RTEMS 6.1-rc2
stm32h747i_eval_errno.h File Reference
Error Code. More...
#define BSP_ERROR_NONE   0
#define BSP_ERROR_NO_INIT   -1
#define BSP_ERROR_WRONG_PARAM   -2
#define BSP_ERROR_BUSY   -3
#define BSP_ERROR_PERIPH_FAILURE   -4
#define BSP_ERROR_COMPONENT_FAILURE   -5
#define BSP_ERROR_UNKNOWN_FAILURE   -6
#define BSP_ERROR_UNKNOWN_COMPONENT   -7
#define BSP_ERROR_BUS_FAILURE   -8
#define BSP_ERROR_CLOCK_FAILURE   -9
#define BSP_ERROR_MSP_FAILURE   -10
#define BSP_ERROR_FEATURE_NOT_SUPPORTED   -11
#define BSP_ERROR_QSPI_ASSIGN_FAILURE   -24
#define BSP_ERROR_QSPI_SETUP_FAILURE   -25
#define BSP_ERROR_QSPI_MMP_LOCK_FAILURE   -26
#define BSP_ERROR_QSPI_MMP_UNLOCK_FAILURE   -27
#define BSP_ERROR_TS_TOUCH_NOT_DETECTED   -30
#define BSP_ERROR_BUS_TRANSACTION_FAILURE   -100
#define BSP_ERROR_BUS_ARBITRATION_LOSS   -101
#define BSP_ERROR_BUS_ACKNOWLEDGE_FAILURE   -102
#define BSP_ERROR_BUS_PROTOCOL_FAILURE   -103
#define BSP_ERROR_BUS_MODE_FAULT   -104
#define BSP_ERROR_BUS_FRAME_ERROR   -105
#define BSP_ERROR_BUS_CRC_ERROR   -106
#define BSP_ERROR_BUS_DMA_FAILURE   -107
Error Code.
Author
MCD Application Team
Attention
Copyright (c) 2019 STMicroelectronics. All rights reserved.
