RTEMS 6.1-rc2
CRYP HAL module driver. This file provides firmware functions to manage the following functionalities of the Cryptography (CRYP) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The CRYP HAL driver can be used in CRYP IP as follows: (#)Initialize the CRYP low level resources by implementing the HAL_CRYP_MspInit(): (##) Enable the CRYP interface clock using __HAL_RCC_CRYP_CLK_ENABLE() (##) In case of using interrupts (e.g. HAL_CRYP_Encrypt_IT()) (+++) Configure the CRYP interrupt priority using HAL_NVIC_SetPriority() (+++) Enable the CRYP IRQ handler using HAL_NVIC_EnableIRQ() (+++) In CRYP IRQ handler, call HAL_CRYP_IRQHandler() (##) In case of using DMA to control data transfer (e.g. HAL_CRYP_Encrypt_DMA()) (+++) Enable the DMAx interface clock using __RCC_DMAx_CLK_ENABLE() (+++) Configure and enable two DMA streams one for managing data transfer from memory to peripheral (input stream) and another stream for managing data transfer from peripheral to memory (output stream) (+++) Associate the initialized DMA handle to the CRYP DMA handle using __HAL_LINKDMA() (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the two DMA Streams. The output stream should have higher priority than the input stream HAL_NVIC_SetPriority() and HAL_NVIC_EnableIRQ() (#)Initialize the CRYP according to the specified parameters : (##) The data type: bit swap(1-bit data), byte swap(8-bit data), half word swap(16-bit data) or no swap(32-bit data). (##) The key size: 128, 192 or 256. (##) The AlgoMode DES/ TDES Algorithm ECB/CBC or AES Algorithm ECB/CBC/CTR/GCM or CCM. (##) The initialization vector (counter). It is not used in ECB mode. (##) The key buffer used for encryption/decryption. (##) The Header used only in AES GCM and CCM Algorithm for authentication. (##) The HeaderSize The size of header buffer in word. (##) The B0 block is the first authentication block used only in AES CCM mode. (#)Three processing (encryption/decryption) functions are available: (##) Polling mode: encryption and decryption APIs are blocking functions i.e. they process the data and wait till the processing is finished, e.g. HAL_CRYP_Encrypt & HAL_CRYP_Decrypt (##) Interrupt mode: encryption and decryption APIs are not blocking functions i.e. they process the data under interrupt, e.g. HAL_CRYP_Encrypt_IT & HAL_CRYP_Decrypt_IT (##) DMA mode: encryption and decryption APIs are not blocking functions i.e. the data transfer is ensured by DMA, e.g. HAL_CRYP_Encrypt_DMA & HAL_CRYP_Decrypt_DMA (#)When the processing function is called at first time after HAL_CRYP_Init() the CRYP peripheral is configured and processes the buffer in input. At second call, no need to Initialize the CRYP, user have to get current configuration via HAL_CRYP_GetConfig() API, then only HAL_CRYP_SetConfig() is requested to set new parametres, finally user can start encryption/decryption. (#)Call HAL_CRYP_DeInit() to deinitialize the CRYP peripheral. (#)To process a single message with consecutive calls to HAL_CRYP_Encrypt() or HAL_CRYP_Decrypt() without having to configure again the Key or the Initialization Vector between each API call, the field KeyIVConfigSkip of the initialization structure must be set to CRYP_KEYIVCONFIG_ONCE. Same is true for consecutive calls of HAL_CRYP_Encrypt_IT(), HAL_CRYP_Decrypt_IT(), HAL_CRYP_Encrypt_DMA() or HAL_CRYP_Decrypt_DMA(). [..] The cryptographic processor supports following standards: (#) The data encryption standard (DES) and Triple-DES (TDES) supported only by CRYP1 IP: (##)64-bit data block processing (##) chaining modes supported : (+++) Electronic Code Book(ECB) (+++) Cipher Block Chaining (CBC) (##) keys length supported :64-bit, 128-bit and 192-bit. (#) The advanced encryption standard (AES) supported by CRYP1: (##)128-bit data block processing (##) chaining modes supported : (+++) Electronic Code Book(ECB) (+++) Cipher Block Chaining (CBC) (+++) Counter mode (CTR) (+++) Galois/counter mode (GCM/GMAC) (+++) Counter with Cipher Block Chaining-Message(CCM) (##) keys length Supported : (+++) for CRYP1 IP: 128-bit, 192-bit and 256-bit. [..] This section describes the AES Galois/counter mode (GCM) supported by both CRYP1 IP: (#) Algorithm supported : (##) Galois/counter mode (GCM) (##) Galois message authentication code (GMAC) :is exactly the same as GCM algorithm composed only by an header. (#) Four phases are performed in GCM : (##) Init phase: IP prepares the GCM hash subkey (H) and do the IV processing (##) Header phase: IP processes the Additional Authenticated Data (AAD), with hash computation only. (##) Payload phase: IP processes the plaintext (P) with hash computation + keystream encryption + data XORing. It works in a similar way for ciphertext (C). (##) Final phase: IP generates the authenticated tag (T) using the last block of data. HAL_CRYPEx_AESGCM_GenerateAuthTAG API used in this phase to generate 4 words which correspond to the Tag. user should consider only part of this 4 words, if Tag length is less than 128 bits. (#) structure of message construction in GCM is defined as below : (##) 16 bytes Initial Counter Block (ICB)composed of IV and counter (##) The authenticated header A (also knows as Additional Authentication Data AAD) this part of the message is only authenticated, not encrypted. (##) The plaintext message P is both authenticated and encrypted as ciphertext. GCM standard specifies that ciphertext has same bit length as the plaintext. (##) The last block is composed of the length of A (on 