RTEMS 6.1-rc2
Header file of CRC HAL module. More...
struct | CRC_InitTypeDef |
CRC Init Structure definition. More... | |
struct | CRC_HandleTypeDef |
CRC Handle Structure definition. More... | |
#define | DEFAULT_CRC32_POLY 0x04C11DB7U |
#define | DEFAULT_CRC_INITVALUE 0xFFFFFFFFU |
#define | DEFAULT_POLYNOMIAL_ENABLE ((uint8_t)0x00U) |
#define | DEFAULT_POLYNOMIAL_DISABLE ((uint8_t)0x01U) |
#define | DEFAULT_INIT_VALUE_ENABLE ((uint8_t)0x00U) |
#define | DEFAULT_INIT_VALUE_DISABLE ((uint8_t)0x01U) |
#define | CRC_POLYLENGTH_32B 0x00000000U |
#define | CRC_POLYLENGTH_16B CRC_CR_POLYSIZE_0 |
#define | CRC_POLYLENGTH_8B CRC_CR_POLYSIZE_1 |
#define | CRC_POLYLENGTH_7B CRC_CR_POLYSIZE |
#define | HAL_CRC_LENGTH_32B 32U |
#define | HAL_CRC_LENGTH_16B 16U |
#define | HAL_CRC_LENGTH_8B 8U |
#define | HAL_CRC_LENGTH_7B 7U |
#define | CRC_INPUTDATA_FORMAT_UNDEFINED 0x00000000U |
#define | CRC_INPUTDATA_FORMAT_BYTES 0x00000001U |
#define | CRC_INPUTDATA_FORMAT_HALFWORDS 0x00000002U |
#define | CRC_INPUTDATA_FORMAT_WORDS 0x00000003U |
#define | __HAL_CRC_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_CRC_STATE_RESET) |
Reset CRC handle state. | |
#define | __HAL_CRC_DR_RESET(__HANDLE__) ((__HANDLE__)->Instance->CR |= CRC_CR_RESET) |
Reset CRC Data Register. | |
#define | __HAL_CRC_INITIALCRCVALUE_CONFIG(__HANDLE__, __INIT__) ((__HANDLE__)->Instance->INIT = (__INIT__)) |
Set CRC INIT non-default value. | |
#define | __HAL_CRC_SET_IDR(__HANDLE__, __VALUE__) (WRITE_REG((__HANDLE__)->Instance->IDR, (__VALUE__))) |
Store data in the Independent Data (ID) register. | |
#define | __HAL_CRC_GET_IDR(__HANDLE__) (((__HANDLE__)->Instance->IDR) & CRC_IDR_IDR) |
Return the data stored in the Independent Data (ID) register. | |
#define | IS_DEFAULT_POLYNOMIAL(DEFAULT) |
#define | IS_DEFAULT_INIT_VALUE(VALUE) |
#define | IS_CRC_POL_LENGTH(LENGTH) |
#define | IS_CRC_INPUTDATA_FORMAT(FORMAT) |
Enumerations | |
enum | HAL_CRC_StateTypeDef { HAL_CRC_STATE_RESET = 0x00U , HAL_CRC_STATE_READY = 0x01U , HAL_CRC_STATE_BUSY = 0x02U , HAL_CRC_STATE_TIMEOUT = 0x03U , HAL_CRC_STATE_ERROR = 0x04U } |
CRC HAL State Structure definition. More... | |
HAL_StatusTypeDef | HAL_CRC_Init (CRC_HandleTypeDef *hcrc) |
HAL_StatusTypeDef | HAL_CRC_DeInit (CRC_HandleTypeDef *hcrc) |
void | HAL_CRC_MspInit (CRC_HandleTypeDef *hcrc) |
void | HAL_CRC_MspDeInit (CRC_HandleTypeDef *hcrc) |
uint32_t | HAL_CRC_Accumulate (CRC_HandleTypeDef *hcrc, uint32_t pBuffer[], uint32_t BufferLength) |
uint32_t | HAL_CRC_Calculate (CRC_HandleTypeDef *hcrc, uint32_t pBuffer[], uint32_t BufferLength) |
HAL_CRC_StateTypeDef | HAL_CRC_GetState (CRC_HandleTypeDef *hcrc) |
