RTEMS 6.1-rc2
spi-sd-card.h
2
9/*
10 * Copyright (c) 2008 embedded brains GmbH & Co. KG
11 * Redistribution and use in source and binary forms, with or without
12 * modification, are permitted provided that the following conditions
13 * are met:
14 * 1. Redistributions of source code must retain the above copyright
15 * notice, this list of conditions and the following disclaimer.
16 * 2. Redistributions in binary form must reproduce the above copyright
17 * notice, this list of conditions and the following disclaimer in the
18 * documentation and/or other materials provided with the distribution.
19 *
20 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
21 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
22 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
23 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
24 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
25 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
26 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
27 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
28 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
29 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
30 * POSSIBILITY OF SUCH DAMAGE.
31 */
32
33#ifndef LIBI2C_SD_CARD_H
34#define LIBI2C_SD_CARD_H
35
36#include <stdint.h>
37#include <stdbool.h>
38
39#include <rtems/libi2c.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
45#define SD_CARD_IDLE_TOKEN 0xff
46
54#define SD_CARD_COMMAND_SIZE 18
55
56#define SD_CARD_TRANSFER_MODE_DEFAULT { .baudrate = 400000, .bits_per_char = 8, .lsb_first = FALSE, .clock_inv = FALSE, .clock_phs = FALSE, .idle_char = SD_CARD_IDLE_TOKEN }
57
58#define SD_CARD_COMMAND_DEFAULT { \
59 SD_CARD_IDLE_TOKEN, \
60 0x40, 0, 0, 0, 0, 0x95, \
61 SD_CARD_IDLE_TOKEN, SD_CARD_IDLE_TOKEN, \
62 SD_CARD_IDLE_TOKEN, SD_CARD_IDLE_TOKEN, \
63 SD_CARD_IDLE_TOKEN, SD_CARD_IDLE_TOKEN, \
64 SD_CARD_IDLE_TOKEN, SD_CARD_IDLE_TOKEN, \
65 SD_CARD_IDLE_TOKEN, SD_CARD_IDLE_TOKEN, \
66 SD_CARD_IDLE_TOKEN \
67}
68
69/* Default speed = 400kbps, default timeout = 100ms, n_ac_max is in bytes */
70#define SD_CARD_N_AC_MAX_DEFAULT 5000
71
72typedef struct {
73 const char *device_name;
75 rtems_libi2c_tfr_mode_t transfer_mode;
76 uint8_t command [SD_CARD_COMMAND_SIZE];
77 uint8_t response [SD_CARD_COMMAND_SIZE];
78 int response_index;
79 uint32_t n_ac_max;
80 uint32_t block_number;
81 uint32_t block_size;
82 uint32_t block_size_shift;
83 bool busy;
84 bool verbose;
85 bool schedule_if_busy;
86 uint32_t retries;
88
89extern sd_card_driver_entry sd_card_driver_table [];
90
91extern size_t sd_card_driver_table_size;
92
93rtems_status_code sd_card_register( void);
94
95#ifdef __cplusplus
96}
97#endif /* __cplusplus */
98
99#endif /* LIBI2C_SD_CARD_H */
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Legacy I2C Library.
Definition: spi-sd-card.h:54
Definition: libi2c.h:462
Definition: spi-sd-card.h:72