64 bits) and the length of ciphertext (on 64 bits) [..] This section describe The AES Counter with Cipher Block Chaining-Message Authentication Code (CCM) supported by both CRYP1 IP: (#) Specific parameters for CCM : (##) B0 block : According to NIST Special Publication 800-38C, The first block B0 is formatted as follows, where l(m) is encoded in most-significant-byte first order(see below table 3) (+++) Q: a bit string representation of the octet length of P (plaintext) (+++) q The octet length of the binary representation of the octet length of the payload (+++) A nonce (N), n The octet length of the where n+q=15. (+++) Flags: most significant octet containing four flags for control information, (+++) t The octet length of the MAC. (##) B1 block (header) : associated data length(a) concatenated with Associated Data (A) the associated data length expressed in bytes (a) defined as below: (+++) If 0 < a < 216-28, then it is encoded as [a]16, i.e. two octets (+++) If 216-28 < a < 232, then it is encoded as 0xff || 0xfe || [a]32, i.e. six octets (+++) If 232 < a < 264, then it is encoded as 0xff || 0xff || [a]64, i.e. ten octets (##) CTRx block : control blocks (+++) Generation of CTR1 from first block B0 information : equal to B0 with first 5 bits zeroed and most significant bits storing octet length of P also zeroed, then incremented by one ( see below Table 4) (+++) Generation of CTR0: same as CTR1 with bit[0] set to zero. (#) Four phases are performed in CCM for CRYP1 IP: (##) Init phase: IP prepares the GCM hash subkey (H) and do the IV processing (##) Header phase: IP processes the Additional Authenticated Data (AAD), with hash computation only. (##) Payload phase: IP processes the plaintext (P) with hash computation + keystream encryption + data XORing. It works in a similar way for ciphertext (C). (##) Final phase: IP generates the authenticated tag (T) using the last block of data. HAL_CRYPEx_AESCCM_GenerateAuthTAG API used in this phase to generate 4 words which correspond to the Tag. user should consider only part of this 4 words, if Tag length is less than 128 bits *** Callback registration *** ============================= [..] The compilation define USE_HAL_CRYP_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. Use Functions @ref HAL_CRYP_RegisterCallback() or HAL_CRYP_RegisterXXXCallback() to register an interrupt callback. [..] Function @ref HAL_CRYP_RegisterCallback() allows to register following callbacks: (+) InCpltCallback : Input FIFO transfer completed callback. (+) OutCpltCallback : Output FIFO transfer completed callback. (+) ErrorCallback : callback for error detection. (+) MspInitCallback : CRYP MspInit. (+) MspDeInitCallback : CRYP MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function @ref HAL_CRYP_UnRegisterCallback() to reset a callback to the default weak function. @ref HAL_CRYP_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) InCpltCallback : Input FIFO transfer completed callback. (+) OutCpltCallback : Output FIFO transfer completed callback. (+) ErrorCallback : callback for error detection. (+) MspInitCallback : CRYP MspInit. (+) MspDeInitCallback : CRYP MspDeInit. [..] By default, after the @ref HAL_CRYP_Init() and when the state is HAL_CRYP_STATE_RESET all callbacks are set to the corresponding weak functions : examples @ref HAL_CRYP_InCpltCallback() , @ref HAL_CRYP_OutCpltCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak function in the @ref HAL_CRYP_Init()/ @ref HAL_CRYP_DeInit() only when these callbacks are null (not registered beforehand). if not, MspInit or MspDeInit are not null, the @ref HAL_CRYP_Init() / @ref HAL_CRYP_DeInit() keep and use the user MspInit/MspDeInit functions (registered beforehand) [..] Callbacks can be registered/unregistered in HAL_CRYP_STATE_READY state only. Exception done MspInit/MspDeInit callbacks that can be registered/unregistered in HAL_CRYP_STATE_READY or HAL_CRYP_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using @ref HAL_CRYP_RegisterCallback() before calling @ref HAL_CRYP_DeInit() or @ref HAL_CRYP_Init() function. [..] When The compilation define USE_HAL_CRYP_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
Table 1. Initial Counter Block (ICB) +----------------------------------------------------—+ | Initialization vector (IV) | Counter | |-------------—|-------------—|--------—|------—| 127 95 63 31 0
Bit Number Register Contents ---------- --------------- ----------- 127 ...96 CRYP_IV1R[31:0] ICB[127:96] 95 ...64 CRYP_IV1L[31:0] B0[95:64] 63 ... 32 CRYP_IV0R[31:0] ICB[63:32] 31 ... 0 CRYP_IV0L[31:0] ICB[31:0], where 32-bit counter= 0x2
Table 2. GCM last block definition
+-------------------------------------------------------------------+ | Bit[0] | Bit[32] | Bit[64] | Bit[96] | |-----------|--------------------|-----------|----------------------| | 0x0 | Header length[31:0]| 0x0 | Payload length[31:0] | |-----------|--------------------|-----------|----------------------|
Table 3. B0 block Octet Number Contents
0 Flags 1 ... 15-q Nonce N 16-q ... 15 Q
the Flags field is formatted as follows:
Bit Number Contents ---------- ---------------------- 7 Reserved (always zero) 6 Adata 5 ... 3 (t-2)/2 2 ... 0 [q-1]3
Table 4. CTRx block Bit Number Register Contents
127 ...96 CRYP_IV1R[31:0] B0[127:96], where Q length bits are set to 0, except for bit 0 that is set to 1 95 ...64 CRYP_IV1L[31:0] B0[95:64] 63 ... 32 CRYP_IV0R[31:0] B0[63:32] 31 ... 0 CRYP_IV0L[31:0] B0[31:0], where flag bits set to 0
