpltCallback (I2S_HandleTypeDef *hi2s) |
void | HAL_I2SEx_TxRxCpltCallback (I2S_HandleTypeDef *hi2s) |
void | HAL_I2S_ErrorCallback (I2S_HandleTypeDef *hi2s) |
HAL_I2S_StateTypeDef | HAL_I2S_GetState (const I2S_HandleTypeDef *hi2s) |
uint32_t | HAL_I2S_GetError (const I2S_HandleTypeDef *hi2s) |
