RTEMS 6.1-rc2
Header file of FLASH HAL module. More...
#include "stm32h7xx_hal_def.h"
struct | FLASH_EraseInitTypeDef |
FLASH Erase structure definition. More... | |
struct | FLASH_OBProgramInitTypeDef |
FLASH Option Bytes Program structure definition. More... | |
struct | FLASH_CRCInitTypeDef |
#define | FLASH_TYPEERASE_SECTORS 0x00U |
#define | FLASH_TYPEERASE_MASSERASE 0x01U |
#define | OB_WRPSTATE_DISABLE 0x00000000U |
#define | OB_WRPSTATE_ENABLE 0x00000001U |
#define | OPTIONBYTE_WRP 0x01U |
#define | OPTIONBYTE_RDP 0x02U |
#define | OPTIONBYTE_USER 0x04U |
#define | OPTIONBYTE_PCROP 0x08U |
#define | OPTIONBYTE_BOR 0x10U |
#define | OPTIONBYTE_SECURE_AREA 0x20U |
#define | OPTIONBYTE_BOOTADD 0x40U |
#define | OPTIONBYTE_ALL |
#define | OB_RDP_LEVEL_0 0xAA00U |
#define | OB_RDP_LEVEL_1 0x5500U |
#define | OB_RDP_LEVEL_2 0xCC00U |
#define | OB_IWDG_SW OB_IWDG1_SW |
#define | OB_IWDG_HW OB_IWDG1_HW |
#define | OB_STOP_NO_RST 0x40U |
#define | OB_STOP_RST 0x00U |
#define | OB_STDBY_NO_RST 0x80U |
#define | OB_STDBY_RST 0x00U |
#define | OB_IWDG_STOP_FREEZE 0x00000000U |
#define | OB_IWDG_STOP_ACTIVE FLASH_OPTSR_FZ_IWDG_STOP |
#define | OB_IWDG_STDBY_FREEZE 0x00000000U |
#define | OB_IWDG_STDBY_ACTIVE FLASH_OPTSR_FZ_IWDG_SDBY |
#define | OB_BOR_LEVEL0 0x00000000U |
#define | OB_BOR_LEVEL1 FLASH_OPTSR_BOR_LEV_0 |
#define | OB_BOR_LEVEL2 FLASH_OPTSR_BOR_LEV_1 |
#define | OB_BOR_LEVEL3 (FLASH_OPTSR_BOR_LEV_1 | FLASH_OPTSR_BOR_LEV_0) |
#define | OB_BOOTADDR_ITCM_RAM 0x0000U |
#define | OB_BOOTADDR_SYSTEM 0x0040U |
#define | OB_BOOTADDR_ITCM_FLASH 0x0080U |
#define | OB_BOOTADDR_AXIM_FLASH 0x2000U |
#define | OB_BOOTADDR_DTCM_RAM 0x8000U |
#define | OB_BOOTADDR_SRAM1 0x8004U |
#define | OB_BOOTADDR_SRAM2 0x8013U |
#define | FLASH_LATENCY_0 FLASH_ACR_LATENCY_0WS |
#define | FLASH_LATENCY_1 FLASH_ACR_LATENCY_1WS |
#define | FLASH_LATENCY_2 FLASH_ACR_LATENCY_2WS |
#define | FLASH_LATENCY_3 FLASH_ACR_LATENCY_3WS |
#define | FLASH_LATENCY_4 FLASH_ACR_LATENCY_4WS |
#define | FLASH_LATENCY_5 FLASH_ACR_LATENCY_5WS |
#define | FLASH_LATENCY_6 FLASH_ACR_LATENCY_6WS |
#define | FLASH_LATENCY_7 FLASH_ACR_LATENCY_7WS |
#define | FLASH_LATENCY_8 FLASH_ACR_LATENCY_8WS |
#define | FLASH_LATENCY_9 FLASH_ACR_LATENCY_9WS |
#define | FLASH_LATENCY_10 FLASH_ACR_LATENCY_10WS |
#define | FLASH_LATENCY_11 FLASH_ACR_LATENCY_11WS |
#define | FLASH_LATENCY_12 FLASH_ACR_LATENCY_12WS |
#define | FLASH_LATENCY_13 FLASH_ACR_LATENCY_13WS |
#define | FLASH_LATENCY_14 FLASH_ACR_LATENCY_14WS |
#define | FLASH_LATENCY_15 FLASH_ACR_LATENCY_15WS |
#define | FLASH_BANK_1 0x01U |
