RTEMS 6.1-rc2
smp-imps.h
1
8/*
9 * Author: Erich Boleyn <erich@uruk.org>
10 * http://www.uruk.org/~erich/
11 *
12 * Copyright (c) 1997-2011 Erich Boleyn. All rights reserved.
13 *
16 * are met:
22 * 3. The name of the author may not be used to endorse or promote products
23 * derived from this software without specific prior written permission.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
26 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
27 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
28 * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
29 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
30 * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
31 * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
32 * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
33 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
34 * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * Header file implementing Intel MultiProcessor Specification (MPS)
39 * version 1.1 and 1.4 SMP hardware control for Intel Architecture CPUs,
40 * with hooks for running correctly on a standard PC without the hardware.
41 *
42 * This file was created from information in the Intel MPS version 1.4
43 * document, order number 242016-004, which can be ordered from the
44 * Intel literature center.
45 */
46
47/*
48 * This file is based upon code by Eric Boleyn as documented above.
49 * RTEMS support was added and minimal other changes were made.
50 * This should make it easier to compare this file with the original
51 * version.
52 *
53 * COPYRIGHT (c) 2011.
54 * On-Line Applications Research Corporation (OAR).
55 *
56 * The license and distribution terms for this file may be
57 * found in the file LICENSE in this distribution or at
58 * http://www.rtems.org/license/LICENSE.
59 */
60
70#ifndef _SMP_IMPS_H
71#define _SMP_IMPS_H
72
73/* make sure "apic.h" is included */
74#ifndef _APIC_H
75#error Must include "apic.h" before "smp-imps.h"
76#endif /* !_APIC_H */
77
78/*
79 * Defines used.
80 */
81
82#define IMPS_READ(x) (*((volatile unsigned *) (x)))
83#define IMPS_WRITE(x,y) (*((volatile unsigned *) (x)) = (y))
84
85#ifdef IMPS_DEBUG
86#define IMPS_DEBUG_PRINT(x) KERNEL_PRINT(x)
87#else /* !IMPS_DEBUG */
88#define IMPS_DEBUG_PRINT(x)
89#endif /* !IMPS_DEBUG */
90
91#define IMPS_MAX_CPUS APIC_BCAST_ID
92
97#define IMPS_FPS_SIGNATURE ('_' | ('M'<<8) | ('P'<<16) | ('_'<<24))
98#define IMPS_FPS_IMCRP_BIT 0x80
99#define IMPS_FPS_DEFAULT_MAX 7
100
105#define IMPS_CTH_SIGNATURE ('P' | ('C'<<8) | ('M'<<16) | ('P'<<24))
106
110#define IMPS_FLAG_ENABLED 1
111#define IMPS_BCT_PROCESSOR 0
112#define IMPS_CPUFLAG_BOOT 2
113#define IMPS_BCT_BUS 1
114#define IMPS_BCT_IOAPIC 2
115#define IMPS_BCT_IO_INTERRUPT 3
116#define IMPS_BCT_LOCAL_INTERRUPT 4
117#define IMPS_INT_INT 0
118#define IMPS_INT_NMI 1
119#define IMPS_INT_SMI 2
120#define IMPS_INT_EXTINT 3
121
122
123/*
124 * Typedefs and data item definitions done here.
125 */
126
127typedef struct imps_fps imps_fps;
128typedef struct imps_cth imps_cth;
129typedef struct imps_processor imps_processor;
130typedef struct imps_bus imps_bus;
131typedef struct imps_ioapic imps_ioapic;
132typedef struct imps_interrupt imps_interrupt;
133
134
135/*
136 * Data structures defined here
137 */
138
146{
147 unsigned sig;
148 imps_cth *cth_ptr;
149 unsigned char length;
150 unsigned char spec_rev;
151 unsigned char checksum;
152 unsigned char feature_info[5];
153};
154
162{
163 unsigned sig;
164 unsigned short base_length;
165 unsigned char spec_rev;
166 unsigned char checksum;
167 char oem_id[8];
168 char prod_id[12];
169 unsigned oem_table_ptr;
170 unsigned short oem_table_size;
171 unsigned short entry_count;
172 unsigned lapic_addr;
173 unsigned short extended_length;
174 unsigned char extended_checksum;
175 char reserved[1];
176};
177
185{
186 unsigned char type;
187 unsigned char apic_id;
188 unsigned char apic_ver;
189 unsigned char flags;
190 unsigned signature;
191 unsigned features;
192 char reserved[8];
193};
194
196{
197 unsigned char type;
198 unsigned char id;
199 char bus_type[6];
200};
201
203{
204 unsigned char type;
205 unsigned char id;
206 unsigned char ver;
207 unsigned char flags;
208 unsigned addr;
209};
210
212{
213 unsigned char type;
214 unsigned char int_type;
215 unsigned short flags;
216 unsigned char source_bus_id;
217 unsigned char source_bus_irq;
218 unsigned char dest_apic_id;
219 unsigned char dest_apic_intin;
220};
221
222/*
223 * Exported globals here.
224 */
225
229extern unsigned char imps_cpu_apic_map[IMPS_MAX_CPUS];
230extern unsigned char imps_apic_cpu_map[IMPS_MAX_CPUS];
231
233extern char _binary_appstart_bin_start[];
234extern char _binary_appstart_bin_size[];
235
237extern unsigned imps_lapic_addr;
238
239/*
240 * Defines that use variables
241 */
242#define IMPS_LAPIC_READ(x) (*((volatile unsigned *) (imps_lapic_addr+(x))))
243#define IMPS_LAPIC_WRITE(x, y) \
244 (*((volatile unsigned *) (imps_lapic_addr+(x))) = (y))
245
246#endif /* !_SMP_IMPS_H */
247
These map from virtual cpu numbers to APIC id's and back.
Definition: smp-imps.c:198
base address of application processor reset code at 0x70000
base address of the local apic. Usually 0xFEE00000
Definition: smp-imps.c:202
Definition: smp-imps.h:196
unsigned char type
must be 1
Definition: smp-imps.h:197
MP Configuration Table Header (cth)
Definition: smp-imps.h:162
MP Floating Pointer Structure (fps)
Definition: smp-imps.h:146
Definition: smp-imps.h:212
unsigned char type
must be 3 or 4
Definition: smp-imps.h:213
Definition: smp-imps.h:203
unsigned char type
must be 2
Definition: smp-imps.h:204
Base MP Configuration Table Types. They are sorted according to type (i.e. all of type 0 come first,...
Definition: smp-imps.h:185
unsigned char type
must be 0
Definition: smp-imps.h:186
