RTEMS 6.1-rc2
Header file of DMA HAL extension module. More...
#include "stm32h7xx_hal_def.h"
struct | HAL_DMA_MuxSyncConfigTypeDef |
HAL DMAMUX Synchronization configuration structure definition. More... | |
struct | HAL_DMA_MuxRequestGeneratorConfigTypeDef |
HAL DMAMUX request generator parameters structure definition. More... | |
Enumerations | |
enum | HAL_DMA_MemoryTypeDef { MEMORY0 = 0x00U , MEMORY1 = 0x01U } |
HAL DMA Memory definition. More... | |
HAL_StatusTypeDef | HAL_DMAEx_MultiBufferStart (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t SecondMemAddress, uint32_t DataLength) |
HAL_StatusTypeDef | HAL_DMAEx_MultiBufferStart_IT (DMA_HandleTypeDef *hdma, uint32_t SrcAddress, uint32_t DstAddress, uint32_t SecondMemAddress, uint32_t DataLength) |
HAL_StatusTypeDef | HAL_DMAEx_ChangeMemory (DMA_HandleTypeDef *hdma, uint32_t Address, HAL_DMA_MemoryTypeDef memory) |
HAL_StatusTypeDef | HAL_DMAEx_ConfigMuxSync (DMA_HandleTypeDef *hdma, HAL_DMA_MuxSyncConfigTypeDef *pSyncConfig) |
HAL_StatusTypeDef | HAL_DMAEx_ConfigMuxRequestGenerator (DMA_HandleTypeDef *hdma, HAL_DMA_MuxRequestGeneratorConfigTypeDef *pRequestGeneratorConfig) |
HAL_StatusTypeDef | HAL_DMAEx_EnableMuxRequestGenerator (DMA_HandleTypeDef *hdma) |
HAL_StatusTypeDef | HAL_DMAEx_DisableMuxRequestGenerator (DMA_HandleTypeDef *hdma) |
void | HAL_DMAEx_MUX_IRQHandler (DMA_HandleTypeDef *hdma) |