#define | OB_PCROP_RDP_NOT_ERASE 0x00000000U |
#define | OB_PCROP_RDP_ERASE FLASH_PRAR_DMEP |
#define | OB_WRP_SECTOR_0 0x00000001U |
#define | OB_WRP_SECTOR_1 0x00000002U |
#define | OB_WRP_SECTOR_2 0x00000004U |
#define | OB_WRP_SECTOR_3 0x00000008U |
#define | OB_WRP_SECTOR_4 0x00000010U |
#define | OB_WRP_SECTOR_5 0x00000020U |
#define | OB_WRP_SECTOR_6 0x00000040U |
#define | OB_WRP_SECTOR_7 0x00000080U |
#define | OB_WRP_SECTOR_ALL 0x000000FFU |
#define | OB_SECURITY_DISABLE 0x00000000U |
#define | OB_SECURITY_ENABLE FLASH_OPTSR_SECURITY |
#define | OB_ST_RAM_SIZE_2KB 0x00000000U |
#define | OB_ST_RAM_SIZE_4KB FLASH_OPTSR_ST_RAM_SIZE_0 |
#define | OB_ST_RAM_SIZE_8KB FLASH_OPTSR_ST_RAM_SIZE_1 |
#define | OB_ST_RAM_SIZE_16KB FLASH_OPTSR_ST_RAM_SIZE |
#define | OB_IWDG1_SW FLASH_OPTSR_IWDG1_SW |
#define | OB_IWDG1_HW 0x00000000U |
#define | OB_STOP_RST_D1 0x00000000U |
#define | OB_STOP_NO_RST_D1 FLASH_OPTSR_NRST_STOP_D1 |
#define | OB_STDBY_RST_D1 0x00000000U |
#define | OB_STDBY_NO_RST_D1 FLASH_OPTSR_NRST_STBY_D1 |
#define | OB_IOHSLV_DISABLE 0x00000000U |
#define | OB_IOHSLV_ENABLE FLASH_OPTSR_IO_HSLV |
#define | OB_USER_IWDG1_SW 0x0001U |
#define | OB_USER_NRST_STOP_D1 0x0002U |
#define | OB_USER_NRST_STDBY_D1 0x0004U |
#define | OB_USER_IWDG_STOP 0x0008U |
#define | OB_USER_IWDG_STDBY 0x0010U |
#define | OB_USER_ST_RAM_SIZE 0x0020U |
#define | OB_USER_SECURITY 0x0040U |
#define | OB_USER_IOHSLV 0x0080U |
#define | OB_USER_ALL |
#define | OB_BOOT_ADD0 0x01U |
#define | OB_BOOT_ADD1 0x02U |
#define | OB_BOOT_ADD_BOTH 0x03U |
#define | OB_SECURE_RDP_NOT_ERASE 0x00000000U |
#define | OB_SECURE_RDP_ERASE FLASH_SCAR_DMES |
#define | FLASH_CRC_ADDR 0x00000000U |
#define | FLASH_CRC_SECTORS FLASH_CRCCR_CRC_BY_SECT |
#define | FLASH_CRC_BANK (FLASH_CRCCR_ALL_BANK | FLASH_CRCCR_CRC_BY_SECT) |
#define | FLASH_CRC_BURST_SIZE_4 0x00000000U |
#define | FLASH_CRC_BURST_SIZE_16 FLASH_CRCCR_CRC_BURST_0 |
#define | FLASH_CRC_BURST_SIZE_64 FLASH_CRCCR_CRC_BURST_1 |
#define | FLASH_CRC_BURST_SIZE_256 FLASH_CRCCR_CRC_BURST |
#define | FLASH_PROGRAMMING_DELAY_0 0x00000000U |
#define | FLASH_PROGRAMMING_DELAY_1 FLASH_ACR_WRHIGHFREQ_0 |
#define | FLASH_PROGRAMMING_DELAY_2 FLASH_ACR_WRHIGHFREQ_1 |
#define | FLASH_PROGRAMMING_DELAY_3 FLASH_ACR_WRHIGHFREQ |
#define | __HAL_FLASH_CALC_BOOT_BASE_ADR(__ADDRESS__) ((__ADDRESS__) >> 14U) |
Calculate the FLASH Boot Base Address (BOOT_ADD0 or BOOT_ADD1) | |
#define | __HAL_FLASH_SET_PROGRAM_DELAY(__DELAY__) MODIFY_REG(FLASH->ACR, FLASH_ACR_WRHIGHFREQ, (__DELAY__)) |
Set the FLASH Programming Delay. | |
#define | __HAL_FLASH_GET_PROGRAM_DELAY() READ_BIT(FLASH->ACR, FLASH_ACR_WRHIGHFREQ) |
