RTEMS 6.1-rc2
Header file of I2C HAL Extended module. More...
#include "stm32h7xx_hal_def.h"
#define | I2C_ANALOGFILTER_ENABLE 0x00000000U |
#define | I2C_ANALOGFILTER_DISABLE I2C_CR1_ANFOFF |
#define | I2C_FMP_NOT_SUPPORTED 0xAAAA0000U |
#define | I2C_FASTMODEPLUS_PB6 SYSCFG_PMCR_I2C_PB6_FMP |
#define | I2C_FASTMODEPLUS_PB7 SYSCFG_PMCR_I2C_PB7_FMP |
#define | I2C_FASTMODEPLUS_PB8 SYSCFG_PMCR_I2C_PB8_FMP |
#define | I2C_FASTMODEPLUS_PB9 SYSCFG_PMCR_I2C_PB9_FMP |
#define | I2C_FASTMODEPLUS_I2C1 SYSCFG_PMCR_I2C1_FMP |
#define | I2C_FASTMODEPLUS_I2C2 SYSCFG_PMCR_I2C2_FMP |
#define | I2C_FASTMODEPLUS_I2C3 SYSCFG_PMCR_I2C3_FMP |
#define | I2C_FASTMODEPLUS_I2C4 SYSCFG_PMCR_I2C4_FMP |
#define | I2C_FASTMODEPLUS_I2C5 (uint32_t)(0x00001000U | I2C_FMP_NOT_SUPPORTED) |
#define | IS_I2C_ANALOG_FILTER(FILTER) |
#define | IS_I2C_DIGITAL_FILTER(FILTER) ((FILTER) <= 0x0000000FU) |
#define | IS_I2C_FASTMODEPLUS(__CONFIG__) |
HAL_StatusTypeDef | HAL_I2CEx_ConfigAnalogFilter (I2C_HandleTypeDef *hi2c, uint32_t AnalogFilter) |
HAL_StatusTypeDef | HAL_I2CEx_ConfigDigitalFilter (I2C_HandleTypeDef *hi2c, uint32_t DigitalFilter) |
HAL_StatusTypeDef | HAL_I2CEx_EnableWakeUp (I2C_HandleTypeDef *hi2c) |
HAL_StatusTypeDef | HAL_I2CEx_DisableWakeUp (I2C_HandleTypeDef *hi2c) |
void | HAL_I2CEx_EnableFastModePlus (uint32_t ConfigFastModePlus) |
void | HAL_I2CEx_DisableFastModePlus (uint32_t ConfigFastModePlus) |