Get the FLASH Programming Delay. | |
#define | IS_FLASH_TYPEERASE(VALUE) |
#define | IS_WRPSTATE(VALUE) |
#define | IS_OPTIONBYTE(VALUE) |
#define | IS_OB_BOOT_ADDRESS(ADDRESS) ((ADDRESS) <= 0x8013U) |
#define | IS_OB_RDP_LEVEL(LEVEL) |
#define | IS_OB_IWDG_SOURCE(SOURCE) (((SOURCE) == OB_IWDG_SW) || ((SOURCE) == OB_IWDG_HW)) |
#define | IS_OB_STOP_SOURCE(SOURCE) (((SOURCE) == OB_STOP_NO_RST) || ((SOURCE) == OB_STOP_RST)) |
#define | IS_OB_STDBY_SOURCE(SOURCE) (((SOURCE) == OB_STDBY_NO_RST) || ((SOURCE) == OB_STDBY_RST)) |
#define | IS_OB_IWDG_STOP_FREEZE(FREEZE) (((FREEZE) == OB_IWDG_STOP_FREEZE) || ((FREEZE) == OB_IWDG_STOP_ACTIVE)) |
#define | IS_OB_IWDG_STDBY_FREEZE(FREEZE) (((FREEZE) == OB_IWDG_STDBY_FREEZE) || ((FREEZE) == OB_IWDG_STDBY_ACTIVE)) |
#define | IS_OB_BOR_LEVEL(LEVEL) |
#define | IS_FLASH_LATENCY(LATENCY) |
#define | IS_FLASH_SECTOR(SECTOR) ((SECTOR) < FLASH_SECTOR_TOTAL) |
#define | IS_OB_WRP_SECTOR(SECTOR) ((SECTOR) != 0x00000000U) |
#define | IS_OB_PCROP_RDP(CONFIG) |
#define | IS_OB_SECURE_RDP(CONFIG) |
#define | IS_OB_USER_IOHSLV(VALUE) (((VALUE) == OB_IOHSLV_DISABLE) || ((VALUE) == OB_IOHSLV_ENABLE)) |
#define | IS_OB_IWDG1_SOURCE(SOURCE) (((SOURCE) == OB_IWDG1_SW) || ((SOURCE) == OB_IWDG1_HW)) |
#define | IS_OB_STOP_D1_RESET(VALUE) (((VALUE) == OB_STOP_NO_RST_D1) || ((VALUE) == OB_STOP_RST_D1)) |
#define | IS_OB_STDBY_D1_RESET(VALUE) (((VALUE) == OB_STDBY_NO_RST_D1) || ((VALUE) == OB_STDBY_RST_D1)) |
#define | IS_OB_USER_IWDG_STOP(VALUE) (((VALUE) == OB_IWDG_STOP_FREEZE) || ((VALUE) == OB_IWDG_STOP_ACTIVE)) |
#define | IS_OB_USER_IWDG_STDBY(VALUE) (((VALUE) == OB_IWDG_STDBY_FREEZE) || ((VALUE) == OB_IWDG_STDBY_ACTIVE)) |
#define | IS_OB_USER_ST_RAM_SIZE(VALUE) |
#define | IS_OB_USER_SECURITY(VALUE) (((VALUE) == OB_SECURITY_ENABLE) || ((VALUE) == OB_SECURITY_DISABLE)) |
#define | IS_OB_USER_TYPE(TYPE) |
#define | IS_OB_BOOT_ADD_OPTION(VALUE) |
#define | IS_FLASH_TYPECRC(VALUE) |
HAL_StatusTypeDef | HAL_FLASHEx_Erase (FLASH_EraseInitTypeDef *pEraseInit, uint32_t *SectorError) |
HAL_StatusTypeDef | HAL_FLASHEx_Erase_IT (FLASH_EraseInitTypeDef *pEraseInit) |
HAL_StatusTypeDef | HAL_FLASHEx_OBProgram (FLASH_OBProgramInitTypeDef *pOBInit) |
void | HAL_FLASHEx_OBGetConfig (FLASH_OBProgramInitTypeDef *pOBInit) |
HAL_StatusTypeDef | HAL_FLASHEx_Unlock_Bank1 (void) |
HAL_StatusTypeDef | HAL_FLASHEx_Lock_Bank1 (void) |
HAL_StatusTypeDef | HAL_FLASHEx_ComputeCRC (FLASH_CRCInitTypeDef *pCRCInit, uint32_t *CRC_Result) |
void | FLASH_Erase_Sector (uint32_t Sector, uint32_t Banks, uint32_t VoltageRange) |
